Old 07-03-2017, 04:51 PM   #71
Racecomp Engineering
Oh no he's banned.
Originally Posted by HappyMonkey View Post
So it's looking like every initial decision I made was significantly suboptimal. Throwing money away is one way to learn...
From what I've been reading the Hawk High Performance Street Race pads are a little more street friendly than the Project Mu HC+ 800 ones. Leaning toward the Hawk until I swap out dedicated track pads.
For fluid I'm using ATE Typ200. No idea how I decided on it. Sounds like everyone uses Motul RBF600. I might as well join the club too.
Basically what you bought was a fine street maintenance replacement package. Really no improvement over stock, but they're not "bad" parts (drilled rotors don't do it for me though). I run some of the same parts on my street cars. Keep them as a back up or run them as your street set-up. In general I recommend a separate set of dedicated track pads...if nothing else it gives you a chance to inspect your car and braking system before a track day which everyone should be doing anyway. A separate set of track rotors makes life easier too.
Lots of good brake pad information and reviews on here. CSG has a lot of info and there's more in the track forum.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG David (07-03-2017), HappyMonkey (07-07-2017), wparsons (07-03-2017)
Old 07-03-2017, 07:30 PM   #72
churchx
churchx's Avatar
Drives: 2014 GT86
HappyMonkey: i'd strike out "significantly". It's not some race BBK kit for $10K . In few trackdays you'll burn more fuel & wear tires then what your purchase did cost. Yes, not much difference over stock .. but then again imho even stock brakes are relatively rather good on twins. You get spares, good enough. Stock rotors/pads may cost even more then some aftermarket offerings .
BTW, next thing i suggest to read a bit on alignment. At least that was what i felt that may benefit from changing after first track visits. But worth to go to track first to feel yourself if/what/how much improve.
The Following 4 Users Say Thank You to churchx For This Useful Post:
HappyMonkey (07-07-2017), strat61caster (07-07-2017), Tcoat (07-07-2017), wparsons (07-03-2017)
Old 07-03-2017, 08:53 PM   #73
wparsons
wparsons's Avatar
Oh no he's banned.
- Andrew
Just to add a little to that... if you're planning on swapping pads, but not rotors, be sure to get pads that are compatible with each other to minimize the amount of bedding needed between swaps.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (07-04-2017), Racecomp Engineering (07-03-2017)
Old 07-07-2017, 10:37 AM   #74
HappyMonkey
HappyMonkey's Avatar
Drives: 2013 Subaru BRZ Limited WRC Blue
Thanks for all the comments. I learned a lot more than I expected to when I posted the questions. Before I go back to stock rotors here's a goodbye photo of the slotted/drilled ones.
HappyMonkey is offline   Reply With Quote
The Following User Says Thank You to HappyMonkey For This Useful Post:
Tcoat (07-07-2017)
Old 07-07-2017, 01:11 PM   #75
CSG David
CSG David's Avatar
Crack em first for good faith.
The Following User Says Thank You to CSG David For This Useful Post:
Icecreamtruk (07-07-2017)
Old 07-07-2017, 01:19 PM   #76
HappyMonkey
She going to the track on the 19th and 27th. The plan is to run these ones on the 19th and the OEM ones on the 27th. I'll do my best to crack these on the 19th. I'll definitely report back if I pull it off.
Old 07-07-2017, 01:22 PM   #77
HappyMonkey
Also, if anyone is curious I used the G2 High Temperature Brake Caliper Paint System Set Blue G2162 on the calipers. It's not a perfect match but close enough that I'm happy with it.
Here's the unedited straight from the camera version of that photo showing the true colors a little better.
Old 07-07-2017, 01:34 PM   #78
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
fwiw since this thread is back on track the ATE fluid is a good choice for beginners imo, especially at half the cost of motul, I just switched to it myself (but not for track duty). It's the preferred fluid for casual Miata track guys last I checked (light cars = less brake heat) my roommate ran it in his NC with no issue, but we're solidly amateurs.
I've read people who run it will sometimes bleed the brakes between track sessions, which seems silly to me, but that's likely the worst case scenario for you HappyMonkey, but I bet the stoptech pads fade first unless you've changed your mind on those.
ineedyourdiddly
Old 07-07-2017, 02:10 PM   #79
HappyMonkey
Yes, I gave up on those and went with the Hawk High Performance Street/Race pads instead. They have good reviews as a compromise street/track pad and they're compatible with Hawk DTC-* line when I decide to go with a dedicated track set.
Old 07-07-2017, 02:29 PM   #80
Icecreamtruk
Drives: Track preped NA FRS
Street/race will work well for you, its no DTC-60, but its close enough and doesnt squeal like a dying pig on the street. I have run them both, and I can get away with 1 cooldown lap every 5 or 6 laps and no fade. This is being very rough on the brakes tho, enough to make them smoke hard when I come off the track (meaning I get to do parade laps around the pit area to cool them down). DTC-60s are better, but street/race is still very good.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
brakes, rotors, temperature
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
ACE vs. OEM Header - Temperature Comparison R2 Engine, Exhaust, Transmission 26 09-25-2017 01:13 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! FRSport.com Brakes, Suspension, Chassis 0 07-08-2016 07:14 PM
