#43 |
Drives: '15 BRZ RA
Thanks. I'll check later what tables are changed.
#44 | |
Drives: '15 BRZ RA
I compared file "Stg1 A01G.bin" with a standard A01G file and the table "Requested Torque A (Accelerator Pedal)" is changed. |
#45 |
Drives: 2013 Scion FRS
What exactly is being updated, all maps? I have a '13 FRS with stock intake system and 2.5" catless headers to frontpipe on E85. Car got hit, but i get it back on the 20th.
Sent from my HTC6535LVW using Tapatalk |
#46 | |
Drives: FT86
, you will also the odd minor changes due to oft using usa roms as base roms and copying tune changes to other countries rom they did not change throttle in 2017 roms though Ive got some throttle tables that change the throttle mapping quite a lot as i did not like the soft mapping in the lower end of throttle, but had to make a lot more substiantial changes than oft guys did to three throttle tables to achieve this. make throttle very linear. I did not want to use external controller. @Tor is trying them as well, they make much more substantial difference than the small tweak oft guys did |
| The Following User Says Thank You to steve99 For This Useful Post: | nikitopo (06-13-2017) |
#47 |
Huge E85 fan!
Drives: 2016 Scion FRS
For the v3 tunes, will the launch control RPM be set lower? Right now all I get is wheel spin.
Also will idle RPM be turned up a bit? |
| The Following User Says Thank You to guybo For This Useful Post: | smg1138 (06-18-2017) |
#48 |
Drives: 2017 manual BRZ
#49 |
Drives: Raven Fr-S
Again, what definitions are you guys using to modify the tunes? I don't want to risk bricking the ECU in the middle of the season
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#50 | |
Drives: 2014 Scion FR-S Monogram
I would email him though.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#51 | ||
Little Member
Drives: Bloo - The 13' BRZ
#52 |
Email shiv with your rom ID and he will just send it to you. It's what I had to do for K00C.
Sent from my Pixel XL using Tapatalk |
#53 |
Drives: 2017 BRZ
Still no word on OTS for 2017 mt model? I'm about to sell my OFT. Unfortunate I didnt do a little more research before I bought it.
#54 |
Drives: 2017 86
| The Following User Says Thank You to Darkrune For This Useful Post: | Somerandom18 (06-18-2017) |
#55 |
Drives: frs
For those who are on beta test, how is the tune so far?
Any thoughts are welcomed |
| The Following User Says Thank You to Teseo For This Useful Post: | Darkrune (06-20-2017) |
#56 |
Drives: 17 86
| OpenFlash Tablet: Multiple Data Log files! | Shiv@Openflash | Software Tuning | 95 | 11-09-2017 08:40 AM |
| OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download | Shiv@Openflash | Software Tuning | 1062 | 08-13-2017 04:13 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet v1.55b: BIN files added! | Shiv@Openflash | Software Tuning | 525 | 04-09-2014 09:42 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
