Old 06-09-2017, 05:59 PM   #4635
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Originally Posted by MarkR171 View Post
So much fun. No power steering, so plenty of feedback but requires plenty of effort in tight corners and counter steering. The car in it's current form loves to rotate when lifting or braking but will immediately hook up when you get back on the gas. I'm still learning to trust it, because at first, it felt like the car wanted to murder you with the back end immediately coming around when you lift and steer at the same time... getting back on the gas early and trusting it is incredibly rewarding.
I have this wild (probably stupid) dream of putting Hoosiers on the car and trying out SSP after nationals.
Video from last Saturday
https://www.instagram.com/p/BU5I-ZJhY0P/
Thanx for the video, the auto seems to shift pretty good.
But that manual steering looks like a handful, the unwinding power seems to want to rip off some arms!!!
brz7400 is offline   Reply With Quote
Old 06-11-2017, 07:47 PM   #4636
jmark
Drives: '97 NSX-T, '18 Type R
Congrats to David aka trippinbillies40
on the CS win.
http://sololive.scca.com/CT/CS.php
jmark is offline   Reply With Quote
The Following User Says Thank You to jmark For This Useful Post:
trippinbillies40 (06-13-2017)
Old 06-13-2017, 12:13 AM   #4637
dutchman1
Drives: 2017 86 6-Speed
Question to anyone running a 2017 with TRD springs: What bars are you using?
I'm still on my stock springs at the moment with a Strano front bar and stock rear. Planning on upgrading to the TRD springs this off season (assuming classing stays the same), am wondering if I need to pick up the TRD bars as well. With the 2017 rear bar being a little thicker than the previous years, I'm tempted to stick with the bars I have now and see how I like it.
dutchman1 is offline   Reply With Quote
Old 06-19-2017, 01:06 PM   #4638
JermMX5
Drives: 2017 Toyota 86
Right now I'm in the same boat as you. I'm running the whiteline 20mm up front on my 2017 86. The only other mod I have (besides the slipping crash bolts ) is a set of 17x7.5 rims.
I've actually been trying to figure out if the TRD springs will be a benefit or not over the stock springs. I've been trying to find any spring rate information because I know that they increased the front by 15% for the 2017 and I don't know if the TRD was stiffened by at least that much or not. I have them sitting in my garage and If I could find someone with a spring dyno I would 100% compare them.
Anyone know the rates?
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 06-19-2017, 02:30 PM   #4639
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No published rates, I haven't caught anyone with a dyno on them, best guess is that the TRD is just rebranded Eibach pro-kits, according to this F-3.6k, R-4.9k
http://www.ft86club.com/forums/showthread.php?t=11093
ineedyourdiddly
Old 06-19-2017, 03:01 PM   #4640
JermMX5
They kind of look similar? I'm not home right now so I can't tell though for sure. I ended up giving ISC Suspension in NH a call to see how much a spring dyno on my stock springs vs the trd would be and they're going to have their dyno guy call me tomorrow morning.
I figure if it's close to their price of a shock dyno ($30/shock) then $120 to know all the facts is probably worth it.
The Following 2 Users Say Thank You to JermMX5 For This Useful Post:
strat61caster (06-19-2017), TMF (08-11-2017)
Old 06-19-2017, 03:05 PM   #4641
strat61caster
Definitely.
ineedyourdiddly
Old 06-21-2017, 01:04 PM   #4642
Sweet
Sweet's Avatar
Drives: '15 Scion FR-S
Very interested in the results if you do the test
Sweet is offline   Reply With Quote
Old 06-21-2017, 01:39 PM   #4643
JermMX5
I might not end up doing the test because the shop doesn't actually have a dyno just a spring tester, so it wouldn't work great for the progressive springs according to them.
That, and the fact that I have since confirmed that the TRD springs are in fact rebranded ebachi pro kit springs. So the TRD rates are
Pro-Kit (82105.140)
Front: lowers 1" | rate 148-200lbs/in
Rear: lowers 1" | rate 103-274lbs/in
And multiple sources I've seen have said that the spring rates for the 2017 were increased by 15% in the front and decreased by 10% in the rear.
I know the 2013 Scion frs rates are:
Car: Front OE Spring Rate:
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Scion FR-S 37 N/mm (211 lbs/in)
So using these numbers that would put the 2017 at 150 lbs/in in the front, and the rear at 190 lbs/in.
This means that the TRD springs stiffen up the front by about 25% and the rear by about 44%. Obviously they're different kind of suspensions front to back, so the % difference front to rear doesn't mean a whole lot. But in the end I'm taking away that the TRD springs are in fact an improvement from stock.
Old 08-07-2017, 09:28 PM   #4644
doctor_driver
Drives: 17' BRZ - PP
Does anyone know how to '17 PP Sachs shocks compare to Koni Yellows? Curious as to how much benefit dropping another ~$1k on the car will actually net me.
Currently running RPF1's w/ 245/40/17 Rival S 1.5, hawk street/race brake pads, spec-D tuning catback, and about to do OEM crash bolts with custom alignment.
doctor_driver is offline   Reply With Quote
Old 08-08-2017, 04:39 PM   #4645
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I haven't heard of anyone doing the comparison yet. My understanding is most people who were dedicated to SCCA autocross went down to D-Street or switched to something else. Who else out there is rocking a 2017 right now in CS?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 08-08-2017, 05:36 PM   #4646
TrqlessWonder
Drives: 2014 FR-S
Still rockin a '14 in CS. I think there were 5 of us at Devens this year.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 08-08-2017, 09:26 PM   #4647
dutchman1
I'm running a '17, but I'm basically in DS prep. Wanted to wait to swap out to the TRD parts till next season to see if they change the classing around or not. I still have a bit of driver mod to do to be competitive anyway.
2017 86 set up for CS STX autocross
Old 08-08-2017, 10:49 PM   #4648
JermMX5
I keep seeing your sig about the axle back, is it available online anywhere? I really want an axle back for my 86 in CS.
And I know I'll be flamed for this... but I noticed a huge difference with the TRD springs, the car felt far less boaty and made it a blast through the slaloms. Most people will say that it's just for the bump stops and/or CG, but the springs rates are a lot better than stock.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
