Old 06-29-2017, 12:55 AM   #85
Gforce
Drives: 2013 Subaru BRZ
Originally Posted by ApexEight View Post
Bump from the dead...
Is there any advantage to trimming the rear bump stop, say, half an inch?
On stock suspension.
Yes.
Gforce is offline   Reply With Quote
Old 06-29-2017, 06:33 PM   #86
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Gforce View Post
Two possible solutions: cut a section out of the bump stop and glue the cut pieces back together, Goop works. I recommend cutting a piece out of the hardest, top section. Or drill holes in the section of the bump stop you wish to soften. I recommend quarter inch holes drilled in the centre section.
Cutting the smallest section off will cause a more abrupt rise in effective spring rate. Cutting out part of the hardest, top section, or drilling holes in the middle section work better.
I dont like the idea of drilling the bumpstop. The structure of the rubber foam is compromised and you risk further damage of the structure after being repeatedly compressed. Especially in the front struts since it is possible to rotate while the bumpstop engaged. But who knows.. I've not tried this. I stopped considering messing with the bumpstops when I installed adustable coilovers.
Intent > Content
Old 06-29-2017, 09:09 PM   #87
Gforce
Not rubber, plastic. Closed cell foam plastic, probably a urethane. Drilling or cutting won't affect the stability of the structure as long as you don't go overboard. Goop happens to be a self curing urethane glue which is compatible with bumpstop materials.
Old 07-26-2017, 12:33 PM   #88
Ben_G
Drives: Blue BRZ
I'm sure glad @ApexEight revived this thread.... but does anyone know if the stock suspension at full travel puts the wheels/tires past the wheel arches and by how much?
Ben_G is offline   Reply With Quote
question about front travel on coilovers uncivilised Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-26-2013 05:33 PM
FS: Standard Suspension R7TA coilovers with extra springs theGonz Brakes, Suspension, Chassis 7 07-18-2013 10:39 AM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 01:49 PM
