#15 |
Drives: '13 FRS - STX
I did Motul 300 at 30k miles and I'm now at 60k, any difference from OE was nigh unnoticeable and likely placebo. I think I'll try something different next week but I won't dissuade anyone from using Motul, it certainly did it's job.
#16 |
Drives: 2013 Asphalt FRS
So since you drained the transmission 2 times after putting the new stuff in are you sure you have enough in it???? might want to have a whole six pack on stand by....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#17 |
Drives: 2014 GT86
strat61caster: from what i read here about experiments with different oils, 1) worth be careful with amount of oil changed, as gear switch feel was different with both under & over filling, 2) i guess most did targeting enhancing of cold gear switching in cold climates. So maybe different choice then Motul300 indeed will be better. Apart from Motul, Redline MTL 70W80 was often mentioned, so did Pentosin MTF2 75W80. Though they are not as universal as M300 and for diff one will need different oil then.
| The Following User Says Thank You to churchx For This Useful Post: | strat61caster (06-25-2017) |
#18 |
Drives: FR-S,GTI
Just noticed, I mistyped. The car only has 108,000 miles not 180,000. And no. The only thing I've done is change the oil, wash and wax, clean the interior, filled up the windshield washer, new wiper blades, new battery, gas and lots of tires. At this point in my VW's life it had gone to the shop at least 50 times to have everything you could imagine to be repaired or replaced at least once. Some things like water pumps and coilpacks many times.
The only problems I have with the FR-S is the drivers side window rubber needs ArmorAll regularly to keep from pinching (since day 1) Should've gotten it fixed under warranty but I hate to bring it to the dealer for any reason. The only other "problem" is the driver's door trying to cut my leg off anytime I park at any up angle. And I have an angled driveway. |
| The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
#19 | |
Drives: car
Captain obvious here, have you tried parking in the opposite facing direction so that gravity holds the door open rather than closed? |
#20 |
Drives: 2017 BRZ
One of my bolts snapped while I was tightening the fibre undercover, your good, I now have a screw stuck inside, and I didn't even put too much pressure.
#21 | |
I still have some Motul 300 left over from the 30k mile change (4L-2.2L-1.3L=0.5L left) that I'll be putting in the differential along with a fresh liter, 'cause I'm cheap and it doesn't appear that fluid type has a big effect on the way this Torsen operates. ![]() I appreciate the suggestions! I hadn't considered leveling the car before the fluid swap but now that you mention it I probably should. |
#22 |
Drives: 2017 86
When I was an Evo X guy people swore by redline.
Sent from my SM-G935V using Tapatalk |
| The Following User Says Thank You to Darkrune For This Useful Post: | strat61caster (06-26-2017) |
#23 |
Drives: 2014 GT86
But then again some also commented that redline can be hit or miss, and they had better experience with motul (which also seems to be most popular by this poll).
| The Following User Says Thank You to churchx For This Useful Post: | strat61caster (06-26-2017) |
#24 | |
#25 | |
Drives: Track preped NA FRS
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | strat61caster (06-26-2017) |
#26 |
And here I was about to order some motul and change both tranny and diff for "better shift feel" as my 5th gear grinds a bit once a week while driving
#27 | |
Drives: 2013 FRS
Sent from my SM-G930V using Tapatalk
WIFE: "How can there be anything left to buy?"
#28 | |
This stuff seems to be super hit and miss depending on use case and climate, there's no universal solution (which is why I'm trying something different, maybe it's better, maybe it's worse, idk, to reiterate I don't consider anything 'wrong' with the way my car shifts with OE or Motul, just that it could be better). |
| Traded my FR-S for a Mustang GT: A cautionary tale | Reason | FR-S / BRZ vs.... | 191 | 04-05-2017 11:40 PM |
| a tale of two dealers | perryair | Issues | Warranty | Recalls / TSB | 20 | 05-05-2016 11:30 PM |
| DIYer's and NOOBS - MUST READ | TurboBRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 07-22-2015 09:49 AM |
| Do you have a tale of karma to tell? | gt8613 | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 11-20-2014 09:42 PM |
| Cautionary tale (not my car) boost can be a huge PITA too, its not all red roses..... | Sportsguy83 | Forced Induction | 208 | 10-10-2014 11:30 PM |
