Old 07-04-2017, 01:22 AM   #1
skkk
Drives: 2022 BRZ Sport-Tech
Exclamation Misdownshifted from 3rd to 2nd and over the redline
So I just now was going to upshift to 4th, but I misdownshifted to the 2nd at 93-98km/h. The revved just passed the redline like about 7700, 7800rpm...
That that gonna cause a huge damage for the engine and the clutch?
skkk is offline   Reply With Quote
Old 07-04-2017, 01:35 AM   #2
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
If I rev mine out to the limiter in 2nd I am at 98km/hr indicated. If you truly were doing 93 - 98 when you inadvertently went into second, I don't see how you over revved?
Michael.
Subsonic is offline   Reply With Quote
Old 07-04-2017, 01:48 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's totaled. Time to buy another car. I suggest a new Honda Civic in auto.
If you keep driving it, the clutch is going to brake and go through floor board and cut off your manly bits.
Lucky for you I'll gladly take that death trap of a car. I'll even give you $300 for your troubles.
The Following 3 Users Say Thank You to Mr.ac For This Useful Post:
funwheeldrive (07-04-2017), TheRoops (07-05-2017), wparsons (07-06-2017)
Old 07-04-2017, 01:48 AM   #4
skkk
Michael.
I was just so scared... I cant really remember exactly how fast was that, but I just remember the rev was over the redline like couple hundreds... I'm just currently so worried about the engine and clutch if they are damaged...
Old 07-04-2017, 09:17 AM   #5
StraightOuttaCanadaEh
Wes
nah no damage. If you misshift from 5th to 2nd, now that might be a problem
Old 07-04-2017, 09:39 AM   #6
Couple of hundred is not a big deal. Just don't keep doing it. Odds are if you damaged anything you would already know it. Damage caused by a serious over rev is usually (not always but most of the time) immediate and extreme. I wouldn't be worried at all.
guybo (07-04-2017), Psilox (07-04-2017), strat61caster (07-06-2017), wparsons (07-06-2017)
Old 07-04-2017, 09:50 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
No need to worry. Keep enjoying your car.
Old 07-04-2017, 10:41 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That's called a money shift. Usually after you do that, you end up spending a lot of money to fix it. If it's driving fine, no problems and nothing happened after- you got lucky. Don't do it again
The Following User Says Thank You to guybo For This Useful Post:
jcw99 (07-04-2017)
Old 07-04-2017, 11:28 AM   #9
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Did you try to press the clutch as soon as you heard it start to over rev?
dinfern22 is offline   Reply With Quote
Old 07-04-2017, 05:09 PM   #10
skkk
It's still fine for now... luckily... thanks btw!
Old 07-04-2017, 05:10 PM   #11
skkk
I did not... cause it just hit like slightly above the redline and then it dropped under the redline right away. I'm just so worried about it.
Old 07-04-2017, 05:53 PM   #12
dinfern22
dinfern22's Avatar
How do you manage to drop it into 2nd gear, were you aggressively driving? 4th gear from 3rd should be a short downward movement, especially on this car.
Old 07-04-2017, 06:20 PM   #13
navanodd
Drives: 2013 BRZ Sport-tech WRB
Michael.
Without actually checking the ratios, I'd say this speed is reasonable for a slight over-rev with the shorter final drive of the 2017.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Subsonic (07-04-2017)
Old 07-04-2017, 06:32 PM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Different members mentioned an occasional mis-shift. I haven't heard anyone to have problems afterwards. In fact the chances after a mis-shift are to have an accident (you lose traction), than to have issues with the engine.
FS. Case of 12 Redline D6 ATF FastWhite Mechanical Maintenance and Tools 0 12-07-2015 01:59 AM
Redline 360 Review z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 3 07-26-2014 08:41 AM
Redline 360 z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 2 07-17-2014 10:49 AM
FS: Redline MT-90 BMWDavid Transmission and Driveline 3 01-07-2014 09:52 AM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 03:12 PM
