Old 07-05-2017, 05:53 PM   #43
Originally Posted by nikitopo View Post
Or not so much for race cars
Beats a coke habit.
strat61caster (07-06-2017)
Old 07-05-2017, 07:24 PM   #44
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I haven't figured out yet if this guy did it on purpose or by mistake. I was reading somewhere that he was trying that day to get used to the right-hand drive position:
On the other side, it is a bit bizarre to miss shift by accident and manage to make a lap record.
Well this JDM model has an 8000rpm redline unlike the export model.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
nikitopo (07-06-2017)
Old 07-05-2017, 07:31 PM   #45
krayzie
Drive From Home
krayzie's Avatar
BTW I've watched enough Best Motoring on VHS where Gansan always overrevs his downshifts well into the red zone when driving flat out on Honda's Takasu test track.
Then again it was always a factory press car / prototype.
OP don't worry my friend money shifted his RSX-S from 5th to 2nd and hit 9000rpm one time while trying to chase an S2K onto the highway ramp. Car still runs like a champ over 10 years later.
These days I tend mis-downshift from 4th to 5th instead of 3rd when driving a little hard.
Irace86.2.0 (07-06-2017)
Old 07-06-2017, 01:58 AM   #46
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are you sure? Max output is @6400 RPM. I would expect redline to be at 7000 RPM.
Sometimes we are over-sensitive after experience with American or European cars. I was watching lately a German guy reviewing the STI and he was saying ... "This is a real engine, you can overrev well into the red zone. Don't do this with a German car!"
The Following User Says Thank You to nikitopo For This Useful Post:
krayzie (07-06-2017)
Old 07-06-2017, 02:46 AM   #47
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Ah, you're fine. Even Shiv's Open Flash canned tunes replace factory rev limit at 7400 with a soft cut at around 7800-ish. I don't remember exact numbers but it's a significant increase.
61 mph in second gear, don't know what rpm that is but I'm sure you can plug it into a calculator and work it out for me, it's past my bedtime.
While the FA20 is proving to be pretty stout, it ain't no 80's-90's Honda engineering.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
krayzie (07-06-2017), Ultramaroon (07-06-2017)
Old 07-06-2017, 03:07 AM   #48
krayzie
Drive From Home
krayzie's Avatar
Something like this with the EJ20
Old 07-06-2017, 03:10 AM   #49
krayzie
Drive From Home
krayzie's Avatar
You are right those Honda engines can rev half way into the red zone while the FA20 chokes right at the redline.
Old 07-06-2017, 09:53 AM   #50
skkk
Drives: 2022 BRZ Sport-Tech
So like FA20 is so easy to get blown?
skkk is offline   Reply With Quote
Old 07-06-2017, 12:15 PM   #51
strat61caster
It chokes about three hundred rpm before the redline, after that it drops off. The hard rev limiter is deceiving, like mentioned earlier in this thread many aftermarket tunes raise the rev limiter a bit and it feels much better to sail up to that 7.4k mark without fear of hitting the wall.
ineedyourdiddly
Old 07-06-2017, 12:59 PM   #52
No. It is just that they are an interference type engine. This means the when the valves are open they are extended into the cylinder where the piston travels. Not an issue unless your timing goes off (badly) or the valve doesn't retract fast enough when the piston comes back up (well sideways in this case). During a SEVERE over rev the springs that return the valves may be slower than the cylinder speed so they can hit each other and cause all sorts of damage. There are other things that can happen as well but this is what raises the risk with the boxer.
As said many times a small over rev is not likely to cause a problem but you bring it up too far too fast and things can go bad.
Old 07-06-2017, 02:45 PM   #53
I suck at math.
Astroboy (07-06-2017)
Old 07-06-2017, 02:51 PM   #54
strat61caster
I suck at math.
Ugh, fine. As a fellow engineer I will counter you by doing no math either and instead looking it up.
7,600 per Shiv.
http://www.ft86club.com/forums/showp...79&postcount=3
ineedyourdiddly
Tcoat (07-06-2017)
Old 07-06-2017, 03:00 PM   #55
7,600 per Shiv.
lolol
I did a spit take with my coffee. #winning
strat61caster (07-06-2017), Tcoat (07-06-2017)
Old 07-06-2017, 03:03 PM   #56
strat61caster
lolol
Looks like I've peaked my forum game for the day, I'm out.
ineedyourdiddly
FS. Case of 12 Redline D6 ATF FastWhite Mechanical Maintenance and Tools 0 12-07-2015 12:59 AM
Redline 360 Review z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 3 07-26-2014 07:41 AM
Redline 360 z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 2 07-17-2014 09:49 AM
FS: Redline MT-90 BMWDavid Transmission and Driveline 3 01-07-2014 08:52 AM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
