#4089 |
Drives: 2013 Scion FRS
![]() ![]() Got real lucky this weekend!! Brackets broke right off...It did not grind right threw my oil reservoir! Think I remember seeing @KraftWerks have made some new brackets?
#4090 |
Drives: White scion frs
Think I remember seeing @KraftWerks have made some new brackets?[/QUOTE] Yes they did! Same thing happened to mine a while back. Follow me on IG:@john9207 |
#4091 |
Cant seem to find them on the website? how did you get them?
#4092 |
#4093 |
Drives: 2014 Red Subaru BRZ
You can buy two large "P" clamps with rubber cushion and be done with it. They look like this:
http://www.homedepot.com/p/Gardner-B...7795/100160272 You'll need to find the correct size/ diameter to wrap around the whole reservoir though. |
#4094 |
BoostedBRZ
Drives: Turbo BRZ
CJ doesn't work for the company anymore. Seems like a lot of people are having that issue. I would make your own brackets from home depot and put rubber washers to absorb the vibrations. Good luck getting someone to help out. KW customer service has been REALLY difficult to work with recently with myself and a few others on the FB group. Good luck.
#4095 |
Drives: White frs
Which vendor has the best deals for this supercharger?
#4096 | |
Drives: 1996 ST204, Series 10 FR-S
My pulley bearings all have play after 8000kms (belt tension was checked throughout). I'm pretty sure I saw someone else with the same problems. It looks like the bearing loose their grease and wear themselves out prematurely. I started to hear a knocking sound so I took the belt off to check. I'm so glad it wasn't coming from my motor though.
They appear to be generic 6203-2RS no-name bearings. I love the kit but the cost savings that KW made seems to be biting us in the behind. Also, does anyone else hate the fasteners that KW supplied? They look like sh*t after a few years turning a rusty colour. Quote:
#4097 |
Well, replacing the bearing has only helped a little bit... Seems like the actual bearings in the blower are shot. Just stumbled upon this video and Tommy is seems like he has already experienced what I'm seeing.
[ame="https://www.youtube.com/watch?v=4K-uYgy679w"]Opening the Rotrex C30-94 Supercharger. - YouTube[/ame] |
#4098 |
Drives: Brz
What is everyone running for an oil cooler? Just picked up this kit, looking for something thermostatic.
#4099 |
Drives: S2000
I am looking for the stock 95mm (30 wide) Cog style pulley. Any chance anyone has one laying around and would sell it to me? Kraftwerks is on back order for 60+ days.
I have a 90mm if anyone would like to trade Thank you in advance. |
#4100 | |
Drives: GT86
What's problem do you have with this sandwich plate ? |
#4101 |
BoostedBRZ
Drives: Turbo BRZ
The rubber o ring that they supply is too big for the ring groove at the bottom of the sandwich plate. So what will end up happening is once it gets hot enough; the rubber will deteriorate and cause an oil leak.
![]() also if you check my build thread, found in my sig, you can see how i stacked a perrin spacer and the mocal spacer and mocal thermostat together to make something to clear....
#4102 |
BoostedBRZ
Drives: Turbo BRZ
if anyone is looking for a kit. get it. 3000 plus shipping:
i don't mind doing quotes just let me know your zip. http://www.ft86club.com/forums/showthread.php?t=121711
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
