Old 06-04-2017, 06:08 PM   #1
Jarrid'sBRZ
Drives: 2016 Black subaru BRZ limited
2016 with a case of the window squeaks
Hello,
This morning I got into my car to find the window squeaking upon closing the door. It only seems to happen when the door is closed and the window auto rolls up. Otherwise I can open and close my window without any problem. I went through and cleaned the glass but the squeak is still there. Searched the forum and found some people who took theirs in for warranty work to have it fixed. But I would assume that the 2016 would of been equipped with a "updated" window fix. Any ideas?
Jarrid'sBRZ is offline   Reply With Quote
Old 06-04-2017, 08:09 PM   #2
navanodd
Drives: 2013 BRZ Sport-tech WRB
Can you hear if the squeak is coming from the window seal at the top? If so, pop into your Honda dealer and pick up a tube of Shin-Etsu grease. Its the best stuff for seal conditioning/lubrication and should resolve it.
If the sound is coming from inside the door itself, its probably something else. I haven't heard of any widespread window issues after the early 2013 models.
navanodd is offline   Reply With Quote
Old 06-04-2017, 09:06 PM   #3
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
This is a problem with my car as well (2017 model).
Not only when it auto rolls up, but when doors are closed and u try to roll up the windows.
Will be bringing in the car for warranty to address a slew of other problems soon.
ztrevs is offline   Reply With Quote
Old 06-06-2017, 07:59 PM   #4
Jarrid'sBRZ
What other problems are you having? Also I used some Armor all auto glass cleaner on the whole window and the rubber around the window to clean it and now the squeaks are gone!
The Following User Says Thank You to Jarrid'sBRZ For This Useful Post:
humfrz (06-07-2017)
Old 06-06-2017, 09:09 PM   #5
ztrevs
ztrevs's Avatar
Rear deck is rattling (tried all the DIYs suggested on this forum), AC fan is whining really loud, a clunking sound when accelerating from low rpms.
I'll try giving the windows and the seals a good clean next though. Thanks!
Old 06-06-2017, 10:09 PM   #6
stevesnj
stevesnj's Avatar
Dirty window felts would make a squeal too.
My 2016 Build thread
Old 06-07-2017, 12:39 AM   #7
Now, THAT is just waaaaaay too simple ..........
Jarrid'sBRZ (06-11-2017)
Old 06-07-2017, 10:25 AM   #8
Gforce
Drives: 2013 Subaru BRZ
Try cleaning the rubber window scraper along the top of the door on the outside.
Work a cloth down between the scraper edge and the glass, with windex or whatever you like in the cloth. Slide it back and forth a couple of times. You'll be surprised how dirty that scraper can get.
Gforce is offline   Reply With Quote
Old 06-07-2017, 01:26 PM   #9
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
My driver's side window squeals like a stuck pig when it's even remotely damp outside. It's so loud that people standing near the car or walking close-by will turn their heads.
Now my driver's side window is deeply scored vertically, along the tracks where the window motor lifts/lowers it. They are deep enough to feel with your finger nail, and are visible from certain angles in certain lighting.
I'm well out of warranty so I doubt there's anything I can do now, but it's really annoying.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 02:22 PM
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 11:24 PM
Clutch squeaks bhbnuckle CANADA 8 08-19-2016 11:56 PM
Leather Shift Boot Squeaks alchemy Issues | Warranty | Recalls / TSB 8 03-29-2016 02:20 PM
2015 FRS windows squeaks about 1/4 down elyugi1 Scion FR-S / Toyota 86 GT86 General Forum 26 05-09-2015 04:28 AM
