#29 |
Drive From Home
Drives: BRZ STI Performance
IIRC there was a post on Temple of Vtec a long time ago where somebody's Razo shift knob cracked and the dude money shifted into 2nd gear and hit 11,000rpm. The engine survived but the gearbox blew.
| The Following 2 Users Say Thank You to krayzie For This Useful Post: | Irace86.2.0 (07-05-2017), Tcoat (07-05-2017) |
#30 |
Drives: '15 BRZ RA
#31 | |
I just used the 1,000 rpm as a sort of place holder number. You could go over 1,000 or 10,000 a hundred times with no issue or you could blow things apart at 950 the first time you did it. It isn't an exact science. I miss shifted a drag set up Pinto once. The engine survived fine, the tranny had some minor damage and the u-joints all but blew apart. As far as the OP here goes he is fine.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | krayzie (07-05-2017), Ultramaroon (07-05-2017) |
#32 |
Drives: 2013 FR-S 10 series [755]
It is called money shift..sounds so Gangster....
I think you are fine if you don't do it all the time... plus, it is very hard to mis-shift from 3rd to 4th....little more practice, yeah? |
#33 |
I believe, for the fa20, the weak link from an acute over-rev is between the wrist pin and piston. The holes stretch and give up the ghost. It has been covered here a few times.
Which astonishes me considering the floofiness of the valve springs. The valves must be super light.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (07-05-2017) |
#34 |
Drives: Q5 + BRZ + M796
Yea. Even a thousand bro. Sent from my iPhone using Tapatalk
#35 | |
Holes stretch? From force or heat/friction? Acute overheating would cause metal expansion, right, and lubricants to heat to dangerously thin levels resulting in metal on metal contact? If that is what we are talking about then could that much heat really occur in a second or two max? I can't see it happening. Sent from my iPhone using Tapatalk
#36 | |
#37 |
Tell 'ya what. Why don't you just go out and make some videos of a few miss shifts at just 1,000 rpms over redline. Just a dozen or so would satisfy me that everything I have know and experienced about over revs is totally wrong. Hell you really want to convince me then do a couple at only 2,000 over since that should be fine as well.
#38 | |
Drives: 2015 BRZ Limited
#39 | |
Drives: '15 BRZ RA
![]() On the other side, it is a bit bizarre to miss shift by accident and manage to make a lap record. |
#40 | |
#41 | |
The rest is, as they say, expensive.
#42 |
Drives: '15 BRZ RA
| The Following User Says Thank You to nikitopo For This Useful Post: | Ultramaroon (07-05-2017) |
| FS. Case of 12 Redline D6 ATF | FastWhite | Mechanical Maintenance and Tools | 0 | 12-07-2015 12:59 AM |
| Redline 360 Review | z3ro | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 07-26-2014 07:41 AM |
| Redline 360 | z3ro | User/Vendor/Sponsor Reviews, Feedback, Comments | 2 | 07-17-2014 09:49 AM |
| FS: Redline MT-90 | BMWDavid | Transmission and Driveline | 3 | 01-07-2014 08:52 AM |
| redline | kendalldwhite | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-26-2012 02:12 PM |
