Old 06-14-2017, 09:33 AM   #463
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Sounds like doing an inch on the Flex Z and driving it around to see if it's enough would be the way to go. Be sure to get an alignment and give it some time before you decide to go lower and add LCA's, or just do it all at once. Once you pass an inch, you're compromising geometry.
JazzleSAURUS is offline   Reply With Quote
Old 06-14-2017, 11:52 AM   #464
Darkrune
Darkrune's Avatar
Drives: 2017 86
Originally Posted by KnightRyderx2 View Post
Install mine over the weekend, they feel great. The height is pretty good but I may raise the back a little, may 1/4 inch. Have the damper set at 7 all around right now.
Are you running spacers?
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 06-14-2017, 12:04 PM   #465
KnightRyderx2
Drives: 2014 FR-S
Yup, 25mm all around. At stock height it was good but now that I'm dropped the rear is a bit in for my taste, needs more poke. That natural camber pulled the top in taking away some poke. A 30mm, maybe even 35mm in the rear would be nice. It really doesn't bother me though, I'll be buying some new wheels in a couple months.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
Darkrune (06-14-2017)
Old 07-05-2017, 04:34 PM   #466
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Is the stiffest from the right? Or left? I have 32 clicks, but 16 is the max. But I'm not sure if it's from the right or left...
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 07-08-2017, 02:57 PM   #467
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
16 is correct
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Exrald (07-08-2017)
Old 07-08-2017, 04:08 PM   #468
Exrald
Exrald's Avatar
Originally Posted by zc06_kisstherain View Post
16 is correct
Is the stiffest from right or left?
2013 Scion FRS
2022 Toyota GR86
Old 07-08-2017, 05:08 PM   #469
jawnthen
Drives: 2013 BRZ Limited 6AT
Turn clockwise all the way and you are at full stiff or 0. Then turn counter clockwise to soften it up.
Sent from my Pixel using Tapatalk
jawnthen is offline   Reply With Quote
The Following User Says Thank You to jawnthen For This Useful Post:
Exrald (07-08-2017)
Old 07-08-2017, 05:37 PM   #470
Exrald
Exrald's Avatar
Got it! Thank you!!!
2013 Scion FRS
2022 Toyota GR86
Old 07-15-2017, 11:13 PM   #471
86Craze
Drives: 2016 FR-S
These are roughly the same price as the MeisterR in the group buy section. How do you think these compare ?
86Craze is offline   Reply With Quote
Old 08-11-2017, 06:58 PM   #472
KingBaeless
KingBaeless's Avatar
Drives: 2017 GT86
Looks Good Man, I've Been Looking Into These & KW'a V1, Also Skunk2's & ST Suspensions. Still Doing Some More Research Before I Decide.
KingBaeless is offline   Reply With Quote
The Following User Says Thank You to KingBaeless For This Useful Post:
D_Thissen (08-14-2017)
Old 08-12-2017, 06:00 PM   #473
KnightRyderx2
Drives: 2014 FR-S
Thanks man. I love the way they ride and how they feel. I've done a few back country runs twisty through the country and they feel awesome. The only thing is I believe they would be a little bit on the soft side for track work if you are there very often. Once or twice a year would be ok. For street/daily and sprinted driving they are awesome.
I have heard nothing but great things about KW V1 and ST Suspension. You couldn't go wrong with either of those. I have not heard much about Skunk 2. Also you need to think about what you plan on doing with the car; track, auto-x, drift, or just street. Things to think about.
The Following 3 Users Say Thank You to KnightRyderx2 For This Useful Post:
brybot (09-24-2018), KingBaeless (08-15-2017), Teseo (08-12-2017)
Old 08-13-2017, 03:46 AM   #474
Whooosah
Drives: FRS
Just a quick review after installing and riding on flex z for a month daily and one track day.
For daily drive I really like how they ride coming from stock suspension and eibach pro kit springs. I started out at 7 clicks from full stiff and it felt pretty good. Comparable to stock ride and comfort levels with a bit more control in corners. I backed it down to 10 clicks from full stiff and am really happy with that. To me feels even a bit more comfortable and cushy over bumps and rough roads. Very smooth ride overall and I would say as many have, it is a better ride than the stock suspension. My ride height is set at about 25 1/4 inches from the ground to top of wheel arches all around. It can go a bit lower but I don't want to further compromise the suspension geometry as the rest of my control arms etc are stock.
I just did another track day at PIR and I feel like they did great. I bumped it up to 5 from full stiff all around and it felt pretty good. Didn't go fast enough to really put it through its paces but in the 2 and 3rd sessions I settled on 3 from full stiff up front and 4 in the rear. Other mods on the car are 225 mpss, header and tune. 2.9 camber front and 2.0 rear. As the pace picked up I could feel the weight transfer is quicker and more controlled in fast left right transitions I was able to carry atleast 5mph more speed in corners more comfortably. In all corners the stiffer spring rates and damping gave more confidence and control to push harder and attack corner entry and exit more. So a performance gain was definitely noticed coming from stock/springs. In long sweeping turns there is maybe slightly less body roll but you can definitely still feel it as I am on stock sway bars.
As far as translating to improved lap times I was 2 tenths quicker that my previous fastest lap on stock/springs, but that was with a lift to let a faster car by so that was atleast a few tenths lost on my fastest lap of the day. I wasn't able to nail a decent lap without traffic. I did notice improvement though and the car was more planted and had more grip in transitions where as the stock setup would wallow and lose control waiting for the suspension to settle. I know these aren't track oriented performance coilovers but for a newbie like me I think they are a fantastic setup for daily and ocasional track or autocross days. I'm really happy with them especially for the price you can't go wrong.
Whooosah is offline   Reply With Quote
The Following 3 Users Say Thank You to Whooosah For This Useful Post:
ApexEight (08-13-2017), brybot (09-24-2018), Teseo (08-13-2017)
Old 08-13-2017, 11:17 AM   #475
KingBaeless
Drives: 2017 GT86
I Would Only Be Using For Street Driving, Thanks For The Feed Back.
How Low Are You?
Old 08-13-2017, 12:01 PM   #476
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I love my MeisterR they have softer spring rates which make daily driving perfect with an aggressive drop.
SuperTom is offline   Reply With Quote
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
