Old 07-05-2017, 02:57 PM   #15
wparsons
wparsons's Avatar
The two alternatives mentioned a lot but may not be easily available in your country are Ferodo DS2500 and Carbotech XP8 which I believe are comparable to HC800+, I don't really know how well the Hawk's would compare.
I'd suggest G-Loc R8's over Carbotech XP8's, they're functionally basically the same but G-Loc is owned and operated by the brother's that were behind Carbotech originally.
As for the R8's, they're a bit more aggressive than the DS2500 or HC800+.
I've personally been DDing R10's, but they might be too noisy for other people. They only make noise at really light brake applications, if you're pressing harder they're silent.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
pym19109 (07-06-2017), strat61caster (07-05-2017)
Old 07-05-2017, 03:56 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Lynxis View Post
A lot of people complain about fade on the OEM system and most of it can be attributed to the OEM brake fluid. If you don't want to spend an arm and a leg, Motul RBF600 is a good place to start but you may have to perform partial bleeds after any track days with this fluid so make sure you've got an extra bottle for that. If you don't want to do partial bleeds periodically then Torque RT700 or Castrol React SRF are great but expensive.
Ooops, forgot to mention this but it's explicit in the 'track prep your car' thread I linked.
I just switched to ATE Typ 200 (used to be known as ATE Superblue) as I'm not headed to the track anytime soon just autocross but that's probably a good place to start since it's half the cost of Motul and a quarter of the cost of the Castrol SRF.
The only reason I didn't mention G-Loc is because he's in Thailand there may not be a good supply chain yet, but definitely my next pad is going to be G-Loc. Your experience on the R10's is exactly what I experienced on the XP10's, I was hoping the R8/XP8 would be a step down from that and a bit more streetable as such, but I may be wrong. I could not DD the XP10 unless I was able to get them bedded in or at least up to operating temperature once a week, which I never felt comfortable doing on the street.
Edit: The XP10's performed great on the street (and autocross) but were just too noisy and I got tired of switching pads for autox since my OE ones were junk. Went for a 'sporty street pad' (Mu NS400) and I can fade it on a big autox course so G-Loc R6 is on my shopping list as soon as I kill these pads.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Lynxis (07-05-2017), pym19109 (07-06-2017), wparsons (07-05-2017)
Old 07-05-2017, 06:31 PM   #17
stevesnj
stevesnj's Avatar
Winmax W2's do make noise when cold not bad and lasts a few min only, flush fluid with high performance fluid also. You'll be surprised the night and day difference even on the street.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Old 07-05-2017, 08:27 PM   #18
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
Once you start leaning on the brakes you might like to consider 2 sets of pads: one for street and one for track. Swapping them out is a painless choir that can be done the day before you go to the track.
Hey Captain, I quoted your post because I'll be doing my first track day in my 86GTS soon, and want a pad that I can swap out with my DD OEM set. I guess I'm looking for a compatible pad that works at the higher temps I'll see at Wakefield park. Since we're in the same country, what do you use for this purpose and where do you get them?
Only recent experience I've had with race brakes are the EBC Green Stuff pads on my Clubman. They are fine on the track but my clubbie doesn't tax the brakes too much given it's so light.
Keen to hear of your local experience for pads for the 86 and maybe a fluid too?
cheers,
Michael.
Subsonic is offline   Reply With Quote
The Following User Says Thank You to Subsonic For This Useful Post:
Old 07-05-2017, 10:50 PM   #19
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Subsonic View Post
cheers,
Michael.
Pm sent.
Subsonic (07-06-2017)
Old 07-06-2017, 01:05 AM   #20
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
Thanks everyone for useful information
pym19109 is offline   Reply With Quote
The Following User Says Thank You to pym19109 For This Useful Post:
stevesnj (07-06-2017)
Old 09-13-2018, 07:26 PM   #21
Seiryuu
Drives: ZC6
Motul RBF600 is a good place to start but you may have to perform partial bleeds after any track days with this fluid so make sure you've got an extra bottle for that. .
I think I've come across that statement a few times but never really understood why. How come we have to partial bleed after any track day with the RBF600?
I am researching a lot on brake pads and fluids to prepare for my first autocross and track day down the road. I've been reading so much material that it is getting all over the place in my head.
Seiryuu is offline   Reply With Quote
The Following User Says Thank You to Seiryuu For This Useful Post:
norcalpb (09-13-2018)
Old 09-13-2018, 09:29 PM   #22
CSG Mike
CSG Mike's Avatar
Because it degrades and your pedal gets soft, even with a novice driver. It's better than stock, but not as good as the nicer stuff.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
DylanJZA (06-30-2022), Lynxis (09-13-2018), Seiryuu (09-14-2018)
Old 09-13-2018, 10:26 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Even with me being novice driver RBF660 with which i started, lasted longer. Imho it's worth paying for "nicer stuff". Hybrid pads on stock brakes were bottleneck rather then fluid. If anything, less frequent bleeds for better fluids imho will more then offset higher price, so see no reason to not fill with those from get go.
CSG Mike (09-14-2018)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
