Old 06-06-2017, 12:20 AM   #771
zeal86
zeal86's Avatar
Drives:
Btw, I had to replace my Shorai battery. It was not holding it's charge for more than 10 hours. I constantly had it on the Shorai battery tender. It would stop charging once it reached a certain voltage which became less and less over time. Turns out one cell was dead so Shorai had to discard the battery because it could not be reconditioned.
Anyway, Shorai didn't have to honor the warranty because I was using it in a capacity that the battery wasn't necessarily intended for. But the tech (Shawn) understood and stated the battery was capable in my application and honored the warranty at 50% of MSRP.
What I did wrong: In the beginning I would hook the battery up to the Shorai tender in store mode which is fine but because of the parasitic draw found in newer vehicles, I should have added a kill switch or disconnected the ground. I started to do that after the battery was already damaged. Also, I should have taken out the battery when storing for long periods of time during the Texas heat... my garage will get very hot... continued exposure to high heat zaps the batteries integrity and performance.
So now I'll place the battery on the tender in the house. My 86 is not a daily driver so this will not be a problem for me.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-06-2017, 01:54 PM   #772
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's nice of em to honored the warranty at 50% of MSRP.
I'm interested to see the chromed out intake
zeal86 (06-06-2017)
Old 06-06-2017, 08:11 PM   #773
zeal86
zeal86's Avatar
Drives:
I received some goodies today... Not sure when I'll get these in though. I'm planning on blasting the manifold and polishing it... that will have to come first as I will install everything together. I'm also working on some door pull straps for the interior...so that will eat into my free time.
Old 06-06-2017, 11:40 PM   #774
zeal86
zeal86's Avatar
Drives:
More work on my Alt/Comp cover...
Old 06-07-2017, 08:55 AM   #775
randomthoughts
Drives: 2014 White BRZ
Are you going to incorporate the pulley covers into the design or leave them seperate?
randomthoughts is offline   Reply With Quote
Old 06-15-2017, 08:00 PM   #776
zeal86
zeal86's Avatar
Drives:
Ok... so this is what I've been up to...
I have to install to see if my adjustment on the pull cord is good. Uninstalled, the mod works great. I've yet to modify the driver side.
Also, I still have to make and upholster the cover... that should be the easy part.
I did at least couple things different than what I saw on the net with this mod. One was that I kept the spring; and two, I used a keeper pin to anchor the pull cord on the spring side.
Detailed write-up coming soon...
The Following User Says Thank You to zeal86 For This Useful Post:
Andrew025 (06-16-2017)
Old 06-15-2017, 08:03 PM   #777
spike021
spike021's Avatar
This may be a dumb question, but what's the benefit of using a pull cord vs. the regular handle for the door?
spike021 is offline   Reply With Quote
Old 06-15-2017, 08:09 PM   #778
zeal86
zeal86's Avatar
Drives:
Since I'm building a race inspired show car... the pull handle fits the theme better. Plus, I really hate the chrome handles!
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
olsonpg (06-16-2017), spike021 (06-15-2017)
Old 06-15-2017, 08:10 PM   #779
zeal86
zeal86's Avatar
Drives:
and because I can... lol 😉
Old 06-15-2017, 08:28 PM   #780
zeal86
zeal86's Avatar
Drives:
Btw, thanks to @Michael for sharing his mod pics with me... we went different routes but seeing his version's internals provided me some more insight on mine.
All the info I gathered led to (what seems will be) a successful end product!
Michael (06-20-2017)
Old 06-16-2017, 01:12 AM   #781
zeal86
zeal86's Avatar
Drives:
I put a template together tonight... I may have this cut from a thin aluminum sheet so it can be damn near perfect...
Old 06-16-2017, 02:08 AM   #782
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Pull straps have been used to replace the heavy arm rest/pull handle in race cars and usually race versions of exotics. I have seen people use them for the unlock mechanism but I don't think that is accurate. More for looks.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zeal86 (06-16-2017)
Old 06-16-2017, 03:28 AM   #783
ryoma
ryoma's Avatar
I'm not gonna lie, I really like the look of the red pull strap. I would buy a set if it wasn't $200+ and discontinued lol.
The Following User Says Thank You to ryoma For This Useful Post:
zeal86 (06-16-2017)
Old 06-16-2017, 03:32 AM   #784
zeal86
zeal86's Avatar
Drives:
Well, once I post my write-up... you should be able to make your own for A LOT less than $200+.
When I checked the prices on these... they were $325. I enjoyed the challenge of making this mod work out, I'm glad I took a crack at it!
olsonpg (06-17-2017)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
