Old 06-08-2017, 04:19 PM   #1
skylt
Drives: BRZ Premium (Europe) WR Blue
What Short Block did I get?
I like many of you buying the 2012/2013 BRZ also experienced a engine breakdown a few months ago (spun bearing most likely) after only 57000 Km of road use. Reason for me not knowing is that the workshop did not open up the short block but just noticed a massive amount of metal residue in the oil. They ordered and installed a new short block on my cost since Subaru Nordic do not admit any issues with this first generation engines...
I was told that the first year engine was only produced this year and that from the second model year, many modifications was done (oil supply and rod bearings perhaps?)
Now to my question how do I know if I got the modified block or an old / bad one that may break again?
I have found these numbers on the engine 140015N and 2050 and C1100080 / C1100261
What does this tell you experts in here?
Skylt
Skickat från min SGP611 via Tapatalk
skylt is offline   Reply With Quote
Old 06-08-2017, 05:28 PM   #2
celek
Resident Gear Head
celek's Avatar
Changes in 2014 were all valve train related on rockers and valves for the most part. the bottom end has been the same for the life of the existence of the car.
That being said part numbers will change if another subcontracted manufacture produces parts.
i.e contract ends with a company that produces the case bolts. new contract signed with another company to produce an identical item at same specifications.
You now have a new shortblock assembly part number reflected because the case bolts are a different part number.
As for your warranty what is it in km? 50k?
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Tcoat (06-09-2017)
Old 06-08-2017, 05:39 PM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The '17 cars have a reinforced block, primarily around the rear main. There's a thread here covering this change. That being said, I don't recall hearing anything changing with internal oiling...
Old 06-08-2017, 05:52 PM   #4
Shady195
Drives: '13 10 Series FRS #1203
On a stock well maintained car thats street driven, there isn't much of a "known issue" in regards to the oil system
The only people that run into issues regarding the oil system are those that really track their cars hard and forced induction guys. In most cases a heavier weight oil and a good oil cooler helps. The biggest issue is a drop in pressure in the higher RPM band under higher heat situations.
The number of engine failures is actually quite small, it just seems like a big issue because most of the guys having these problems post on here lol.
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
Tcoat (06-09-2017)
Old 06-08-2017, 06:56 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
part numbers change all the time... supplier, different trim/model, different year, different parts cost, etc etc...
Here's a list of S15 ECUs I'm looking up for a friend of mine. They are all of the same thing....
23710-91F01
23710-91F05
23710-91F06
23710-91F07
23710-91F10
23710-91F15
23710-91F16
23713-91F07
Old 06-08-2017, 07:01 PM   #6
skylt
I've had many many cars over the years old and new and this is the first one ever where the engine has self destructed and it costed me 7500 USD to fix. When searching the Internet I find many other people with exactly the same experience, it's natural to wonder how to avoid it to happen again. I love my car and it's completely stock and has always been.
I would have hoped a car with just over 50K on the odo would be considered goodwill from the manufacturer
Old 06-08-2017, 08:01 PM   #7
mav1178
mav1178's Avatar
http://www.subaru.se/om-subaru/information/garantier/
I can't read it but in the US, the powertrain is good for 60k miles or 5 years.
Old 06-09-2017, 01:07 AM   #8
celek
Resident Gear Head
celek's Avatar
reinforced block actually came into existence in the 15 WRX with the webbing changes. I have the entire 2017 BRZ PDF and changes with tech specs.
As for the reinforcement the 2013 stock casting and sleeves have been taken to over 750WHP for a short period of time. so if that is your concern about a stronger block don't worry
venturaII (06-09-2017)
Old 06-09-2017, 10:29 AM   #9
venturaII
venturaII's Avatar
Yeah, there was a pdf circulating on here that showed the built up areas, but I can't find it right now. Either way, just pointing out that the blocks aren't all the same. The question of whether there have been oiling improvements is different, and one that I don't know the answer to. The horsepower limit is purely academic for me - I'll always be n/a.
Old 06-09-2017, 11:04 AM   #10
radroach
Drives: car
@Shady195 aside from the case sealant problem on some cars
Old 06-09-2017, 03:43 PM   #11
skylt
Only three years or 60k miles what happens first here in Sweden...
Old 06-09-2017, 09:10 PM   #12
celek
Resident Gear Head
celek's Avatar
I have it on my FB build page in an album
See signature
venturaII (06-12-2017)
FA short block xwd Want-To-Buy Requests 0 03-07-2015 12:42 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 02:26 AM
Best Custom Short Block tech31 Engine, Exhaust, Transmission 4 07-04-2014 02:42 PM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 06:21 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 07:48 AM
