Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-03-2012, 08:01 AM   #15
Blur GT
Drives: 86 soon
6K from the GT to the GTS doesn't sound like that much, but on a car like this its nearly 18% price difference. I went for the GT cause the lighter weight and lower price means the money saved will go a long way to some wheels, suspension or other mods. Would have liked the digital speed display for convenience, but that alone is not a deal breaker!
Blur GT is offline   Reply With Quote
Old 07-03-2012, 08:11 AM   #16
m0nty
m0nty's Avatar
Drives: 86 GT
I'd like to see comparisons because apart from brakes and wheels I have no idea where this claimed extra 30kg comes from. I wonder if 1,230kg is for the GTS auto. I reckon there would be less than 15kg between the GT and GTS and most of that is wheels.
m0nty is offline   Reply With Quote
Old 07-03-2012, 08:12 AM   #17
os86
Drives: 2jz
maybe its the seat warmers ...lol
os86 is offline   Reply With Quote
Old 07-03-2012, 08:16 AM   #18
450hp/tonne
Drives: 2011 Corolla Ascent Sport
To repeat an earlier post:
Originally Posted by 450hp/tonne View Post
Please note that all 4 calipers, rotors and even pads are different between GT and GTS. The biggest issue will be the larger diameter front rotors (GT:277mm vs GTS:294mm).
You will also find the ride and handling performance is reduced (16" tyre has a stiffer sidewall [despite higher profile] and stiffer ride), so might want to test drive both to see if that upsets you.
450hp/tonne is offline   Reply With Quote
Old 07-03-2012, 08:42 AM   #19
Blur GT
Drives: 86 soon
I must say im only going off quoted numbers regarding weight. I will corner weigh my car as soon as its in my possession, but surely the dual climate control, seats with heaters and the wheels (16s vs 17s) are the main weight adders. Wouldnt think satnav, headlights and smart entry to make any difference.
Old 07-03-2012, 08:44 AM   #20
os86
Drives: 2jz
I am also sure that the GTS comes with the 17inch spare as opposed to a spacesaver / steelie for the GT which does add extra weight
Old 07-03-2012, 08:52 AM   #21
Paragon
Guest
Posts: n/a
Originally Posted by Nafe View Post
GT calipers and pads are the same as GTS, just the rotors are slightly smaller.
You will notice very little difference on track I imagine, and even less on road. ANd the GT is lighter anyway.
AFAIK the rotors should be a direct bolt on anyway. Wear out GT rotors and then replace with GTS rotors.
hi how reliable it's this info, from toyota tech or something as the brake difference is the only reason for me to go from gts to gt, everything else I can do without
Old 07-03-2012, 08:54 AM   #22
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Yeah the GTS has a full size spare.
my first mod will be to put that in the garage and put some tyre in a can in the boot..
then i can put a FG sub box in the spare wheel well..
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-03-2012, 08:55 AM   #23
Paragon
Guest
Posts: n/a
I was wandering how you can get 277 and 294mm rotors to fit
the same calipers
Old 07-03-2012, 09:04 AM   #24
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I have inquired about fitting GTS brakes to a GT. I enjoy braking more than accelerating. I was going to fit 2 piece rotors to the front anyway and vented discs at the rear then I received this pdf from the local dealership. All the prices are acceptable to me except for the "H/U ASSY VDC". I don't even know what that is. I am now thinking of buying a 2nd hand Elise instead.
You will need to move the brake pads further out some how. Either by fitting new calipers or new brackets/mounts that fit between the hub and the caliper. You can't fit larger diameter rotors and not move the caliper.
You have tested both versions?
Old 07-03-2012, 09:22 AM   #25
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
Thanks mate, I was told by a Toyota employee, but not parts. I was actually going to make an enquiry with parts tomorrow, but now no need
My previous statement was incorrect, my apologies
Nafe is offline   Reply With Quote
Old 07-03-2012, 09:23 AM   #26
Captain Snooze
Drives: Red Herring
Who has claimed 30 kgs? Toyota Australia's website says 18 kgs difference for the manuals.
Old 07-03-2012, 09:28 AM   #27
Captain Snooze
Drives: Red Herring
No worries. After so many theories,guesses and interwebbing getting concrete information is slowly becoming available.
Even if I subtract the price of discs and pads (which I would source, maybe with a little cream, tarragon and nutmeg) that VDC unit puts it way over what I am willing to spend just on brakes. Yes, I could go the GTS route but then I am ending up with stuff I dont want/need.
Old 07-03-2012, 07:00 PM   #28
Captain Snooze
Drives: Red Herring
I had sent an email to Kenneth at Toyota Belconnen, ACT after receiving that pdf:
"Hi Kenneth,
Thank you very much for your quick email.
As I was looking at the prices I was thinking "good, good, acceptable" then I nearly fainted when I saw the price of the "H/U assy VDC". Could you please tell me what this is? Google was not able to help me.
With thanks,
B."
I have just received a reply mail.
"Good Morning B,
This is the upgraded VDC ( Vehicle Directional Control ) brake actuator – to suit Auto Transmission, the VDC to suit Manual Transmission is in pdf quote attached to this email.
Regards
Ken Lee
Canberra Toyota"
Then this:
"Hello B,
I have had another look at more parts required for the upgrade to premium brake system on base 86 Toyota, maybe abs computer is different, I could not find one in E/P/C, other issues could come into play as well, will the wheels have to be 17” or 16 “ ? Does base model have correct wiring loom for this upgrade ? as is new model our service department would still be in process of training technicians to work on this car, labor costs ? Hope this proves useful in you making correct judgment call on this one or maybe exploring possibility of purchasing upgrade model with all premium brakes system etc installed .
Regards,
Kenneth."
Mmmmmm... not looking good.
Still can't decide on AT or MT for your first FRS/BRZ? This may help... Moto-P Engine, Exhaust, Transmission 366 09-15-2019 11:14 AM
Help me decide Decoy68 Other Vehicles & General Automotive Discussions 0 06-18-2012 08:29 PM
Messed up? You decide. Godzilla35 Scion FR-S / Toyota 86 GT86 General Forum 66 05-15-2012 02:20 PM
Next months Stock GT5 Course Poll - Help us decide! merlin2111 Scion FR-S / Toyota 86 GT86 General Forum 28 02-17-2012 07:11 PM
Next months Stock GT5 Course Poll - Help us decide! merlin2111 Scion FR-S / Toyota 86 GT86 General Forum 18 01-02-2012 01:53 PM
