| CANADA Canada |
#15 |
Drives: subaru
il have mine up for sale soon. 2013 sportech brz 31k kms for 19 grand. bumper has some damage on it. thats about it
#16 |
Drives: 2015 BRZ Sport Tech CWP
They're everywhere haha, I found two more:
http://www.firstchoiceautosalvage.co...c1586da21fa04/ http://www.firstchoiceautosalvage.co...8225cc598ab3f/ I would have to agree with others buying a running vehicle might be a better idea. You can find used ones for 14k on Kijiji. Part out the stuff you don't need to recoup the $
![]() Last edited by Guru Woodman; 12-16-2016 at 05:39 PM. |
#17 |
Drives: RAVEN FRS
LKQ
Stark Auto Plazek Impact Auto I bought a salvage title 2 years ago, front end damage. Total cost of the repairs were around 4.5k (I did most of the work myself). Ontario recently changed their laws and made inspections harder to pass. Tolerances have to be tighter + some other regulations are changed. OEM parts on the other hand were kind of hard to find (this was in 2014). Check out my instagram @agent__86 for th build pictures. |
| The Following User Says Thank You to darko For This Useful Post: | Tcoat (12-16-2016) |
#18 | |
Here is it's story: http://www.ft86club.com/forums/showt...66#post2797166 And more info here starting at post 142: http://www.ft86club.com/forums/showt...34#post2784934 It is sort of sad that I recognized the car and knew the story the second I clicked on the salvage link.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Guru Woodman (12-16-2016), unhappymeal (02-01-2017) |
#19 |
Drives: RAVEN FRS
#20 |
Slow lane
Drives: none
Came across these guys in the Eastern Townships of Quebec when I was searching for mine, wasn't looking for a damaged title though.
http://www.mrzperformance.com/en/veh...13-manuel-1958 http://www.mrzperformance.com/en/veh...13-manuel-1717 |
| The Following User Says Thank You to pitotshock For This Useful Post: | FirestormHachiroku (01-31-2017) |
#21 |
Drives: 2018 Miata RF, 2017 Golf R
If you bought my totaled red one, PM me. I still have the other remote and it's sitting on my bookshelf doing nothing as both the dealer and collision center did not want it back.
#22 | |
I set a strict budget for myself and bid on 4 cars (all at Impact Auto) before winning one within my budget and I'm very happy with it. No structural damage at all and it will be on the road soon. This route isn't for everybody as there is inherent risk but this is my second one and would do it again. Here's some before and I'll post some after when it's done. |
| The Following User Says Thank You to Bent42 For This Useful Post: | FirestormHachiroku (02-28-2017) |
#23 | |
#24 |
Yep, your bang on. The MAF (and the airbox) and 1 of the oil control valves got smashed. The rad got punched but surprisingly the fans and a/c condenser survived. The taillights are brutal. They are getting restored and all the red plastidip in the interior is going too.
#25 |
Progress update
So I guess I'm hijacking this thread but for those that are interested here's some updated pics.
Once I got it disassembled, other than the obvious body damage I found a broken oil control valve, the intake was crushed up against the TB and the MAF was smashed so it barely ran. Once I had my parts list I scoured the boards and Kijiji and was able to get a stock intake and headlights from a guy west of the city. I scored the bumper (in the right colour) near Ottawa, a pair of BRZ grey fenders in Markham and I have a white hood (not pictured) that I found north of the city. I have a line on a red hood from a member here but he's stopped communicating so we'll see what happens there. I ordered a new crash bar, rad support and rad from Rock Auto. The car came with an Invidia exhaust that I sold to fund the repairs and I found a stock exhaust almost free from a member here. Installed the new rad support, it is a bolt in piece except for 4 small spot welds. Mocked up the fenders before paint and trial fit the bumper. Once the fenders were back from paint I reassembled the front sheet metal as well as installed the new rad (not pictured) and the original fans, which needed some plastic welding on the shroud. Had to buy a new front signal light harness and socket for one side and repair a couple of broken light connectors as well. I've ordered new wheel well liners and some other small bits to complete the front end work. Once I figure if I'm getting the red hood or not I'll either bolt it on (the hinges need a small tweak) or put the white one on til I find a better hood. The last pic at the bottom is the fully assembled front end with the original hood bent back to shape-ish. Next on the list is to replace the seat belts, install the new steering wheel and it'll be ready for the road soon. |
| The Following User Says Thank You to Bent42 For This Useful Post: | Guru Woodman (05-02-2017) |
#26 |
While I don't expect throngs of you awaiting updates, the car is (mostly) done. Took longer than expected as I had a bit of a setback. Driving it into the shop one morning it developed a bad miss and spit a rocker through the valve cover. Thought it bent a valve but in the end it was just a small piece of the airbox plastic that jammed open an intake valve causing the rocker to fallout and get popped through the valve cover. While it was a ton of work to pull the motor and fix, it was a relatively cheap fix. My helper did some disassembly and even did some of the early torque sequences during reassembly.
Back together and it runs perfectly! Popped in a set of Eibach Sportlines and bolted on a set of staggered 18" Fastco FC04's. I had a deal cooked for a mint hood already red but it fell though thus the hood flag covering a white hood I picked up earlier that has some cosmetic challenges. When all was said and done I'm on the road for exactly half of what the cheapest FR-S listed locally on Kijiji is going for so I'm very happy! |
| The Following 3 Users Say Thank You to Bent42 For This Useful Post: |
| MK4 / A80 Toyota Supra appeciation thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 288 | 04-22-2021 06:59 PM |
| What Do You Most Regret Buying for your Twin? | Koa | Scion FR-S / Toyota 86 GT86 General Forum | 183 | 05-26-2015 05:31 PM |
| front lip totalled. where to get a new one in GTA? | chenshuo | CANADA | 4 | 10-05-2013 11:10 PM |
| buying salvage twin for track worth it? | WATCHMEHEAL | Tracking / Autocross / HPDE / Drifting | 15 | 09-03-2013 02:31 PM |
| FS: 2013 Totalled BRZ FS (~5,000 miles) | eklipz98 | Northern California | 45 | 02-03-2013 01:16 AM |
