Old 07-01-2017, 06:09 PM   #1
zeal86
zeal86's Avatar
Drives:
DIY: Broken or Missing Sidemarker A-clip Fix
Turn your front wheels all the way to one side to gain more working room... complete one side then turn to opposite side to complete the other.
Drill a hole as close to center as possible... I used a 1/16" drill bit. I could have gone a little smaller but those drill bits are at my work.
Pass the safety wire through the hole and get a couple of twist or so close to the mounting tab.
You'll pass both ends of the safety wire through the square opening... one will go through the closest hole (maintenance hole) to the square opening (not pictured here)... the other one will go below and then on the outside of the maintenance hole...
The safety wire that passes below the maintenance hole settles in the slot pictured here...
Push in the sidemarker making sure your safety wire ends pass through the correct locations. Using safety wire pliers, twist the safety wire thereby tightening the sidemarker into place. Cut off excess safety wire and bend inward.
You're done! if you ever need to remove your bumper just cut the safety wire to remove sidemarkers. Of course you'll need more safety wire to secure sidemarker again but this is a lot more secure than the A-clip ever was.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 9 Users Say Thank You to zeal86 For This Useful Post:
arkanist (11-20-2018), BirdTRD (07-01-2017), BRZyJ (07-02-2017), DarkPira7e (11-03-2018), HSC (12-03-2024), juenedgi (10-30-2020), MJones_RB (07-04-2017), RedReplicant (06-19-2022), rns294 (07-01-2017)
Old 07-01-2017, 11:59 PM   #2
Emero
Emero's Avatar
Drives: Whiteout '13
Thanks
Just HUGE THANKS for the write up zeal86.... THANKS
Emero is offline   Reply With Quote
The Following User Says Thank You to Emero For This Useful Post:
zeal86 (07-02-2017)
Old 07-04-2017, 07:52 PM   #3
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
cool i should snag up some safety wire from school, do you work on machinery or aviation?
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 07-04-2017, 08:01 PM   #4
zeal86
zeal86's Avatar
Drives:
Aviation... you know your occupations... lol
Old 07-04-2017, 08:25 PM   #5
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
This method works great. I use zip ties instead of wire.
ajcarson11 is offline   Reply With Quote
Old 07-04-2017, 08:35 PM   #6
zeal86
zeal86's Avatar
Drives:
I considered it... I love zip ties! lol
I decided on the safety wire so I could drill the smallest hole possible... plus it just occupies less space.
Old 07-05-2017, 01:20 AM   #7
1GiantTurtle
Space for Rent
yup currently going to A&P school
been doing this for the past 6 months, i wonder why it never crossed my mind to do that haha
Instagram: 86turtle
Instagram: 86turtle
The Following User Says Thank You to 1GiantTurtle For This Useful Post:
zeal86 (07-05-2017)
Old 07-05-2017, 01:29 AM   #8
zeal86
zeal86's Avatar
Drives:
I've learned sheet metal on the job but I'm actually an Electronic Technician... I do mechanical jobs from time to time... I am not an A&P though. Many good paying jobs in the Aviation industry. You have a bright future!
The Following User Says Thank You to zeal86 For This Useful Post:
1GiantTurtle (07-05-2017)
Old 07-05-2017, 11:58 AM   #9
G-Unit86
Just and FYI side marker clips can now be purchased at:
http://www.ft86speedfactory.com/oem-...l#.WVz-YoQrKHs
Just use super glue and they will no longer fall out.
G-Unit86 is offline   Reply With Quote
Old 07-05-2017, 12:01 PM   #10
zeal86
zeal86's Avatar
Drives:
Thanks... I saw that recently but I was tired of dealing with them... the clips not ft86speedfactory... lol
Old 07-05-2017, 12:03 PM   #11
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
That safety wire is backwards. Just kidding, aviation is the way to go. 6yrs F15 jet engine mechanic, and currently line tech for United. Where are you going to school at?
thatfilipinoguy is offline   Reply With Quote
OEM wiper clip first snow storm clip broken Jertronic Scion FR-S / Toyota 86 GT86 General Forum 2 12-29-2015 02:03 PM
HID install missing clip? gabrielthethird Cosmetic Modification (Interior/Exterior/Lighting) 7 01-28-2015 02:16 PM
JDM Sidemarker A-Clip Issues Cliu91 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-16-2014 12:44 PM
Sidemarker and Sidemarker Light arm broken off while driving. CreinCrein Issues | Warranty | Recalls / TSB 4 05-20-2014 09:49 AM
Broken Light clip ...$125 AUS Neilus AUSTRALIA 2 12-30-2012 06:45 PM
