Old 07-21-2017, 12:10 AM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by MassTroy View Post
Is there some way of knowing how compressible a pad is? I feel like the Hawk HP+ are pretty grabby which means they arent very compressible. I've gotten used to that and probably want something similar so I don't think I want something compressible.
"bite" is generally a subjective measurement, as objective measurement is rather expensive (brake dyno time is not cheap... think an order of magnitude more expensive than a chassis dyno for engine tuning).
Keep in mind, that while bite and performance frequently go hand in hand, one is not required for the other.
Try W3 for street use, and W5 for the track. Or W5 full time like many other full-time race pad users here. Keep in mind you'll need to bed the W5 properly to keep them quiet for street use.
Old 07-21-2017, 12:35 AM   #44
MassTroy
Subaru BRZ
MassTroy's Avatar
Drives: 2013 Subaru BRZ
Thanks Mike. I actually just placed an order for a set of Ferodo DS2500 since so many people were recommending them. They seemed to be in between the W3 and W5 in both price and performance. Hope I like them
MassTroy is offline   Reply With Quote
Old 07-21-2017, 03:28 AM   #45
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Pat View Post
Also consider Ferodo DS2500 as a dual-purpose pad.
Had them on my previous car (lighter and less powerful than BRZ) and they worked street and track. I had fade when using them with my BRZ and Sprint kit.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
CSG Mike (07-21-2017), Tristor (03-29-2018)
Old 07-21-2017, 01:08 PM   #46
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm confident I would also fade them in a BRZ with AP Sprint.
The Following 2 Users Say Thank You to Pat For This Useful Post:
Old 07-21-2017, 01:11 PM   #47
Pat
Pat's Avatar
Drives: 2023 BRZ
Oh I have some pads for you to check out then...
The pads i run on my BRZ have a 0.02μ variance over the ENTIRE range of 0C to 1200C.
Sounds super cool, Mike. Not many pads can do that! Maybe those would be a better option for him, depending on cost relative to the DS2500.
While it sounds like a pad I could potentially use as a dual purpose pad, I have to think there are other drawbacks (i.e. cost, rotor wear, noise, dust, availability, etc.) that would make using that one pad less appealing to me than more purpose-specific pads. Regardless, I am curious.
The Following User Says Thank You to Pat For This Useful Post:
Old 07-21-2017, 01:12 PM   #48
MassTroy
Subaru BRZ
MassTroy's Avatar
The big brake kit should keep the brakes cooler than the stock brake system. The car isn't any heavier and isnt putting any extra heat into the brakes. It should be less likely to fade. Unless the driver drove harder/longer knowing they had a BBK.
The Following User Says Thank You to MassTroy For This Useful Post:
Old 07-21-2017, 01:22 PM   #49
Pat
Pat's Avatar
Drives: 2023 BRZ
I disagree. With sticky tires on track one can put WAY more heat into the brakes. I have a BRZ with no power or aero modifications and an AP Sprint kit with DTC-60s and sometimes I feel like I'm nearing the limit of those pads.
Old 07-21-2017, 02:23 PM   #50
CSG Mike
CSG Mike's Avatar
Shoot me an email. They're in a whole different league price point wise, but they're very streetable. Here's a pic of the last rotor I replaced, to demonstrate the amount of grooving.
15k mixed miles.
https://www.instagram.com/p/BTsDa8kl...n-by=psychoazn
Old 07-21-2017, 02:26 PM   #51
CSG Mike
CSG Mike's Avatar
Actually, sort of yes and sort of no. Multiple factors here.
- Cooling capacity (surface area and airflow) is increased with most BBKs. Most BBKs have more surface area via increased rotor thickness and more vanes.
- Thermal capacity (rotor mass) is decreased with most BBKs. The brake rotor is a heat sink that absorbs the kinetic energy which is turned into heat under braking. The rotor absorbs the heat from the pads, and then releases it into the air. If you have less rotor mass, the same amount of energy (heat) is still going into the rotor, so you actually run the rotors *hotter*
Almost every BBK for this platform increases cooling, but decreases thermal capacity. You don't see increased thermal capacity until you get to to 325mm 1 piece rotor BBKs, or 355mm 2 piece rotor BBKs.
Any BBK that advertises weight reduction, is a decrease in thermal capacity. You have to find a balance between cooling and thermal that is right for you.
Old 07-21-2017, 02:44 PM   #52
Pat
Pat's Avatar
Drives: 2023 BRZ
15k mixed miles.
Thanks for the offer, Mike. I do appreciate it. That said, I'm not exactly in pad-buying mode. I'm fortunate to have more free pads than I can use for the foreseeable future.
Old 07-21-2017, 02:51 PM   #53
CSG Mike
CSG Mike's Avatar
strictly educational
wparsons (07-23-2017)
Old 07-23-2017, 09:30 PM   #54
wparsons
wparsons's Avatar
Any more details on them? Shoot me a PM if you prefer.
flickr
Old 07-24-2017, 04:46 PM   #55
CSG Mike
CSG Mike's Avatar
Literally a flat torque curve from 0C-1200C. 0.02μ variance over the entire temperature range
Selection of desired torque in 0.05μ increments, so you can fine tune exactly how much bite and friction you have.
Additionally, release friction is linear with pressure, not just application pressure, so you can trail brake precisely.
All in all, it leads to a 100% predictable, 100% consistent pedal, so that you can brake at threshold every time, with absolute confidence. Additionally, you can do some gnarly things like braking mid-corner to slow down, and precisely control the rotation!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
lazyluka (07-25-2017), Tristor (03-29-2018), wparsons (07-25-2017)
Old 07-25-2017, 09:19 AM   #56
wparsons
wparsons's Avatar
Dare I ask what the price point is like for our stock calipers?
flickr
OND (07-25-2017)
brake, brake pad, counterspace, street brakes, track prep
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
How to restore OEM brake pads after a track day? torqdork Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-24-2013 12:45 PM
Daily drivers, do you swap street and track brake pads? qoncept Tracking / Autocross / HPDE / Drifting 31 06-26-2013 03:50 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
Track brake pads - front and rear? oofie Tracking / Autocross / HPDE / Drifting 37 05-26-2013 04:48 PM
