Old 07-12-2017, 09:53 AM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
HID beam pattern issue
I recently purchased aftermarket HID bulb and installed in to Winjet headlight.
Also had aftermarket HID bulb for 2 years without any problem but this time beam pattern is just shittt.
anyone know what causes this problem?
bhbnuckle is offline   Reply With Quote
Old 07-12-2017, 10:24 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Shitty projectors without built-in cutoffs.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-12-2017, 11:58 AM   #3
Veeoh
Veeoh's Avatar
I've installed HIDs on my winjets...I'm satisfied with the output/cutoff on mines. Pretty even and clean cutoff once I leveled everything.
It looks like the bulbs are upside down on yours though? The winjets had a little slot shape for where the bulb wire should go (on the bottom)
Veeoh is offline   Reply With Quote
The Following User Says Thank You to Veeoh For This Useful Post:
bhbnuckle (07-12-2017)
Old 07-12-2017, 12:03 PM   #4
bhbnuckle
bhbnuckle's Avatar
Which means bulb wire should be on bottom?
I also have always been satisfied with HID bulbs but not this time.
Need to flip them around tonight
Thanks for your help!
Old 07-12-2017, 01:05 PM   #5
Veeoh
Veeoh's Avatar
Ay, No problem. I hope that's what it is. It's a pain in the ass to work the bulb once the headlights are already on the car. Or it might just be me lol. Hate that we have to remove the bumper for these things.
Frs bolt pattern OgCruzing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-06-2017 10:35 AM
FS: Brand New GT86 Headlight LHD Beam Pattern nigel-jdmparts Exterior Parts - Lighting 4 08-21-2014 12:48 PM
bolt pattern probs markm7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-19-2014 06:39 PM
MT shift pattern dietz Scion FR-S / Toyota 86 GT86 General Forum 21 10-12-2012 01:26 AM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 03:58 AM
