Old 07-06-2017, 01:38 AM   #71
PulpBrah
Drives: 2014 frs
If you used the supplied grease, then Eric might have some input regarding compatibility.
Either way, the spray-on stuff is better than nothing. I doubt it will last.
Pull it apart. Clean it. Lube it. Put it back together.
*shoots self* this will be fun. What's your recommendation for grease?
PulpBrah is offline   Reply With Quote
Old 07-06-2017, 01:57 AM   #72
That brings us back to the Lucas Red & Tacky #2. It's "equivalent" to the Nichimoly specified in the service manual.
But I have some not-so-good news about it. I cleaned and re-lubed mine last summer. It just started hanging up again last week. I also have to take mine apart again.
Old 07-06-2017, 02:49 AM   #73
PulpBrah
Drives: 2014 frs
Whaaaat? This is ridiculous! Did you retain your original pilot bearing?
Old 07-06-2017, 08:27 AM   #74
Teseo
Drives: frs
Put me in. Mine pedal squeaks like a door of haunted house, but not everytime. Can i spray wd40 to isolate the sounds? I want to make sure its the slave before taking it apart, @Ultramaroon
Old 07-06-2017, 02:08 PM   #75
Pull the top of the fork all the way forward to bottom out the slave piston. Then, before it extends back out, jiggle the hell out of the fork. That will move some shit around in the main pivot.
I'm betting the sound will go away for a few days at least.
Teseo (07-06-2017)
Old 07-06-2017, 02:14 PM   #76
Never touched the actual clutch. Just cleaned, greased, and reassembled the TOB, fork, and related components. I agree. It's shameful but I'll figure out a solution eventually. It's what I do.
Mine isn't creaking yet like it did last summer. The TOB is starting to hang up again where it slides on the transmission input shaft cover. If it gets too bad, that's where it eventually bends the fork.
Old 07-06-2017, 02:26 PM   #77
Teseo
Drives: frs
Also after some driving the sounds disappeared
Old 07-06-2017, 02:42 PM   #78
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
On the Fork-to-TOB, Fork-to-Pivot, Fork-to-Slave, and finally TOB-to-Input Shaft locations, I have always used Sil-Glyde. I was taught this by a master-tech from Toyota when I was an apprentice and worked at a Toyota dealership for 4 years. It seems to do the trick well from my experiences. It is a high-temp silicone lubricant which does very well with temperature/dust/dirt/grime/elements/time/etc.
There are plenty of lubes that you can use that are equal to this and it looks like the Lucas stuff should be good to use as well. I think the big thing is to lubricate all the locations necessary with a decent grease.
I would never use any spray type grease, it doesn't have enough substance to last.
Hope this helps some.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
Bonburner (12-07-2018), PulpBrah (07-06-2017), strat61caster (07-06-2017), Ultramaroon (07-06-2017)
Old 07-06-2017, 02:53 PM   #79
Thanks, man! I will try this stuff specifically and report next year how it's holding up.
VerusEric (07-07-2017)
Old 07-06-2017, 11:07 PM   #80
PulpBrah
Drives: 2014 frs
Interesting. My friend suggested I may have overshot my clutch adjustment when returning it back to normal spec.... I'll give this a try before going in.
Weird Clutch feedback? luelanski Engine, Exhaust, Transmission 5 03-11-2016 12:40 PM
Clutch Failure Ashybone Issues | Warranty | Recalls / TSB 28 08-21-2015 08:43 AM
Clutch failure UMB FR-S Issues | Warranty | Recalls / TSB 30 08-10-2015 05:16 PM
Weird Clutch failure !!! Valentino Engine, Exhaust, Transmission 72 04-19-2015 10:20 PM
weird noise from my clutch stevemp5 Issues | Warranty | Recalls / TSB 3 08-12-2014 04:58 PM
