Old 06-10-2017, 09:16 AM   #1
Teseo
Drives: frs
Going with Motul engine oil...
Summer is here and is bloody hot. I will use Motul engine (5W/30) oil in this interval, my concern is which Motul i should use:
Eco-lite
Eco-nergy
X-clean
Old 06-10-2017, 09:23 AM   #2
Trust86
Drives: 2016 Halo FRS
x-clean
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
Teseo (06-10-2017)
Old 06-11-2017, 07:47 PM   #3
Ernest72
Just use a good 0W20. I know you think a thicker oil will not break down with the heat. But a thicker oil may also not circulate as well and could retain heat. Assuming its a DD. Tracking is a different story.
The Following User Says Thank You to Ernest72 For This Useful Post:
Teseo (06-11-2017)
Old 06-11-2017, 11:42 PM   #4
Teseo
Drives: frs
Interesting about 0w/20. In Africa manuals says go with 5w/30 and where i live the temp is very similar
Old 06-13-2017, 07:43 PM   #5
Ernest72
Hence get a good oil. There are 5W30 that will shear down to 20 weights pretty quick. Go to Bob is the oil guy and pick a good 0W20 or 5W30.
I use a thicker oil in my WRX but that has a turbo, that is oil cooled. The BRZ engine was built for 0W20, see no reason why a good 0W20 oil would degrade just because its hot out.
Doubt you are spending all day up at 7K rpm anyway. With normal driving under 4K the engine is barely getting a workout.
Teseo (06-13-2017)
Old 06-13-2017, 07:46 PM   #6
Teseo
Drives: frs
Thanks mate, i appreciate. Anything wrong about going motul x-clean?
Old 06-13-2017, 09:35 PM   #7
swarb
I went with eco-lite 5w-30. It's energy conserving approved so it meets the energy savings requirement in the manual. No idea what that means.
They meet different standards so maybe that can help you decide.
The Following User Says Thank You to swarb For This Useful Post:
Teseo (06-13-2017)
Old 06-14-2017, 09:37 PM   #8
Ernest72
Motul X-clean is good.
Teseo (06-14-2017)
Old 06-15-2017, 06:32 PM   #9
CSG Mike
CSG Mike's Avatar
300V
Teseo (06-15-2017)
Old 06-15-2017, 08:31 PM   #10
Lust
Drives: 2017 Subaru BRZ
300V
Would you recommend 300v even for a daily driver?
Lust is offline   Reply With Quote
Old 06-16-2017, 02:49 AM   #11
CSG Mike
CSG Mike's Avatar
Yes, I use it in my daily. You can run extended oil change intervals, but use used oil analysis to determine what is right for you.
Lust (06-16-2017), Teseo (06-16-2017)
Old 06-16-2017, 02:54 AM   #12
Lust
Would you recommend 0w20 or 5w30?
Old 06-16-2017, 09:49 PM   #13
Ernest72
I would go 0W20 if its a DD.
Lust (06-16-2017)
Old 06-17-2017, 09:26 AM   #14
CSG Mike
CSG Mike's Avatar
0W20
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
cbryant514 (07-06-2017), Lust (06-17-2017), Teseo (06-17-2017)
FS: Motul engine oil, brake fluid, coolant and gear oil Jesse0923 Mechanical Maintenance and Tools 7 09-07-2019 10:05 AM
FS: 4x Motul 300V 0w20 Engine Oil ($120 OBO) [SoCal] official_george Mechanical Maintenance and Tools 2 07-18-2017 04:43 AM
CounterSpace Garage || Jackson Racing Oil Cooler | Motul Engine Gear Oil Packages || CounterSpace Garage Engine, Exhaust, Bolt-Ons 41 07-08-2016 04:19 PM
Motul 5w-40 Oil for turbo engine steve86gt Forced Induction 7 05-24-2016 01:13 PM
