CANADA Canada
Old 07-06-2017, 05:48 PM   #71
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Originally Posted by n0thing View Post
is that not too low for re71r? i run 36psi hot on this same track (-3.2f/-2.4r), and according to the chalk test, its already running on the edge/triangle mark. wish i have access to pyrometer.
Not sure if it would make a difference but I run 31-33 hot with the re71r at -4.1f/-2.5r. Im on 265/35/18, wear is perfectly limited to the triangles
Not sure if tony was on 17" wheels tho so sidewall would be larger?
Canehda is offline   Reply With Quote
Old 07-06-2017, 06:06 PM   #72
laksman91
Drives: BRZ Sport-Tech, Evo X GSR, E92 M3
He's on 18s - 255.
laksman91 is offline   Reply With Quote
Old 07-06-2017, 08:27 PM   #73
Canehda
Canehda's Avatar
Originally Posted by laksman91 View Post
He's on 18s - 255.
yeah so maybe having less sidewall allows you to go less hot tire pressure? idk lol but the low thirties works perf for me
Old 07-12-2017, 06:33 PM   #74
n0thing
Drives: Subaru BRZ
I know pyrometer, which I lack, is preferred to checking tire temperature, but should I even bother with those laser gun?
n0thing is offline   Reply With Quote
Old 07-17-2017, 01:04 PM   #75
Marat
Drives: '15 Ultramarine FR-S
First time out on the track this year, but now with a set of 245/40/17 RS4's and stoptech street pads. Managed to get a 1:24.5.
The RS4's seem to stick better than my old RS3's around corners.
[ame="https://www.youtube.com/watch?v=rlu341RCKhI&t=23s"]FRS laptime - 1 24 5 at Cayuga - YouTube[/ame]
Marat is offline   Reply With Quote
Old 07-17-2017, 01:21 PM   #76
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
It works good enough for me. It at least shows me the difference in temperature across the tire profile.
Remember, the basic key is look for massive differences between the outside and inside temperatures. A pyrometer will get you more accurate readings but the actual absolute number isn't as useful as the delta between the outside and inside profile.
Make sure you hold the laser at the same angle and distance from the tire for the outside and middles to ensure you get as accurate of a reading as possible.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 08-15-2017, 10:18 PM   #77
n0thing
Drives: Subaru BRZ
managed 1:22.8 this time. definitely still room for improvement, should be able to hit 1:21. sry @mabviper, had to borrow your hud
[ame="https://www.youtube.com/watch?v=PHk99TT0N4A"]081317tmp - YouTube[/ame]
Old 08-16-2017, 10:42 AM   #78
mabviper
Drives: WRB BRZ
lol! No problem. The data looks good
mabviper is offline   Reply With Quote
Old 08-16-2017, 06:15 PM   #79
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Stock everything except for
-Nameless track pipe
-Gutted rear interior
-17x8.5 wheels wrapped with Federal RS-R 235/40/17
I can definitely improve my time if I were more ballsy on turn 1 and the last turn into the wall
Cubix is offline   Reply With Quote
Old 08-16-2017, 08:22 PM   #80
n0thing
Drives: Subaru BRZ
yea for those with oft, you can actually pull data like throttle, brake, steering, coolant/oil temp, wheel speed, etc
Old 10-19-2017, 11:09 PM   #81
interna
Hamilton, Ontario
interna's Avatar
Drives: Scion FRS
Finished the season with a 1:25:7. 1:25:5 was possible.
I need to clean up my braking I'm creating too much understeer.
Setup in the description.
interna is offline   Reply With Quote
Old 10-20-2017, 09:23 AM   #82
Frost
Frost's Avatar
Originally Posted by Cubix View Post
1:27.1
My $0.02?
There's likely WAY more time to be had in the infield than the final turn. When you start getting ahead of yourself and only focus on the the last and first turn as places to gain time, you will meet the wall or the field.
Stay safe.
Old 10-27-2017, 02:06 AM   #83
86Tony
Drives: 2015 AOZORA EDITION
Ended my season with a 1:17.95, now to go for that 16s next year
86Tony is offline   Reply With Quote
Old 10-27-2017, 03:29 PM   #84
Canehda
Canehda's Avatar
Tony coming in with the AIM flex... finally a BRZ that's going to give Ramesh a run in street class
Fastest Track Times Thread EAGLE5 Tracking / Autocross / HPDE / Drifting 407 04-17-2026 09:06 AM
NZ Track times diss7 NEW ZEALAND 2 03-03-2014 12:42 AM
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
