Old 01-19-2016, 01:16 AM   #15
Yoda
Drives: Crystal Black BRZ(Sophia)
Just going to go at it myself on Wednesday. Worst case take it to the dealer then.
Yoda is offline   Reply With Quote
Old 01-19-2016, 02:15 AM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Google is your friend, yes nut is easily accessible with wheel removed, retorquing may not solve it, but a new nut may help as the material is pretty soft and easily deformed.
You'll need a 32mm socket and a beefy breaker bar.
http://www.ft86club.com/forums/showthread.php?p=1194267
ineedyourdiddly
Yoda (01-19-2016)
Old 01-21-2016, 11:49 PM   #17
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
i have the same issue when i put my car in rear, usuually on a cold start. i always had this issue, but too lazy to bring it up to my dealer. guess next time i go in for service ill mention it.
morswestford is offline   Reply With Quote
Old 02-07-2016, 03:40 PM   #18
tracerit
Drives: '13 SSM BRZ Limited 6MT
I get this same noise driver side rear only when I go up and down my driveway (requires going at an angle too as my car is lowered, maybe 1.5-1.8"?). I can't reproduce it all the time, it happens randomly and I always try to listen for it when I go up and down the driveway. During straight leveled driving I can't hear it at all.
If I had the same issue as mentioned in this thread, would it be something that can be reproduced easily and on leveled surfaces?
tracerit is offline   Reply With Quote
Old 05-18-2016, 01:57 AM   #19
Teseo
Drives: frs
This problem must be solved Stat or can take sometime?
Old 07-20-2017, 10:40 PM   #20
stockysnail
Just the tip
stockysnail's Avatar
Here's my update on this. I originally took it to the dealer and they wouldn't touch my car as it had mods. I took it to a few more dealers and same thing. I replaced the axle nut myself and the click went away for a day. Later I read somewhere someone greasing all the internals of the ebrake assembly so I tried that, which lasted maybe about a year or so. The click came back last year so I tried lubing the ebrake up again but this time it didn't help. I'm stuck with the constant clicking noise when the wheel gains or looses torque in that area. It's pretty annoying. I try to drown it out with supercharger whine, music, and exhaust noise.
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 03:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
Stuttering/ticking noise while car is parked? jermyzy Issues | Warranty | Recalls / TSB 4 03-02-2014 08:35 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 06:55 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 06:42 PM
