Old 06-07-2017, 01:20 PM   #365
johan
Drives: '14 981CS, '99 NB1
As those are clearly Pilot Sport 4 and not Pilot Sport 4S, I thought it might be helpful to look at some reviews of them in the market they currently reside in:
http://www.tyrereviews.co.uk/Tyre/Mi...ot-Sport-4.htm
Look to be really well reviewed overall.
johan is offline   Reply With Quote
Old 06-07-2017, 01:59 PM   #366
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Question
Originally Posted by nikitopo View Post
What do you mean it isn't high speed traction limited? More traction is always welcome.
Old 06-07-2017, 02:31 PM   #367
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Aero is always welcome for a higher performance car. It'll lose some top speed, but even this is preferable if you want to be safer and more planted. In fact, the BRZ is not a heavy car and aero is needed much more in comparison to other (heavy) cars. I don't get it why you're questioning the decision.
Old 06-07-2017, 02:49 PM   #368
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
I think you have a better chance of seeing God! I waited 4 1/2 years with my 2013 BRZ and finally bought a 2017 Yellow Special Edition and had Crawford put their turbo in it.
007BRZ is offline   Reply With Quote
Old 06-07-2017, 03:16 PM   #369
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Subaru teasing again... this time for the WRX...
"Hot wings. Brought to you by Subaru Tecnica International. 6/8 #STI #TypeRA"
I really hope whatever the BRZ turns out to be, they make it available in all the colors, or at least white since that's what I want.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
The Following User Says Thank You to Lebby83 For This Useful Post:
nikitopo (06-07-2017)
Old 06-07-2017, 03:39 PM   #370
airjonny
airjonny's Avatar
Drives: Nissan Murano
Hopefully the wing is optional for the brz
airjonny is offline   Reply With Quote
The Following User Says Thank You to airjonny For This Useful Post:
Sport-Tech (06-07-2017)
Old 06-07-2017, 03:44 PM   #371
Pat
Pat's Avatar
Drives: 2023 BRZ
I disagree. Often when you add more traction sacrifices are made in other areas. If you never use 100% of your available traction in certain situations (i.e. 120+ mph), what's the point in having more traction? You're only making sacrifices in other areas (i.e. fuel economy, top speed, etc.) and not able to really benefit from more traction.
Old 06-07-2017, 03:54 PM   #372
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Do you mean that the wing is not of much use under 120 mph? There is evidence that it is functional even with lower speeds, like on a small race track. Not the specific STI wing, but a similar one:
http://www.c-west.co.jp/labs/86_20120420.asp
Lap time
GT-WING Available: 1:40.263
No GT-WING: 1:40.483
Top speed
GT-WING Available: 165.90 km / h
No GT-WING: 166.22 km / h
The improvement might seem small, but the car had steelies and stock tires. With better wheels and tires the potential should be a bit more.
Old 06-07-2017, 03:55 PM   #373
DSOmegaX
DSOmegaX's Avatar
It wouldn't be. It's a limited production number run. Adding options to such a car would be even more costly for them. If you one, I'm sure you wouldn't have any problems finding someone to trade trunks with
@dsomegax.cars
Old 06-07-2017, 04:10 PM   #374
johan
If you don't want the wing, buy a PP and just add the STI accessories. IMO the wing is crucial to setting the package apart.
Old 06-07-2017, 04:15 PM   #375
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
https://www.carthrottle.com/post/for...-nothing-more/
Forget Your Turbo STI Dreams: Subaru Has Made A New BRZ tS And Nothing More
bkharmony is offline   Reply With Quote
Old 06-07-2017, 04:27 PM   #376
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
I don't think you have a proper understanding of downforce. In your example, the only way the wing wouldn't make a difference is if you're taking a 120+mph corner flat, and I'm not sure if a corner exists in motorsports where an otherwise stock BRZ would be flat out at 120mph in a wide open corner.
That having been said, with downforce, the more you have, the faster you can go through a corner. Downforce = traction. So sure, there's a point where you have "too much downforce" because the drag on the straights outweighs the increased speed in the corners, but you rarely see that until you get to the fastest race cars. For a foil like the one that comes on the BRZ tS that won't be generating thousands of pounds of downforce, it's going to be beneficial every time you turn the wheel in anger.
trippinbillies40 is offline   Reply With Quote
Old 06-07-2017, 04:30 PM   #377
WolfpackS2k
This guy gets it.
Let's ignore that other wing bc it's not relevant to this conversation. Have you spent much time with your car on a race track? Because forget about 120 mph. Let's say the BRZ's wing is fairly effective at 100 mph. Do you know how much time a 205 hp BRZ spends above 100 mph on an average track, especially in a TURN? Very, very little time. And with a big wing like that even less, thanks to the drag.
Old 06-07-2017, 04:32 PM   #378
trippinbillies40
Drives: '22 WRB
Originally Posted by WolfpackS2k View Post
This guy gets it.
Let's ignore that other wing but it's not relevant to this conversation. Have you spent much time with your car on a race track? Because forget about 120 mph. Let's say the BRZ's wing is fairly effective at 100 mph. Do you know how much time a 205 hp BRZ spends above 100 mph on an average track, especially in a TURN? Very, very little time. And with a big wing like that even less, thanks to the drag.
You're misguided about the downforce effects of the wing that comes on this car. You don't need to be in triple digits for the foil to have an effect.
The Following User Says Thank You to trippinbillies40 For This Useful Post:
Testing Waters: Stivo Wing in asphalt gray DarkCard Exterior Parts (Aero, Lighting, Etc.) 3 10-08-2013 01:49 PM
Subaru BRZ STI Spied Testing on Nurburgring! Hachiroku BRZ First-Gen (2012+) — General Topics 162 07-05-2013 01:28 AM
Subaru's FT-86 STI Coupe Spied Testing In Southwest! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 68 09-23-2010 01:53 AM
