Old 06-28-2017, 04:57 PM   #1037
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Thanks. I'll read it tonight!
Weigaldo is offline   Reply With Quote
Old 06-30-2017, 10:29 PM   #1038
HALOFR
HALOFR's Avatar
Drives: 2016 Scion FR-S
I am having issues with this as well using the "F00D". This is what my numbers look like while driving and idle. Haven't driven my car for a few days and I've tried to message openflash but no response yet. Any info is appreciated.
HALOFR is offline   Reply With Quote
The Following User Says Thank You to HALOFR For This Useful Post:
nikitopo (07-01-2017)
Old 07-01-2017, 01:38 AM   #1039
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is an issue with monitoring IAM. The tune doesn't have any problem and it is safe to use it. Shiv is a bit busy currently with the beta testing of OFT 3. I am sure that things will get sorted out in a while. Please be patient.
Old 07-01-2017, 03:35 AM   #1040
HALOFR
HALOFR's Avatar
Thanks, I appreciate the info. I'm glad it's just a minor issue.
Old 07-01-2017, 05:10 AM   #1041
Kodename47
Kodename47's Avatar
Drives: UK GT86
..... and quite a few other parameters too by the looks of it.
If anyone could genuinely get their IAM down to 0 I'd be very shocked, although a poorly setup Ignition Advance table could do it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-01-2017, 05:26 AM   #1042
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have the same issue with "D00G", but I found the IAM value from the KC Learned and other parameters. I calculated IAM and equals 1.
Old 07-01-2017, 10:52 AM   #1043
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
My OFT starts up..
And then is totally unresponsive to touch. I've unplugged and re plugged a thousand times. Screen pops up but I can't actually select anything.
Everything was fine until I plugged it in and it did an auto update the other day.
Any suggestions?
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 07-02-2017, 02:56 AM   #1044
PDXsuperfly
Drives: 2013 FRS
I have been running "Stg2 UEL A01D.bin" and its been good but how do I know if this is for 91 or 93 octane? Also since I have the OFH I was looking to run "Stage 2OFH A00D.bin" I have it uploaded on the tablet but before I try it I wanted to make sure it is the 91 and not the 93 octane tune. Unfortunately where I am the highest is 92 Octane so I wanted to be sure I was running the 91 tune.
PDXsuperfly is offline   Reply With Quote
Old 07-02-2017, 07:24 AM   #1045
steve99
Drives: FT86
Originally Posted by brzzy View Post
My OFT starts up..
Any suggestions?
Try plugging oft baxk into computer and updating again, maybe the update was incomplete , make sure you logged in as administrator on the pc
Old 07-02-2017, 07:27 AM   #1046
steve99
Drives: FT86
Tunes loaded in oft default datavase are 93 octane I believe.
The ofh specific tunes were done for 93 fuel, and top brand 93 they are more agresive than the standard 93 tune
Old 07-06-2017, 08:09 AM   #1047
brzzy
@anthonysestito
brzzy's Avatar
Have tried everything including this - still no luck.
@Shiv@Openflash hasn't responded to my emails about screen issues I've been having for like 6 months now.
So, not to happy about this thing anymore.
IG: @ANTHONYSESTITO
Old 07-06-2017, 08:16 AM   #1048
steve99
Drives: FT86
on the pc log in as admin
delete the C:\openflash directory and all subdirectories
download and reinstall openflash manager from here
http://www.openflashtablet.com/downloads/
as admin
plug in oft and see if update completes
Old 07-06-2017, 09:47 AM   #1049
n0thing
Drives: Subaru BRZ
uel stg2 93 here, afaik the redline has been increased. in terms of tracking/acceleration, is there a benefit to shift at 7600 instead of 7400?
n0thing is offline   Reply With Quote
Old 07-06-2017, 11:59 AM   #1050
churchx
churchx's Avatar
Drives: 2014 GT86
While power/torque at top of redline drops, for best acceleration almost always, almost for any car, it's worth to spin the closer to redline, the better, as resulting torque at wheels will be higher simply due still being in lower gear. It's more of how safe it is, to spin to particular rpms on specific engine, but that aside, longer at lower gear/higher rpms - faster, even if by dyno curve at a bit lower rpms engine produce more hp/tq. Also sometimes at some tracks ability to go at higher rpms may mean less shifting, and taking larger portion of track at lower gear, instead of loosing some time/acceleration on shift-up.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
