Old 06-26-2017, 01:49 AM   #813
zeal86
zeal86's Avatar
Drives:
So now that I'm done with the door strap pull project I should be moving on to blasting and polishing the '17 red intake manifold... however, I need to address my side markers which have suffered from the dreaded shitty A-clip issue.
I'm going to pull my wheels off to gain more access... I am thinking of pushing the side marker into place and marking the tab that once held the A-clip on the other side of the opening it inserts into. Then I will drill a hole on the mark big enough to pass a cotter key through. I'll have to pull back the wheel well liner but I think I will have access to the cotter key hole. As long as I drill the hole really close to the edge of the opening, the cotter key should hold the side marker in tight.
I will find out if my course of action will be successful soon.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-27-2017, 02:11 PM   #814
zeal86
zeal86's Avatar
Drives:
So I backed up and deleted all the images I had stored on Photobucket. Those links are forever dead... I am going to slowly reinsert images starting from the beginning of this thread...
Going to take a while being that this thread will be 3 years old in October (I think) . Please bare with me during the process.
Anything new I post will be hosted by Imgur.
FU Photobucket for making me use my already limited free time to fix the images in my thread.
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
DustinS (06-27-2017), Michael (07-02-2017), new2subaru (06-27-2017)
Old 06-27-2017, 07:26 PM   #815
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Dude! Who did the door toggle?! That's sick!
Sent from my SAMSUNG-SM-G891A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 06-27-2017, 07:33 PM   #816
zeal86
zeal86's Avatar
Drives:
As a matter of fact... I made it...
https://www.instagram.com/p/BVmiiANgJh0/
https://www.instagram.com/p/BVvj9cpAJmn/
Old 06-27-2017, 07:37 PM   #817
batlwagn
Bro, so much win. Seriously you need to stop because you're killing the game. Lol
ALL THE MODS!!
The Following 2 Users Say Thank You to batlwagn For This Useful Post:
Bramick (06-28-2017), zeal86 (06-27-2017)
Old 07-01-2017, 06:16 PM   #818
zeal86
zeal86's Avatar
Drives:
Check out my DIY for fixing a loose sidemarker due to a broken or missing A-clip...
http://www.ft86club.com/forums/showthread.php?t=119974
Old 07-01-2017, 07:57 PM   #819
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'll probably do this. Aftermarket markers just wont stay
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zeal86 (07-01-2017)
Old 07-02-2017, 04:33 PM   #820
zeal86
zeal86's Avatar
Drives:
Well... I had a change of heart... I'm not going to blast and polish the '17 OEM red intake manifold... it is staying red. I plan on polishing the Velox fuel rail brackets instead.
I'll fabricate a cover for the '17 OEM red intake manifold instead that I will polish to create some contrast between the manifold, fuel rails, and fuel rail brackets.
I'm currently looking over the installation manual and the OEM maintenance manual to make sure I understand all instructions and I will have everything I'll need for the installs.
I may be able to get to it on the 4th. We'll see... I'll have to get the fuel rail brackets polished before then. Shouldn't be too bad though... they are quite small.
stay tuned...
The Following User Says Thank You to zeal86 For This Useful Post:
weederr33 (07-02-2017)
Old 07-03-2017, 12:34 AM   #821
zeal86
zeal86's Avatar
Drives:
Did a mini shoot today... more to come...
Boy do those Brides add so much to an exterior shot!
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Majik (07-03-2017), spike021 (07-03-2017)
Old 07-03-2017, 03:55 AM   #822
spike021
spike021's Avatar
stay tuned...
Definitely interested in seeing how this goes. Curious about the process of retrofitting it on your older car.
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
zeal86 (07-03-2017)
Old 07-03-2017, 02:15 PM   #823
zeal86
zeal86's Avatar
Drives:
Some new interior shots...
Old 07-03-2017, 02:25 PM   #824
zeal86
zeal86's Avatar
Drives:
Some undercarriage shots...
Old 07-03-2017, 02:30 PM   #825
zeal86
zeal86's Avatar
Drives:
Here are two exterior shots...
CARBON10 (07-03-2017)
Old 07-03-2017, 03:16 PM   #826
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Have you considered the 2017 tail lights?
Originally Posted by humfrz
I'm old and lazy
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
