Old 07-11-2017, 01:27 PM   #1
Diz86x
Drives: GT86 Nur spec
Intake manifold leak
Hello there,
My Brz is FI on fbm stage 1 turbo kit and today after just 3 minutes of redline when i came into a complete stop the car went off immedietly. I immedietly contacted my tuner and he asked me to clean the throttle and i did it did work until i tried stepping on the pedal a little bit and heard an air leak !
Please solutions
This is what i found after checking the intake manifold could it he the only reason?
Diz86x is offline   Reply With Quote
Old 07-11-2017, 08:36 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Are you suggesting your manifold sprung a leak under the heat shielding?
1974 TA22 Celica
2013 86 GT
Old 07-12-2017, 07:32 PM   #3
Diz86x
Yes
Old 07-12-2017, 07:53 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
That's odd sorry about your luck if it is melted. Replace it with a metal one
Old 07-12-2017, 09:27 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Diz86x View Post
Yes
It seems unlikely that would happen but not impossible. I assume you have checked all the piping from the turbo to the manifold for leaks already?
1974 TA22 Celica
2013 86 GT
Old 07-13-2017, 12:42 PM   #6
Amputechture
Drives: 2014 BRZ
That silver heat foil that you see is just that, the adhesive bond that mates it to the surface of underneath the manifold often degrades and makes it appear that there is a slit in the intake manifold. It has happened to me, and it is more than likely fine. You have more of a probability of those EVAP solenoid hoses popping off under boost....have you clamped them down? Best way to test is to do a smoke test.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 0 03-03-2016 08:29 PM
Intake manifold dallenj Engine, Exhaust, Transmission 0 11-02-2015 02:56 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
