| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
Drives: '14 BRZ 6MT
Question, I also noticed a significant increase in engine note throughout the entire RPM range. This occurs in gear moving or not moving, as well as out of gear. Have other people also noticed this? My car has all stock bushings otherwise. Also stock exhaust and intake/filter. Vibration increased through the entire RPM range as well. Other than that you can tell there is certainly a much more solid connection between the transmission and the chassis. You can hear the hollow tones, the gear engagement and a moderate whine now and then. My shifter rattle has increased a fair amount above 4.5k which is where it would be fire to a lesser degree. Yes, main question, does everyone else experience the engine note being increased quite a bit through all RPMs? |
#30 |
Drives: GT86
I could mainly hear a lot more whine from the gearbox. My car is a commuter car and I grew tired of the added NVH. So after a year or so removed it and it felt like a huge relief! Silence at last (well not really, but you get it). And when doing clean shifts (not rushed and with some mechanical sense), there is no need for it either, haven't missed it since even on performance drives (almost 2 years now?)...
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | surfwaxsmitty (06-10-2017) |
#31 | |
Drives: SWP BRZ
didnt know this method worked. jacking up front pipe hanger like 1 inch is much easier though. |
| Whiteline Positive Shift Kit DIY | F1point4 | DIY (Do-It-Yourself) Guides | 95 | 04-26-2021 01:05 PM |
| Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit | jehu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 12-14-2017 03:12 PM |
| Whiteline Positive Shift Bushing? | wootwoot | Engine, Exhaust, Transmission | 20 | 11-05-2012 07:45 PM |
| FS [WA] Whiteline KDT926(Positive Shift Kit) | stevo_12v | Australia Classifieds | 5 | 11-04-2012 05:16 AM |
| IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! | 10k Redline | Brakes, Suspension, Chassis | 6 | 10-16-2012 05:32 PM |
