Old 07-22-2013, 11:19 AM   #15
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Thanks @twincamRob I used this method to install mine last night and took all of 3 minutes. I did not even have to take off the under panel, and I also feel like you could lift the rear of the transmission with your hand and insert the bushing, so I was not too worried about the stress on the exhaust bracket.
Also, your last 2 pictures do not seem to be working, just a heads up
Originally Posted by jybrd View Post
Dont mean to get kind of off topic, but what does this part do for you?
This will fill in the voids of the factory bushing, essentially making the factory bushing stiffer. It is a great alternative to an aftermarket transmission mount for someone who wants to stiffen the mount up a bit.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-01-2013, 04:29 PM   #16
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Daniel TongTechnical Sales SupportRedranger USA/ Whiteline USA
Thank you for contacting Whiteline. I apologize your email was not replied to in a timely manner. The KDT926 will work effectively regardless of which direction the word WHITELINE can be read from. The orientation facing front or rear is cosmetic. Once again, we apologize for the delay. Please do not hesitate to contact us via phone or email, if you have any additional questions. Thank you for your support.
ok. I just received confirmed e-mail back from Whiteline and install from front or rear doesn't really matter. hope this helps for many memebers who is going to install bushing.
Old 03-07-2014, 10:08 AM   #17
Trettiosjuan
Drives: GT86
This is how I did it:
- Drove up a ramp
- removed the undertray
- removed the central nut (17mm with me, not 19mm)
- wedged in the insert from the front and then hammered it in - swing room enough - while simultaneously giving upward pushes to the gearbox by hand. Bit crude but went down nevertheless.
- Refit
The whole thing took me half an hour taking it easy, alone, most time spent reaching for those undertray screws that were obscured by the ramp...
The increase in NVH is quite noticeable on an almost stock car, do like the harder engine note and the whole feel of the mod esp. in high revs.
Trettiosjuan is offline   Reply With Quote
Old 03-07-2014, 09:11 PM   #18
FR-Slide
Drives: 13 Whiteout 6MT
This is one of the first mods I did on my S4, as I HATE driveline slop under deceleration or in traffic.
I'm not as familiar with the driveline of the 86 though. I know that there are both bushings and mounts, and then this Whiteline kit.
FT86SF has some packages that have both the Whiteline kit and a Perrin trans mount. The mount is aluminum, with almost no deflection allowed. With both of those on (on a DD street car), would the NVH be too crazy? I hate not having a tight driveline, but don't want to shake the mirrors loose either.
FR-Slide is offline   Reply With Quote
Old 03-09-2014, 04:29 AM   #19
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
this seems like a good simple mod... i am also curious about the perrin aluminum mount
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 03-16-2014, 02:30 PM   #20
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Is that method is really safe?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 03-16-2014, 11:44 PM   #21
zc06_kisstherain
Drives: SWP BRZ
Yes
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Mikepage (03-17-2014)
Old 03-26-2014, 08:26 PM   #22
Mikepage
Mikepage's Avatar
DIY__twincamRob's 5min Whiteline Positive Shift bushing install
@twincamRob i want to say to you Thank you for your how to, it work perfectly and this is not dangerous at all because you just need to raise the trany less then 2 or 3 cm.
o= FR-S =o
Old 05-06-2014, 01:14 AM   #23
SPCorBUST
SPCorBUST's Avatar
Great write up @twincamRob.
I used this method and it took me hardly any time at all.
One thing I forgot to do was grease the bushing before installation. No problem, since it was so easy to put in / take out to begin with. So future users, don't forget to do this!
Anyhoo, thank you sir!
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Mikepage (05-06-2014)
Old 07-02-2014, 09:53 AM   #24
jvincent
jvincent's Avatar
Props to @twincamRob for this.
I installed my bushing yesterday and doing it this way cut my under-car time considerably.
Old 07-08-2014, 09:44 PM   #25
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Great writeup! It's an awesome time saver if you're just installing just the 1 bushing.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 11-03-2014, 05:55 PM   #26
Pat
Pat's Avatar
Drives: 2023 BRZ
I used this method and it was great. I think all you really need to do is undo the 17 mm t-bolt, use the OEM jack to push the exhaust hanger up one or two centimeters and insert the new bushing from the passenger side front. Super easy.
Thanks for the post!
Old 09-23-2015, 07:11 PM   #27
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Just used this method for the install...I put "Whiteline" facing forward. When I tigthened down the nut on the "T"-bolt the "T" isn't centered in the space. Does that matter?
Phaedrus29 is offline   Reply With Quote
Old 09-24-2015, 05:18 PM   #28
zc06_kisstherain
Drives: SWP BRZ
sup? long time no talk. haha
doesnt matter. mine is not centered either. i looked at it for like 10 min and think about does it really needs to be centered? lol
Phaedrus29 (09-24-2015)
Whiteline Positive Shift Kit DIY F1point4 DIY (Do-It-Yourself) Guides 95 04-26-2021 01:05 PM
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit jehu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 12-14-2017 03:12 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
FS [WA] Whiteline KDT926(Positive Shift Kit) stevo_12v Australia Classifieds 5 11-04-2012 05:16 AM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 05:32 PM
