Old 06-29-2017, 12:26 AM   #71
stevesnj
stevesnj's Avatar
Get a traffic cone, steal one like I did, and drive towards it in 2nd gear and throw the wheel left or right, whatever your preference, off throttle feather the throttle to hold the slide. DO NOT BRAKE or e-brake, thats drifting, and it's stupid. :P I do it this way to extend my slides.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
TorontoNat (07-14-2017)
Old 06-29-2017, 01:37 AM   #72
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Drifting can be initiated without the e-brake as well.
EDIT: Caught the brake part, but regardless, I fail to see how it's stupid.
Old 06-29-2017, 11:59 AM   #73
stevesnj
stevesnj's Avatar
Just my opinion.
Old 06-30-2017, 12:19 PM   #74
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Ketchupy sushi?
That sounds horrible
Hehe oh god no that really does sound bad
driftartist is offline   Reply With Quote
Old 06-30-2017, 01:27 PM   #75
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Only if you hit something. I slide the hell out of my car. When you come out, rip another gear, thats living
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 07-01-2017, 05:19 PM   #76
root
Drives: Raven FR-S
Originally Posted by mazeroni View Post
Has that always happened? The differential in these cars lock the wheels 50:50 under power, right? So if you are turning, the outside wheel (I think) is forced to turn slower and 'skips' and sounds like you are peeling out.
I think power sliding is great. I did it once in the rain when making a U-turn onto a 2 lane road - then never again. I maintained control, but was not expecting the car to slide as much as it did. I ended up sliding left to right to left to right between the lanes. I was so surprised that I couldn't think to ease my foot off the gas to straighten out. Once I got it straight enough I just dumped the gas and thankfully didn't spin out.
Nope, we have torsen diff which I believe ours is designed for about 4:1 torque split. It allows pretty normal driving. If you've got lockers or really aggressive clutch diff then you get that, the drifter boys couple houses down
I'll hear them all the time making the U-turn to pull into their driveway chirping away.
With hard compound high mileage tires, pretty much any sliding, loss of traction will make a squeal. Even hard cornering where youre not sliding out yet. I had the even crappier all season tires, not the Primacy on mine. They lasted 3 years, including a number of autocross, before I finally got tired of them. According to the wear bear they still had some life.
Now running the RE71Rs, amazing difference, feels like a whole new car! You won't be wanting to power slide these though, it'll take way more speed and power to get them to and they will get worn out in no time.
root is offline   Reply With Quote
Old 07-04-2017, 09:06 AM   #77
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by dinfern22 View Post
Gotcha!
But doesn't powersliding cause stress on the cars alignment, because the wheels are trying to go straight but is being forcefully moved sideways while the wheels are still spinning?
It's actually less stressful than hard cornering at the limit, since tires have more grip when gripping (static friction region) rather than slipping (kinetic friction region):
When cornering hard, the car is still trying to force the wheels sideways, but with higher force due to having more grip when not sliding (static friction).
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
dinfern22 (07-04-2017)
Old 07-04-2017, 01:39 PM   #78
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
If you want to slide your car around, go attend a gymkhana event.
We just had one locally. Did an event last year and was much fun, couldn't maintain a slide though.
The Twins make me smile
Old 07-12-2017, 08:14 PM   #79
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
go back to eat burgers you imbecile
Old 07-14-2017, 10:34 AM   #80
paulca
Drives: Toyota GT86 Coupe Red (UK)
They get over confident, hit gravel or water, don't have the space to start with, there are many reasons.
Had an experience like this in the spring. An exit road that is more or less an open wide hairpin bend. As usual the car encouraged me to boot it round it in 2nd.
Was just getting into the sweet spot over 5k rpm expecting the tail to come a little lose but just as it began to slip it slipped out onto the gravel at the edge of the road thrown out by gravel trucks I assume.
Woooosh, screech! I'm now 70 degrees sideways looking out the side window down the road the VSC buzzing and whrring. I let the wheel spin until it thumpped into the lock and then quickly unwound it again as I was... somehow... pointed back down the road just considerably slower like down to under 20mph.
I believe the VSC saved me from going right round into a full spin out.
Looking at it, how risky was it really? The road was wide, there was nothing oncoming and on the left side of the road was a wide 'hard shoulder'. Even without the VSC saving the spin I would simply have spun 180 on the exit or if I'd over corrected and got back lash I'd have stopped on the hard shoulder.
It has however made me reconsider where and when I will push for a bit of 2nd gear powersliding. When something unexpected makes your little powerslide into a BIG one it will be awfully handy to have LOTs of room to fuck up in safely.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
The Following 2 Users Say Thank You to paulca For This Useful Post:
dinfern22 (07-15-2017), Tcoat (07-14-2017)
Old 07-19-2017, 11:00 AM   #81
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Bad news guys..apparently I have a punctured tire from a nail, on my rear drivers side tire.
I went after the tire dropped to 10PSI. Do you guys think this is from the power sliding, and the tire caught a nail?
dinfern22 is offline   Reply With Quote
Old 07-19-2017, 11:46 AM   #82
bababooey
Drives: BRZ SWP Limited -6MT
seems like it depends where in the tire the nail is. up the sidewall likely so, new tire.
bababooey is offline   Reply With Quote
Old 07-19-2017, 11:57 AM   #83
dinfern22
dinfern22's Avatar
Oh shit, didn't know you need a new tire of it's in the side.
I'm at the dealership now and getting a patch, but I'm not sure where the puncture is located.
Do you NEED to get a new tire if the puncture is on the side, any downsides to getting a patch even if it's on the side? Thanks!
Old 07-19-2017, 12:57 PM   #84
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
They won't repair it, and tell you why if it's in the sidewall.
Punctures are always possible even if you only move the car a couple inches.
Spoiler that with help performance but not harm mpg? DVNARC Scion FR-S / Toyota 86 GT86 General Forum 58 08-17-2015 10:34 AM
4 way stop. paulca Other Vehicles & General Automotive Discussions 43 02-19-2015 01:15 AM
Stop me if you've heard this one! Sincerely, Sam Scion FR-S / Toyota 86 GT86 General Forum 21 11-22-2014 06:41 PM
Please... Stop... Me.. moda3 Great Lakes 4 12-09-2011 12:51 PM
