Old 06-29-2017, 02:22 PM   #1
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
Passenger Front Collision Repair question
I got into a wreck in my car at the race track about a month ago. This caused my passenger wheel to sit back into the rear of the fender well. After replacing all the bent and broken pieces (Lower control arm, inner and outer tie rod, coilover), The wheel sits more forward now but when I turn the steering wheel about a half turn it runs on the rear of the fender well. My question is, could an alignment fix this issue? or should I expect is to be frame damage?
Wheel Spec: 18x9.5 w/ 38 offset
Tire Size: 265/35/18
I will be posting photos when I get the chance
WhiteChocolate is offline   Reply With Quote
Old 06-29-2017, 05:05 PM   #2
Well, I'd suggest you check the clearance between the wheel and the fender wheel on both sides and do a comparison.
Next, look at the fender wells on both sides and see if there is a difference on how they are mounted.
If you can't detect any difference, I'd recommend that you have the car placed on an alignment rack and let the tech take a look see.
Old 06-29-2017, 05:10 PM   #3
After changing all those parts an alignment is pretty much required even under the best of circumstances.
Spuds (06-29-2017), stevesnj (08-03-2017), Summerwolf (08-03-2017)
Old 06-29-2017, 05:35 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I would hope an alignment was the first thing done after the parts were replaced, otherwise you haven't even completed the necessary repair work.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
22R (06-29-2017), Spuds (06-29-2017), Tcoat (06-29-2017)
Old 06-29-2017, 08:17 PM   #5
nocoolname
I'd measure from like points in a diagonal under the car to see if everything is square.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 06-30-2017, 12:24 PM   #6
WhiteChocolate
Thanks for the input guys, I was holding off on the alignment just incase theres something that I missed to check. Ill get it on the alignment rack and go from there. Ill keep you posted
Old 07-08-2017, 08:21 PM   #7
angadam
Drives: 14 BRZ Limited
Most shops around me in the northern Ohio southern Michigan area offer a free 30 day warranty for an alignment. If the alignment is set and you find something else its free.
angadam is offline   Reply With Quote
Old 08-03-2017, 08:59 AM   #8
WhiteChocolate
Sorry for the late response...
Went in for the alignment and got everything straighten out. Only issue I'm having now is that the wheel is still sitting too far back in the passenger wheel well and my tire rubs as well when I turn it 1.5 rotations to the right. Still looking into it see where the damage is coming from.
Best auto collision repair shop :( Tiggimon Northwest 14 02-23-2017 03:04 PM
Collision repair around Columbia, SC? Fishbed77 Southeast 1 07-28-2015 10:49 AM
good bodyshop/collision repair shops near Downtown LA DarkestBuddha Southern California 2 06-26-2015 06:30 PM
Collision experts and body repair experts :) Mikeez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 03-17-2015 11:58 AM
Collision Repair in NJ? Reflex NY / NJ / CT / PA 15 01-17-2014 09:28 PM
