Member's Car Journals Car journals by our members. |
07-04-2017, 12:23 PM | #771 | |
Drives: Sterling BRZ Ltd
My cooler flange looks just like the photos posted above. If you want it its yours. I did damage the center bolt thing as I didn't have an allen big enough, I bet you can just reuse yours.
07-04-2017, 01:15 PM | #772 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Thanks for the quick come back!
That flange is such a pain. But I might be able to make better use of the straight tube configuration. I don't have a spare coupler bolt. Just the one that comes with the $140 Boss kit. I can get another bolt for $12 or so. Normally the bolt comes with the cooler for a total of about $95 shipped for the best on-line Ford price. My commercial address zip 75088. What do want for the cooler shipped to me? I can process the order through your website if you tell me how. Or I can just mail you a check to keep costs at a minimum. I'm not in a hurry, as I must finish healing from last week's gut surgery before I bend over a fender in the garage. A couple of weeks. |
07-04-2017, 01:36 PM | #773 |
PM'd
07-04-2017, 01:52 PM | #774 |
Pretty impressive these stock manifolds flow over 300hp, still need to go.
The last test fit showed the pan still needed trimming, this is all I can take out of it so have to make it work from here.
07-08-2017, 07:54 PM | #775 |
Shaved a few inches and gained a mile
The Following User Says Thank You to mrk1 For This Useful Post: | solidONE (07-10-2017) |
07-22-2017, 07:54 PM | #777 |
With the motor in place its obvious the factory clutch master wont work at all. I made the call to ditch the stock brake setup in favor of a manual non ABS setup.
I made a mockup bracket to mount both the brake and clutch master cylinders. A pair of Tilton master cylinders will do the trick. With the clutch master now moved over about 5" I had to dissect the pedal box and shorten that 5" to match.
The Following User Says Thank You to mrk1 For This Useful Post: | zeal86 (07-22-2017) |
07-23-2017, 05:32 PM | #778 |
New motor won't let me run a normal strut brace so I came up with these WRC inspired supports.
07-24-2017, 10:17 AM | #779 |
Drives: 2013 Ultramarine FR-S
Thought about getting rid of ABS as well. Doesn't work on my car anyway haha. Really enjoying these updates. Looks great as always.
07-24-2017, 10:32 AM | #780 |
Only users lose drugs.
Drives: All the time
Clean work.
The Following User Says Thank You to venturaII For This Useful Post: | mrk1 (07-24-2017) |
07-24-2017, 04:47 PM | #781 |
Driver
Drives: 16 Subaru BRZ
pretty nice man, keep it up.
BRZ Build Thread
See you space cowboy... |
The Following User Says Thank You to EdBoy For This Useful Post: | mrk1 (07-24-2017) |
07-24-2017, 06:34 PM | #782 |
So much clutter, if it wont work no sense in keeping it around.
The Following User Says Thank You to mrk1 For This Useful Post: | DustinS (07-25-2017) |
Similar Threads | ||||
AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 07:45 PM |
86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 11:53 AM |
