Old 07-04-2017, 02:18 PM   #15
Just don't do it too often as you'll run out of oil..
That's how I do my oil changes.
pfaffendorn (07-05-2017), Sportsguy83 (07-05-2017)
Old 07-04-2017, 02:33 PM   #16
JD001
JD001's Avatar
Drives: Subaru BRZ
I do the same, but it's such a chore when refilling with new oil. I'm sure some bright spark on this forum will find a quicker way of changing oil.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
pfaffendorn (07-05-2017), Ultramaroon (07-04-2017)
Old 07-04-2017, 02:45 PM   #17
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Yeah it is very hard to read accurately.
+1 to using some sandpaper or scotch-brite to rough up and scour some lines. It makes it a bit better at least. If I recall correctly, you are supposed to read your oil once the car is fully warmed up and has sat for 5 minutes turned off on a level surface to get the most accurate reading.
I check mine at every other fill up, and its usually perfect timing to check the oil level right at the end of my fill up.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 07-04-2017, 03:26 PM   #18
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I just hold the end of dipstick up to whatever light source I have. The light reflects better off the oil than the metal. You should see a line going across the dipstick. If you don't, then your oil is likely low.
Also, pull, wipe, insert, pull, check, wipe, insert is my method as well.
The Following User Says Thank You to Spuds For This Useful Post:
Old 07-04-2017, 03:33 PM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
I am sensing a consensus forming on this thread.. common goal and technique converging on the common dip stick.. only wish other threads were as united in thought and harmony.
Old 07-04-2017, 03:39 PM   #20
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
There does seem to be plenty of dip sticks on here.
Scrappydoo is offline   Reply With Quote
The Following 6 Users Say Thank You to Scrappydoo For This Useful Post:
Drakiv (07-05-2017), gravitylover (07-08-2017), JD001 (07-04-2017), pfaffendorn (07-05-2017), Tcoat (07-04-2017)
Old 07-04-2017, 03:45 PM   #21
I am not totally convinced we are still talking about checking oil here though.
JD001 (07-04-2017), pfaffendorn (07-05-2017), Spuds (07-04-2017)
Old 07-04-2017, 03:50 PM   #22
JD001
JD001's Avatar
Drives: Subaru BRZ
We are talking, lubrication, sticks, dipping and wiping?? What's rocking in your head Tcoat? Just lay down on the couch and spill all..
Old 07-04-2017, 03:52 PM   #23
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
He is trying, just give him time.
And don't look, it'll put him off.
The Following 3 Users Say Thank You to Scrappydoo For This Useful Post:
JD001 (07-04-2017), pfaffendorn (07-05-2017), Ultramaroon (07-04-2017)
Old 07-04-2017, 05:43 PM   #24
From an efficiency standpoint an argument could be made that the second wipe is redundant.
JD001 (07-05-2017), pfaffendorn (07-05-2017)
Old 07-04-2017, 06:00 PM   #25
Spuds
The Dictater
Spuds's Avatar
From an OCD standpoint an argument could be made that second wipe is absolutely necessary.
JK, I just do it because Im already holding the tip steady with the paper towel/rag/etc. And habit. And less chance for the oil to drip on hot things. I swear there is some logical reason for it...
ChristineAlexa (10-22-2017), pfaffendorn (07-05-2017)
Old 07-04-2017, 11:33 PM   #26
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
Nooooo. That second wipe wastes oil! That is why you have to overfill!
Silver Supra is offline   Reply With Quote
The Following 2 Users Say Thank You to Silver Supra For This Useful Post:
pfaffendorn (07-05-2017), Scrappydoo (07-05-2017)
Old 07-05-2017, 12:29 AM   #27
Another voice of reason. Thank you.
Old 07-05-2017, 01:08 AM   #28
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Pull dipstick, wipe (obviously) then put in and give it a moment then pull it out and check BOTH sides of the dipstick. If your not sure then just repeat and maybe put the dipstick in again and repeat. I'm a paranoid dude and I check my dipstick 2-3 times, but then you know.
The car runs better in general if the oil level is at the half point or quarter point. Try not to over fill and if you do avoid reving her up too much until your next oil change.
Also if you drive your car with spirit like I do then you fall under "extreme" conditions and you should change your oil every 3700 roughly (check the manual that's what it says). Also if you use OEM oil filters here is a great site suggested in other threads for a good deal, like $6 an oil filter. http://www.subarugenuineparts.com
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 06:44 PM
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 06:24 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 01:10 PM
