CANADA Canada
Old 06-22-2017, 03:30 PM   #57
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Originally Posted by Frost View Post
Setup? Video? I always love watching other people drive the track. I'm a kid in a candy store when people share deets like this... **drool**
I can post the video tonight.
Setup:
RCE Tarmac 2 coilovers
255 40 17 Nitto Nt01
RR racing stage 2 front bbk with Endless ME20 pads
Punched OEM header with OFT stage 2 tune
[ame="https://www.youtube.com/watch?v=bu73YsvQxIg"]2017-06-19 Cayuga - YouTube[/ame]
infinity21 is offline   Reply With Quote
Old 06-22-2017, 04:17 PM   #58
n0thing
Drives: Subaru BRZ
kvw3
245/40r17 re71r
-3.2f/-2.4r
header back with oft stg2
ap sprint w/ dtc30
hold down 3sec trac off
only hit 1:25, I'm definitely doing something wrong...
n0thing is offline   Reply With Quote
Old 06-22-2017, 04:41 PM   #59
wparsons
wparsons's Avatar
Originally Posted by n0thing View Post
kvw3
245/45r17 re71r
-3.2f/-2.4r
ap sprint w/ dtc30
How much experience do you have? Are you analyzing data to see where you're gaining/losing time lap after lap? Have you had someone that knows the track really well point out any places your line is giving up time?
flickr
Old 06-22-2017, 07:41 PM   #60
n0thing
Drives: Subaru BRZ
about 10 lapping days between ddt/tmp. no datalog to analyze other than rewatching my dashcam videos. not sure if this matters much, but i have the kwv3 set at factory setting, +2 clicks up front
here's my 1:25.01 as per HLT, with a passenger, there are some braking zones where i braked too early or too hard, and exits where accelerate too late, especially near the wall. please feel free to criticize.
[ame="https://www.youtube.com/watch?v=a12r163gYFQ"]061117cayuga - YouTube[/ame]
Old 06-22-2017, 09:07 PM   #61
wparsons
wparsons's Avatar
Hard to be super analytical without seeing throttle/brake data, too hard to guess by sounds, but a couple things stand out as some possible areas to gain a bit...
Turn 2 - looks like there's a bit more curb you can use to shorten the path a bit on the inside, also sounds like you brake hard, lift and brake hard again, but it could just be the audio making it sound that way.
Turn 3 - tough to tell, but looks like you brake more than needed and could track out a bit more on exit
Turn 12 - looks like you over brake here too.
flickr
Old 06-22-2017, 10:35 PM   #62
n0thing
Drives: Subaru BRZ
what do you guys use to datalog? i have a bluetooth obd2 dongle paired up with the HLT. or can i use the oft? how do you even extract and interpret the data?
Old 06-22-2017, 10:39 PM   #63
mabviper
Drives: WRB BRZ
You should hit me up when you see me. I have a limited number of daq prototypes I designed. Check out a few of my posts.
Sent from my Pixel XL using Tapatalk
mabviper is offline   Reply With Quote
Old 06-23-2017, 12:01 PM   #64
infinity21
infinity21's Avatar
@n0thing t2 you braked too early and not hard enough. Trail brake into the corner while carrying speed so you're lined up nicely going into t3. You generally seem to be braking too early and not carrying enough speed through corners. Can't see the exact speed but the last corner entry looks slow to me which will really hurt your time.
Old 06-23-2017, 03:39 PM   #65
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I use RaceChrono and a OBD bluetooth dongle. RaceChrono has inherent built in support of the OBDLink MX and LX units.
Is it me or the video is bouncy? Or is that you chopping up the turn?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 06-23-2017, 05:02 PM   #66
n0thing
Drives: Subaru BRZ
I'll be coming by tmr for the alligator lapping at CTMP. Perhaps I'll see some of you guys then.
Old 06-24-2017, 07:07 AM   #67
mabviper
Drives: WRB BRZ
I'll be at ctmp today as well.
Old 06-25-2017, 07:08 AM   #68
86pro
Drives: frs
All of this is news to my ears. Stock frs running 1.23 and full bolt ons running 1.21. Wow. Question. Why is it that there are no official times. I'm not trying to sound like I don't believe you but if you run these times why not run at cscs. 120.7 by tony congrats that's a fast time and hopefully one day we both can be on the track at the same time. And for the rest of the fast na guys keep it up. Would be nice to see more vids like the one above showing 1.22. That's fast for na and the driver should pat himself on the back.
86pro is offline   Reply With Quote
Old 06-26-2017, 12:04 AM   #69
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
tbh the motivation to compete and deal with CSCS is fairly low, OTA is where it's at but sadly their only event at TMP came and went before I had proper brakes for my car
Canehda is offline   Reply With Quote
Old 07-05-2017, 11:00 PM   #70
n0thing
Drives: Subaru BRZ
Originally Posted by 86Tony View Post
they are actually very consistent when running at 30-32psi hot, ive ran them for 10+ laps per session and they never lost bite at all even when they wore down past the wear bar lookin like slicks and even then it still grip. they dont last as long as RS3 but the extra grip is worth it. my tire of choice for now untill something better comes out in a 200TW
is that not too low for re71r? i run 36psi hot on this same track (-3.2f/-2.4r), and according to the chalk test, its already running on the edge/triangle mark. wish i have access to pyrometer.
Fastest Track Times Thread EAGLE5 Tracking / Autocross / HPDE / Drifting 407 04-17-2026 09:06 AM
NZ Track times diss7 NEW ZEALAND 2 03-03-2014 12:42 AM
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
