Old 07-18-2017, 01:03 PM   #15
Teseo
Drives: frs
And how much for it? Of course hp per dollar
Old 07-18-2017, 01:33 PM   #16
Shady195
Drives: '13 10 Series FRS #1203
Waste of money and worthless to most of the cars theyre on.
Shady195 is offline   Reply With Quote
The Following 3 Users Say Thank You to Shady195 For This Useful Post:
j3rf (05-08-2019), Wayno (09-16-2017), wparsons (06-25-2019)
Old 07-18-2017, 01:42 PM   #17
Somerandom18
Drives: 2017 manual BRZ
Every little bit helps if you're staying NA.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following 2 Users Say Thank You to Somerandom18 For This Useful Post:
jdair28 (07-18-2017), nikitopo (07-19-2017)
Old 07-18-2017, 07:48 PM   #18
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
If you concerned with the best cost to power gain ratio and want to avoid wasting time or money the 86 platform is a poor platform. I would suggest anything with a 4g63 engine such as a 1st or 2nd gen eclipse or an evo 1-9. A 3rd runner up would be the 4b11 powered evo 10. for about $4,000-$5,000 you can double the power output to the wheels.
~$1000 Stock frame turbo with 30r wheel or larger
~$350 1200cc injectors
~$450 dual walbro drop in fuel kit
~$50 Manual boost controller
~$50 boost gauge
~$100 3" down pipe
~$100 3" test pipe
~$350 3" catback
~$50 drop in filter (hack up the stock intake lid for more air flow)
~$350 intercooler of some sort
~$250 Intercooler piping
~$600 272/272 kelford cams (or larger size)
~$200 tuning cable + software payment
~$100 O2 pipe
~$300 Ported throttle body
Grand Total ~$4300
cost/power ratio: ~$17.20 per horsepower
*Most prices are for used items
**Self installation is assumed
***Self tuning is assumed
****On e85 this set up will place you north of 500hp to the wheels on both dynojet and mustang dynos
*****Factory evo 8/9 power to the wheels averages between 230-250hp
Hope this helps you in finding the best bang for your buck automotive power gains.
Originally Posted by jdair28 View Post
@TachyonBomb thank you very much for the pictures! It looks like the spacer, thermal gasket, and TB are all flush together (at least from the top). Is that the case? If I line everything up so that the hump at the top is in line with them all, the spacer extends a bit more to the left.
Yup just line it up with the hump and everything falls in place. It is a pretty easy install and the included instructions are pretty clear in the steps you take.
Originally Posted by Drakiv View Post
Ah ok, good to know. I wanna get one, just wasnt sure about all of that. I just got a 30% off coupon for it too
30% lucky ass!! I got 25% off with their july 4th sale.
TachyonBomb is offline   Reply With Quote
The Following 3 Users Say Thank You to TachyonBomb For This Useful Post:
Drakiv (07-18-2017), jdair28 (07-18-2017), Teseo (07-19-2017)
Old 07-18-2017, 09:11 PM   #19
jdair28
Drives: 2013 Scion FR-S 10 Series
I tried again today with no luck...I disconnected the battery this time since last time I did not. The car would try to start, but it would not. It would try cranking for a couple seconds but then give out. Here are some pictures:
https://drive.google.com/open?id=0B8...mt3Y3lqa0o0U2M
https://drive.google.com/open?id=0B8...Tg0MEFObnVlUFE
https://drive.google.com/open?id=0B8...WdOUktvRTl4STg
I'm using the TRD CAI btw (in case that's important)
I forgot to take a picture of the spacer, but it does have the extra hole for the 2017 aluminum intake manifold. However, I don't think the setup is seated properly.
As you can see, the spacer is not flush with the thermal gasket and the throttle body. When trying to screw the bolts back in, the bottom right screw is much further in than the other 3 screws. I'm not sure if this is causing the problem or if it's a faulty harness. I plan on calling Grams tomorrow. Thanks for the help/input
jdair28 is offline   Reply With Quote
The Following User Says Thank You to jdair28 For This Useful Post:
SuperTom (07-18-2017)
Old 07-19-2017, 12:29 AM   #20
TachyonBomb
You really should have disconnected the battery the first time. I remember reading two other posts where they did not initially disconnect the battery and they had all the issues.
Try hitting the start button twice without stepping on the clutch peddle. this will put your cars electronics into the on position. Take the intake pipe off the throttle body while the car is in on position and have a friend step on the gas peddle. See if the throttle flap opens and closes. Have this friend try to turn the car on (start button with clutch pressed down) while the intake pipe is off. check to see if the flap opens.
If the flap opens doing the above then the electrical part is all good. If not get an amp meter or a friend with an amp meter and unplug the harness at the throttle body. Check to see if all the electrical pin are giving proper voltage readings. You are going to have to report these readings to grams to see if they can confirm the harness is ok or check on here for what the proper readings should be.
If the flap is opening and closing in the above tests and the connection is good. The next thing I would draw your attention to would be the threaded hole at the top of the throttle body that requires you to screw in the threaded plug provided with the kit. From your pics it looks like you screwed it in way to far to where it is not sealing off the whole. This could be the angle and resolution in your pictures but when compared to the pictures I took at 86fest it seems like you screwed it in way to deep which would leave you with an air leak.
So check those to things a post back what you found.
Old 07-19-2017, 12:32 AM   #21
TachyonBomb
Ya compare the hole and plug in your first pic to the plug and hole in the 2nd pic I provided from the grams display engine. Yours seems very recessed into the hole.
Old 07-19-2017, 07:55 AM   #22
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Try putting the stock throttle body back on before going any further.
Joon525 is offline   Reply With Quote
Old 07-19-2017, 11:33 AM   #23
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I second TachyonBombs method for testing here. If you don't have a friend around, you can alternatively unbolt the throttle body from the intake runners and set it on top of the engine to watch while you operate the throttle from inside the car. Was testing the other day and this method worked great for me.
B T is offline   Reply With Quote
Old 09-06-2017, 11:35 AM   #24
jdair28
thanks for the input everyone. Just an update on this, I was able to read the fault code as P0121 and yeah the throttle body would not open with the gas pedal pressed. Grams is sending me a new wire harness, so hope that is the solution!
TachyonBomb (09-06-2017)
Old 09-14-2017, 12:16 PM   #25
jdair28
got the wire harness in, and whattaya know..it works like a charm!! Wow, granted it is my butt dyno, but throttle response is great! The best part is the sound as you can just hear the increased airflow! Thanks everyone!
The Following 5 Users Say Thank You to jdair28 For This Useful Post:
Joveen (03-19-2019), MJones_RB (10-30-2018), SuperTom (01-10-2020), TachyonBomb (09-14-2017), zeal86 (09-14-2017)
Old 09-14-2017, 07:52 PM   #26
TachyonBomb
glad you got it working man!!
The Following User Says Thank You to TachyonBomb For This Useful Post:
jdair28 (09-15-2017)
Old 09-16-2017, 06:36 AM   #27
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nice that Grams managed to make this product. Hope that now the different issues are resolved and users will have a straight forward installation.
The Following User Says Thank You to nikitopo For This Useful Post:
jdair28 (09-16-2017)
Old 03-26-2018, 01:53 PM   #28
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
is there a way to keep the coolant line? I have a forrester xt oil cooler that i would like to retain. The grams website is worthless for installation info.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
OEM throttle body nikitopo Engine, Exhaust, Bolt-Ons 10 01-07-2024 11:50 AM
OFT and Grams throttle body 86Speedy Software Tuning 27 05-05-2017 05:21 PM
