Old 02-14-2017, 03:23 PM   #561
allowe
allowe's Avatar
From what I can tell it's legal because mustangs are legal and they're red.
allowe is offline   Reply With Quote
Old 02-14-2017, 04:56 PM   #562
Brayden_23
Drives: Asphalt 2015 FRS
Originally Posted by allowe View Post
Can turn signals be red? Like can I get a bulb that's red? Is it legal?
Rear turn signals are only allowed to be red in US and Canada. However, "A 2008 U.S. study by the National Highway Traffic Safety Administration (NHTSA) suggests vehicles with amber rear signals rather than red ones are up to 28% less likely to be involved in certain kinds of collisions,[68] and a 2009 NHTSA study determined there is a significant overall safety benefit to amber rather than red rear turn signals."
Source: https://crashstats.nhtsa.dot.gov/Api...ication/811115
Brayden_23 is offline   Reply With Quote
Old 02-14-2017, 05:37 PM   #563
allowe
allowe's Avatar
Happy with mine but how long till I can put them on?? I nEed to drive to work in 4 hours :S Also, I used the vht nightshade red one, is there a glossifier I could use on it that's good? Can I use plasti dip glossifier ? I have 8 cans of that haha
Old 02-15-2017, 02:51 AM   #564
inferno56kb
inferno56kb's Avatar
Drives: GT86 raven
Did you clearcoat them or did you only use the VHT to make them red? because the clearcoat makes a huge difference in how glossy they are and it also helps to protect the color.
I left mine to cure for 48h before reinstalling them (which was probably more than needed) but my clearcoat said 24h to cure completely i think.
If you are unsure check the can of the paint you used and there it should say how long it takes for it to harden completely, if not then go on the website of VHT and check there.
inferno56kb is offline   Reply With Quote
Old 02-18-2017, 12:52 PM   #565
connorhelm
Drives: 2014 Pearl White Subaru BRZ
Duplicolor Metalcast and Krylon clear also used Meguairs plastic polish
connorhelm is offline   Reply With Quote
Old 07-07-2017, 11:22 PM   #566
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
Now that the gloss I'm looking for...
How often did you sand? How many coats of red vs clear?
Waffle86 is offline   Reply With Quote
Old 07-08-2017, 09:27 AM   #567
B-R-Z
I love peanut butter
B-R-Z's Avatar
Try Spraymax2k dude. It looks like shop level clear coat
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
nocoolname (07-10-2017)
Old 07-09-2017, 03:22 AM   #568
BlueFR-Ss
BlueFR-Ss's Avatar
Drives: Blue Scion FR-S
Paint or tint Tail light housing
Hey guys what do you think about painting/tinting the chrome housing of the stock jdm tail lights... So the housing will look like a smoked chrome look, with the white reflector on the side of the tail light smoked also...
I want to do this to my car, but mine is Ultramarine. So it would kinda look like this...
BlueFR-Ss is offline   Reply With Quote
The Following User Says Thank You to BlueFR-Ss For This Useful Post:
B-R-Z (07-09-2017)
Old 07-10-2017, 08:14 PM   #569
nocoolname
This. I did the metal cast and spraymax 2k route. I could have mixed some clear and sprayed them but the spraymax is cheaper and easier than mixing some up and cleaning out the gun afterwards. A buddy saw mine and thought I shot the clear with a gun. The trick is spraying wet coats without running.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
The Following User Says Thank You to nocoolname For This Useful Post:
Waffle86 (07-11-2017)
Old 07-11-2017, 12:17 PM   #570
ikuGANO
ikuGANO's Avatar
Drives: 2016
Taking the plunge this weekend to perform this DIY on my car. Is it required to wetsand and polish the taillights at all? I see a few finished products posted by other members that show both clear and hazy tail lights without wetsanding at all...would that be due to improper prepping (cleaning the tails before painting) ?
ikuGANO is offline   Reply With Quote
Old 07-11-2017, 01:12 PM   #571
nocoolname
The haze is usually from not clear coating them. If they've been cleared and are hazy then it's from putting dry coats of clear on. My pictures from above are with clear and no wet sanding. Wet sanding after clear is only needed if there's some dirt in the clear or it's not as slick as you want. I.e. Orange peel or dry spray.
ikuGANO (07-11-2017)
Old 07-11-2017, 02:01 PM   #572
ikuGANO
ikuGANO's Avatar
Drives: 2016
Big thanks for the additional information. I guess the hard part is clear coating them. I'm not too keen on painting or plasti-dipping with aerosol cans. When you're painting the red or clearcoat, are you pressing down on the nozzle intermittently? Or is your finger always held down for the whole duration through each layer you're spraying?
Old 07-11-2017, 03:19 PM   #573
B-R-Z
B-R-Z's Avatar
Clearcoat is not hard with spraymax2k, it sprays like any other spraypaint. I would recommend doing it outdoors no where near any other cars or objects that u care about possibly getting molecules of clear coat on. I also wore a respirator and long sleeves.
People who have commented on mine in person all thought they were either aftermarket or shop sprayed.
Old 07-11-2017, 06:32 PM   #574
B-R-Z
B-R-Z's Avatar
ikuGANO (07-12-2017)
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
