Old 12-17-2016, 05:49 AM   #15
davmandave
Drives: 2016 Scion FRS, Pearl White, M/T
Originally Posted by ysu View Post
Hey, thanks again for that tip on the tune. I've re-flashed to the old tune I used back then for tracking and I've got the generic oil temp that raceChrono reads.
So we've got to the core of the problem! Fantastic.
No problem. I'm really curious as to what in your tune disabled that. Were you logging extra stats with your tune or anything?
davmandave is offline   Reply With Quote
Old 12-17-2016, 08:21 AM   #16
steve99
Drives: FT86
I'd hate to do that - but for a test it makes sense. I'll have CEL codes with the ACE header Thanks for the suggestion.
p.s. is it possible the OFT reads the "other" pid ? One that can be hacked into Obdlink or Toque ( 2101 / 7E0 ) ?
OFT , ecutek and tactrix read logging parameters buy directly requesting the data f:om an ecu ram address. These ram addresses arexdifferent for each 86brz rom calid and different for different vehicles and have to be individually found by dissassembling the rom ecu program. Hoever it allows much fastercreading of data up to 20 times a second
Generic obd application like torque racecrono etc use pid or predetermined parameter id,s that are generally standard on all cars, however datexratexis slow may twice a second. Manufactures have to stick to a standard for basic pis,s but after that they are free to use their own pid,s i suspect oil temp is not a basic pid
ysu (12-17-2016)
Old 12-17-2016, 09:13 PM   #17
ysu
Drives: Toyota 86 GTS Auto
I do not know it, I have to wait for the gent who built the tune to help me out there. I'm not into building tunes myself, my time is very limited to try and dig myself into that
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
davmandave (12-19-2016)
Old 07-16-2017, 09:21 PM   #18
Colin86
Drives: 86
Sorry to necro a thread but I've got the exact same problem, I have an ODBlink and am using the ODBlink app but it doesn't show oil temp... When reading oil temp through the ECUtek it reads perfectly fine.
Was there a solution to reading oil temp in ODBlink?
Edit:
I also tried to add the custom PID via a link posted earlier in this thread and it didn't read anything, see screenshot below for settings:
Colin86 is offline   Reply With Quote
Old 07-17-2017, 08:57 AM   #19
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Oil temp reading via OBDLINK?
Edit:
Obdlink reads PIDs differently than Torque and ECUtek. This is my custom PID for oil temp:
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Colin86 (07-17-2017)
Old 07-17-2017, 11:02 AM   #20
Colin86
Drives: 86
Thank you!!! I'm going to give this a shot and will report back.
The Following User Says Thank You to Colin86 For This Useful Post:
Yoshoobaroo (07-18-2017)
Old 07-19-2017, 09:25 AM   #21
Colin86
Drives: 86
Confirmed, settings work. Thank you Yoshoobaroo!!
Yoshoobaroo (04-05-2018)
Old 12-14-2019, 05:34 PM   #22
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
I'm glad I just found this thread today. BUT I haven't been able to gleen the solution. Using torque and on OFT tune 1, oil temp is read. Write OFT tune 2, and I lost the oil temp. I am looking for exact instructions to be able to restore the oil temp with torque app.
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Oil galley temp reading low Tomita San Engine, Exhaust, Transmission 19 03-14-2017 05:22 PM
OFT, GPS, OBDLink dstrout Engine, Exhaust, Bolt-Ons 8 12-03-2015 12:53 PM
WTB - Scantool OBDlink RustySocket Want-To-Buy Requests 0 09-19-2015 12:05 AM
Sandwich plate - oil temp reading "accuracy" 1Cor10:23 Engine, Exhaust, Transmission 3 04-08-2015 01:36 AM
The Case of The Missing Oil Temp Reading Fastbrew Electronics | Audio | NAV | Infotainment 3 08-06-2014 11:25 AM
