go_a_way1
Old 07-05-2017, 10:03 PM   #10403
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by j_Zer0 View Post
Woke up to a dead battery this morning (again). My starter battery (PC680 FMJ) is less than a year old, so I'd rather try to trickle charge or maybe jump it than order another one. Only thing is, I'm not sure where to hook up the leads/cables. It doesn't quite make sense to me that I'd hook up cables to the main array terminals given that the dump batteries are in there. I've attached a picture of my battery array and labelled "main positive", "main negative" and "starter negative" (for the starter battery's negative terminal). So where do I hook up leads/cables to either trickle charge or jump? Thanks!
Main negative main positive for a trickle charge. Not for a jump.
Is your led display off when you shut off the car? Meaning does it turn off automatically?
Installed Mods:
Old 07-05-2017, 10:22 PM   #10404
j_Zer0
Drives: Asphalt FRS 2014
My LED display does turn on and off automatically, so I don't think that's what drained my battery. Thanks for the quick response Steve.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
The Following User Says Thank You to j_Zer0 For This Useful Post:
Sojhinn (07-05-2017)
Old 07-15-2017, 01:21 PM   #10405
j_Zer0
ESC quits around WOT
At throttle >= ~75% my ESC quits. I say it quits because there is a noticeable drop-off in torque and the voltage on my LED starts climbing. Partial boost still works great. At ~50% throttle the torque is there and voltage drops, but as soon as I throttle up to ~75% (guessing) no more torque and voltage climbs.
I'm using a fairly linear Procede map (as load and throttle increase so does boost) so I have no idea what is causing the behavior.
Has anyone encountered this before? Any theories? I can log some data if it'll help to see the conditions under which boost cuts out. Thanks.
Old 07-15-2017, 01:22 PM   #10406
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
The final two columns in your procede map need to be full power. You remapped your throttle didn't you?
You can also lower max throttle slightly.
Installed Mods:
Old 07-15-2017, 01:33 PM   #10407
j_Zer0
I'll have to check my Procede map. Haven't messed with that stuff in almost 2 years. Thanks for the suggestion. I'll let you know how it goes.
Old 07-15-2017, 05:03 PM   #10408
j_Zer0
Calibrated my throttle as per @KoolBRZ's instructions in the Procede thread (mine is now sitting at 170 - 890). With the pedal all the way down load is 92% and I'm in the 90 column on my map. But no change. I still have no boost up high (from the 70 column and up). I'll post my Procede map in the Procede forum.
Old 07-18-2017, 01:31 AM   #10409
j_Zer0
Best way to Contact Rob?
What's the best way to contact Rob? Just PM @Robftss? Or does he have an email? Looks like the Phantom website isn't up any more.
Old 07-18-2017, 03:52 AM   #10410
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I don't know the best way, but the way I would try involves some candles, and salt laid out in a pentagram, and drizzled with the blood of the innocent.
*edit, sorry if my reply got your hopes up, It hasn't worked for me yet either. Maybe kids under 6 would be a better catalyst.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
Tcoat (07-18-2017)
Old 07-18-2017, 11:38 AM   #10411
j_Zer0
That's what I was afraid of. I've got an issue with my ESC (controller issue seems like) and I'm stuck until I can summon Rob. As good as the ESC is, given the experimental, one-man-show nature of the thing the downside comes when your unit eventually needs service.
Sent from my Nexus 5X using Tapatalk
Old 07-19-2017, 12:56 AM   #10412
BuffDriver
Drives: 2016 Subaru BRZ
I also wondered who is maintaining the list now Fenton is out...
I had asked to be put on the list but never heard back.
Still willing to take the chance that one day production might be enough that I have my chance to get one.
BUT, I know how dreams work in the real world...
I used to be in aviation (A&P mech) and during the last 45 years have seen many extraordinary / great planes that people designed and built and displayed thru the Experimental Aircraft Association and Sportplane community. Designer builders would attempt to produce kits for people to build their own (as per FAA regs described here for example https://www.eaa.org/en/eaa/aviation-...efore-building ) and some would take deposits of $2000.00 up to one kit which was $40,000.00 ... and about 95% of those people lost their money whe the developer just got out of their ability to go into production.
However, a lot DID succeed and today there are 50 or so kit planes that are actually in production. According to the 2017 June numbers there are 35,300 Experimental / Light sport planes flying and most of these were kit built.
So there IS hope the Phantom may "get off the ground" and everyone who wants one will be able to buy one but I / we have to be realistic too. At least we are not being asked to put down deposits.
However, I, as others have said here too, would put down a deposit of $500.00 in a heartbeat, even knowing the odds of eventually losing it!!!!
Sent a PM to Fenton the day he listed his but was too late. Maybe next time...
I just don't want a turbocharger. Right now I am grudging looking at other supercharger systems but they all don't do what I want. The Phantom does / will. Someone IS going to produce something like this, probably out of China, Ha Ha because the demand is there for lots of platforms, not just ours.
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
Old 07-19-2017, 01:14 AM   #10413
TM
TM's Avatar
Drives: DGM BRZ 6MT
Send him an email. Rob doesn't usually reply to my pms, but he always replied to my emails in a day or less when I needed help. I had servicing done 2-3 times (round trip shipments) along with some additional components sent to me over the past 4 years. Always quickly resolved.
Email him
TM is offline   Reply With Quote
Old 07-19-2017, 01:47 AM   #10414
j_Zer0
Email him
Wish I had Rob's email Could someone please PM it to me? Thanks!
Old 07-22-2017, 06:20 PM   #10415
j_Zer0
Just wanted to share the resolution to my issue (partial boost was working, but full boost wasn't). Rob thought it was being caused by drained dump batteries (full boost requires more voltage than partial) and suggested I charge them. I hooked up my dump batteries to a charger, but found them already fully-charged. As a last resort I ordered new dump batteries (mine WERE 2 years old -- maybe they weren't dumping all that well any more). If nothing else I could rule-out dump batteries as the cause. But as soon as the new batteries were in, full boost was back. Again, mine started failing right around the 2 year mark, so if you start to notice boost dropping off above 5K RPMs check your dump batteries.
Thanks to Sojhinn, Rob and TM for helping me find my way to the solution.
The Following 2 Users Say Thank You to j_Zer0 For This Useful Post:
DAEMANO (07-28-2017), Sojhinn (07-22-2017)
Old 07-24-2017, 08:41 PM   #10416
predator800
Drives: 2015 Scion FRS
waiting list
If no one is taking care of the list besides Rob, I can volunteer to maintain it. I don't live in Calgary but do live 6 hours away in Regina. I don't have Rob's email address so I thought I would just put it out there.
predator800 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
