Old 06-30-2017, 10:30 PM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Gent5 UEL header + Overpipe intial Review
Here is a review of the Gent5 UEL header + Overpipe found on FRSport.
http://www.frsport.com/Gent5-G1112-G...p_1478692.html
Waiting for the UPS man today got a head start taking off the stock headers and taking some measurements and weigths
First wanted to measure the inside diameter of the overpipe and secondary.
Looks to be 50mm inside or slightly less that 2" WEAK!
Weights
headers 20.8 lbs
overpipe 4.6lbs
Then ordered my own heatshield stuff to cover oil pan near the header. Got some OCD and covered some areas of the engine too!
SuperTom is offline   Reply With Quote
Old 06-30-2017, 10:42 PM   #2
SuperTom
SuperTom's Avatar
THEY ARRIVE!
Arrived tonight so I will be installing them Sunday
Really Nice looking welds
Best pic I could get of the Merge collector looks real clean and smooth
Then took some weights
Headers 15lbs
Over pipe 3.5 lbs and the overpipe looks nice as well
Inside Diameter of the overpipe and end of the header flange 58mm or about 2.25"
Only minor thing was one small section of the flanged wasn't machined the same but the area was still smooth and flat with the rest of the flange otherwise these are 99% perfect
More OCD kicked in And I always cover any flange, seal or gasket with a layer of Acousti Seal which is a tar like stuff. Wanted to extra seal the connecting pipes
These were sealed very nice from the factory was able to get them apart about a 1/2" which was good enough to get some tar on
All back together and cleaned up. A lot of tar got pushed out telling me the stock seal is very precise.
Stay Tuned Sunday for my install!
Old 06-30-2017, 11:08 PM   #3
Teseo
Drives: frs
Glad you went for car parts and not cocaine and prostitute.
Old 07-01-2017, 02:58 AM   #4
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Would have been a more interesting thread though.
Old 07-01-2017, 06:43 AM   #5
SuperTom
SuperTom's Avatar
well I was in Vegas a few weeks ago...
Old 07-02-2017, 02:31 PM   #6
SuperTom
SuperTom's Avatar
Installed
Installed this morning man this was the easiest header install Ive ever done. Didn't even need swivel attachments like others have said.
Here are the Siruda gaskets which can be purchased with the headers
The went to coating every flange with Acousti-Seal. Man I really love this stuff for making a sound/airproof seal, just wear some gloves because it can get messy.
Installed the overpipe first. Couldn't imagine installing an overpipe with the headers still on the car
Bad pic but loosened the bottom bolt of the stock cat pipe to have some play with the overpipe to rear cat connection.
All buttoned up everything fit perfect
Plenty of space between the overpipe and suspension. I had added a layer of the insulation on the suspension incase it was close. Not the case had a good finger gap.
Final Top down view
Sound - don't have a good setup to record yet but there are plenty of clips of UEL headers with stock midpipe and catback on youtube.
First cold startup I thought man that's loud but not the case at all. Even without a cat this sounds quiet with the rest of the stock exhaust with a slight change to the rumble.
I could defineantly upgrade to a highflow cat and a more flowing catback but I would still go with something on the quieter scale
Power- NO tune yet but that delay in the middle rpms seems gone. Accelerated more linear. Cant wait to feel what a tune will do. Plus eliminating that cold start non-sense will be on my list.
Also the Blox CEL eliminator seems to be working so far with 100 miles driven we'll see. Time to drive again!
Old 07-02-2017, 03:23 PM   #7
Teseo
Drives: frs
Those gaskets are approved by Moltres
Old 07-02-2017, 04:10 PM   #8
Andrew025
Andrew025's Avatar
What's that seal like when you try to remove it?
Old 07-02-2017, 05:55 PM   #9
SuperTom
SuperTom's Avatar
Don't know who the hell he is but I'm glad he approves!
Its easy to put on has about the same consistency of a silicone glue going on. Apparently heats and cures to be a bit more solid. So you would need to scrape it off. I used some mineral spirits to clean off the excess on the pipes. Thankfully for me I got 3 years until inspection so it will be on there for a while.
I felt under there while the car was jacked up and running. Zero I mean zero leaks! Here are some reviews on Amazon
https://www.amazon.com/Walker-35959-.../dp/B000CQDL94
Old 02-15-2018, 12:41 PM   #10
ort895
ort895's Avatar
You ever get around to getting a tune?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-15-2018, 01:02 PM   #11
Timmy_Jones
Spun
Drives: 23' Supra
Is the overpipe size of 2.25" smaller than stock? Or other header/OP combos?
Timmy_Jones is offline   Reply With Quote
Old 02-15-2018, 08:52 PM   #12
SuperTom
SuperTom's Avatar
Been running on OFT v3 beta tune since install. Runs great even in really cold temps since then. Lot more mid rang torque which this car needs. Heard there is a v4 tune coming out soon!
Old 02-15-2018, 08:55 PM   #13
SuperTom
SuperTom's Avatar
From my measurements above 2.25" is the inside diameter. I believe stock is 2.25" outside diameter. So bigger without being overkill. I run into a 60mm HKS dual resonated front pipe and HKS rear legamax catback. Keeps the velocity of flow the same all the way through
Old 02-16-2018, 09:32 PM   #14
ort895
ort895's Avatar
Ordered a header just now, we'll see how it goes.
Tomei UEL Header and Overpipe Review xlid007 Engine, Exhaust, Transmission 13 05-04-2017 10:46 AM
FS: JDL UEL Header & Overpipe rever5e Engine, Exhaust, Bolt-Ons 6 12-29-2014 07:34 PM
JohnMotoring's overpipe review zc06_kisstherain Engine, Exhaust, Transmission 7 08-08-2014 11:03 PM
hks header, motiv overpipe, motiv front pipe, ark catback review ft86me Engine, Exhaust, Transmission 9 11-26-2013 11:19 PM
FIRST 86 Intial Accessory Options GodSays Scion FR-S / Toyota 86 GT86 General Forum 18 05-04-2012 08:04 PM
