Old 06-14-2017, 05:40 PM   #603
srscion
srscion's Avatar
Drives: 2016 FRS
I just noticed something my rom end with F00C, I cross-referenced roms that are AOOC+ and there is the option to disable p0068 in romraider, but not in mine. Its possible my map sensor may be a defect. But first I will try altering the CEL limits again to see what happens.
srscion is offline   Reply With Quote
Old 06-21-2017, 11:09 AM   #604
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
before bitching at me not knowing anything first. i am a total noob and never edit any tune before.
i usually let someone do maf scaling or fixing my tune but i want to learn!!
I downloaded this maf scaling tool v.24.1 and what do i do?
i ran program and how to import log info. i was like WTF!!! lol
I am mechanic savy but not software like this lol
Old 06-21-2017, 10:02 PM   #605
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
For each horizontal tab (sections of the application) at the top of the tool, there are vertical tabs down the side. One of the vertical tabs in each section has instructions for that section.
Old 06-21-2017, 10:34 PM   #606
zc06_kisstherain
Drives: SWP BRZ
i know but difficult to understand what to do...
i am quite computer savy..
how load up logs to adjust anything?
Old 06-22-2017, 10:01 AM   #607
Spuds
The Dictater
Spuds's Avatar
If you are asking how to get logs on to your computer, then you aren't quite ready for maf scaling yet. Look up "subaru data logging" "Subaru rom editor" "flashing an ECU" "romraider" "ecuflash" "tactrix" "openflash tablet". That should give you the basics.
Also, there is this sticky http://www.ft86club.com/forums/showthread.php?t=29340
Old 06-22-2017, 11:07 AM   #608
zc06_kisstherain
Drives: SWP BRZ
I already read these and asking someone to guide me lol
but guiding and educating is different story.
we all shouldnt go to school if textbook is what we all need.
i am not really super duper total noob...have little basic knowledge on looking at datalogging..
anyway, thanks.
maybe i am stupid lol
Old 07-25-2017, 02:20 PM   #609
Kodename47
Kodename47's Avatar
Drives: UK GT86
I just wanted to add this info as it seems to be a massively overlooked effect of MAF scaling as many look to MAF scaling as a 1 step fix.
Below we'll use an exaggerated example situation that the engine is being held at 0.9 load and 2600 RPM.
Here's the fuel and ignition maps on the original MAF scale.
We can see that the fueling target is 14.0:1 and the base timing is 2.35 degrees advance. Now lets say that the fueling error works out to be around -15% (AFR too rich) and you adjust the MAF scale to that effect. Due to the MAF re-scale the engine load calculations will also end up having the same reduction, so now at the same situation your load is now around 0.75
MAF Scale Reduced 15%
This correlates to the same MAF voltage so the same actual airflow as above however you are now targeting 14.6:1 and base timing advance of 13.95 degrees. That means despite the same conditions in the cylinder you are now targeting a leaner AFR and nearly 11.5 degrees more advanced timing. Now lets swing the MAF up 15% the other way as if the fuel error was lean.
MAF Scale Increased 15%
Targets of 13.6:1 AFR and base timing advance of 0.23 degrees.
Now I know that my example is a little extreme and if you're not changing intake you wont get error like that, however I have just rescaled an intake where the original is around 15% out under WOT conditions. Even in my 1st example that a -5% change in MAF scale from the original would result in 4 degrees of extra advance. For those having a working tune that then starts to pull timing after a MAF re-scale then this could well be the cause.
All this needs to be taken into account when you play with your MAF and is one of the reasons that when you want to correct your OL MAF scale, if you've got all your load dependent settings (timing, cams, load limits, injection control etc) set then changing your MAF scale might not be the solution that you want to do.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
steve99 (08-18-2017), Tor (07-25-2017)
Old 08-18-2017, 01:23 PM   #610
ELorinD86
Drives: 2015 Halo White FRS
Lump at 3v for when maf scaling
Steve99
I've read your advice over and over about how to not get the lump at 3v when doing open loop, but I must be mixing it up. When you talk about the columns to look at to set a good percentage do you mean the columns in the data log sheet or something else? I set what I was assuming is the throttle error % to 7.5 but I still get a big lump. Another reason I'm assuming I'm looking at the wrong thing to change this is default percent was 30% not 200%
ELorinD86 is offline   Reply With Quote
Old 08-18-2017, 04:06 PM   #611
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by ELorinD86 View Post
Steve99
Have a look at this:
http://www.ft86club.com/forums/showthread.php?t=119535
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-18-2017, 08:12 PM   #612
steve99
Drives: FT86
Steve99
I wrote that a long time ago, the VGI program has has a lot of revisions and refinements since then, the defaults have likely changed.
have a look at wayno guide
http://www.ft86club.com/forums/showthread.php?t=94822
if your stock intake id grab his maf scale as starting point and then you may only need to tweak the open loop section above 3.2v
Old 08-18-2017, 08:17 PM   #613
steve99
Drives: FT86
Another demonstration of why almost all intakes on NA cars are way more trouble than their worth, especially stuff like the 3" maf tube ones that throw the maf scaling way off and require almost a total retune ( not just maf scale) to get working correctly for minimal gain
Old 08-25-2018, 12:48 AM   #614
Boomerang
86
Boomerang's Avatar
Does it matter if I do the logging when my IAM is dropping?
Old 08-25-2018, 06:50 PM   #615
Kodename47
Kodename47's Avatar
Drives: UK GT86
No
.: Stealth 86 :.
Kodename 47 DJ:
Boomerang (08-25-2018)
Old 08-25-2018, 11:08 PM   #616
tomm.brz
Drives: brz 2017 hksv2
No
But there is the "Fuel map - compensation" that enrich the afr based on IAM...
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
