View Poll Results: Which of the following options have you decided upon for this much discussed Gen1 201
No torque dip specific modifications: It doesn't bother me. 67 25.38%
No torque dip specific modifications: I don't want any potential future warranty issues due to mods. 26 9.85%
OFT tune 28 10.61%
UEL Header (Which one?) 14 5.30%
UEL header + OFT tune 100 37.88%
Something else: Please specify. 19 7.20%
Wait for the performance results of the 2017 model before deciding. 10 3.79%
Voters: 264. You may not vote on this poll
Old 06-14-2017, 01:32 PM   #141
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I never really noticed much of a torque dip. In fact I regularly pass people on the freeway in the middle of that torque dip. Honestly the throttle response is so fast it doesn't really matter much.
DandoX is offline   Reply With Quote
The Following 3 Users Say Thank You to DandoX For This Useful Post:
strat61caster (06-14-2017), Tcoat (06-14-2017), Vic4uf (06-14-2017)
Old 06-14-2017, 01:37 PM   #142
Yep!
We worked it out from the dyno graphs once and the "dip" lasts around a tenth of a second. Suck if trying to set a world drag race record but no real world effect on the streets or highway. Turbo lag can last far longer under heavy acceleration.
DandoX (06-14-2017), strat61caster (06-14-2017), Vic4uf (06-14-2017)
Old 06-14-2017, 01:53 PM   #143
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Yep!
You'd never see the torque dip in this scenario with most motor / gear setups.
The Following User Says Thank You to Summerwolf For This Useful Post:
Tcoat (06-14-2017)
Old 06-14-2017, 02:03 PM   #144
Yep. If your are trying to set a world drag race record with a stock Twin you are in for a world of disappointment anyway.
Old 06-14-2017, 03:45 PM   #145
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by tumbla.jr View Post
10. BOOST.... the cure all fix
Edelbrock Supercharger Boost plus Delicious Tune...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 06-14-2017, 03:50 PM   #146
And no lag!
paiceyfan (06-14-2017)
Old 06-14-2017, 03:54 PM   #147
gramicci101
Off Topic
Nothing said you had to be going for the fastest time. There are all kinds of records.
The Following User Says Thank You to gramicci101 For This Useful Post:
Tcoat (06-14-2017)
Old 06-14-2017, 04:43 PM   #148
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Detroiter View Post
My previous car was a 02 Audi A4 with the 1.8t motor and I can tell you that with it and any car that comes turbocharged from the factory that isn't a dedicated sports car (IE- 911 Turbo, GT-R, etc) The torque and power will always die off at the top.
Car manufacturers use the smallest turbo possible to minimize spool time and give it a nice punchy low to mid torque so the average consumer is like "OH MY CAR IS FASTTTTTT" When in reality it is not.
The pull all the way to redline is one of my favorite thing about my FRS. It is so much more exciting than a mid range torque shove.
Haha yep agreed, it's just the result of the small OEM turbo. I'll give credit to VW though. For the way the average person drives, the TSI engine is tuned well with peak torque coming below 2000 RPM.
Occasionally when I'm giving someone a ride in the GTI, they'll mention the car feels surprisingly quick (even though I'm just driving normally through traffic below 4000 RPM). For the regular driver who will never redline an engine, the TSI has a very broad usable torque curve.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
strat61caster (06-14-2017), Tcoat (06-15-2017)
Old 06-14-2017, 04:50 PM   #149
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The issue is that if you get used revving your engine and then go back to the TSI engine, then you see the difference.
Old 06-14-2017, 09:54 PM   #150
DarkSunrise
It works both ways. Sometimes after a week of driving the GTI, I get into the FR-S and wonder where the power went.
Then I remember I shouldn't have upshifted so early and there was another few thousand RPM to go. The two engines have very different characteristics - I just try to enjoy them for what they are.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Tcoat (06-15-2017)
Old 06-14-2017, 10:18 PM   #151
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Unhappy
What tune do you have? A proper stage 1 93oct tune should give gains after the torque dip.
Delicious 91/93 tune, it's nice but you don't feel the rush near top anymore... I know it's faster and it has more torque all around and more hp...but I like how stock shoots you a tiny bit forward with lightest touch on the gas paddle pass 6.5k...
after tune it's just very stable climb & the throttle response is more dull on top.
Old 06-14-2017, 10:35 PM   #152
navanodd
Drives: 2013 BRZ Sport-tech WRB
My personal preference to handle unexpected torque dip is nachos, though its also good on wraps.
navanodd is offline   Reply With Quote
The Following 3 Users Say Thank You to navanodd For This Useful Post:
gramicci101 (06-15-2017), Spuds (06-15-2017), Tcoat (06-15-2017)
Old 06-15-2017, 01:42 AM   #153
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In general a smoother throttle response is better and faster. No reason to unbalance the car or to loose grip, unless you intend to do so ...
The Following User Says Thank You to nikitopo For This Useful Post:
chaoskaze (06-16-2017)
Old 06-15-2017, 09:23 PM   #154
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I never knew the car had a "torque dip" until I joined the forum. Every engine is different. Before variable cam timing, we figured out where the engines "power band" was. Choosing a cam while Building an engine was always a compromise. Did you want low end, or high end? Couldn't have both.
chaoskaze (06-16-2017), Quentin (06-17-2017)
decisions decisions Triumphrider Scion FR-S / Toyota 86 GT86 General Forum 13 12-01-2014 07:29 PM
Decisions decisions... amilleri Scion FR-S / Toyota 86 GT86 General Forum 26 05-05-2014 03:33 PM
Automatic or Manual Transmission? Decisions, decisions... Bfly Engine, Exhaust, Transmission 27 07-08-2012 03:25 PM
decisions... EPIKsung Scion FR-S / Toyota 86 GT86 General Forum 9 06-16-2012 10:22 PM
Decisions, decisions... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 24 05-16-2012 01:18 PM
