Old 05-24-2017, 11:19 AM   #211
blkwrxwag
Drives: DS FRS
Thanks for the help Manfred. Stock painted spoilers are pretty cheap thankfully.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 05-24-2017, 11:27 AM   #212
M0nk3y
Originally Posted by blkwrxwag View Post
Thanks Manfred. Now, I think I know the answer to this, but I presume that just adding the TRD spoiler would be illegal. The only spoiler I could add would be the stock one?
As for running DS, well I did it in a WRX and that thing was like wrestling a gorilla around the course. Surely a twin will be more fun? I'm not sure which is faster though - course dependent I'm sure.
The nice thing about a FRS or BRZ is that you can always build it into a STX car as funds allow. Funds don't allow that for now, but there is at least a path.
My main objective is a car that is competitive. We all know Scroggs is blindingly fast, but I do think the courses this year on the West Coast have really favored his car from a gearing perspective. I could be horribly wrong though, but that's ok as he's a good friend and I enjoy racing against him.
At that point you should just buy your car back from Tsangs lol
Old 05-24-2017, 11:30 AM   #213
blkwrxwag
Drives: DS FRS
That conversation did happen, but we couldn't quite come to terms (I was about $15k short )
-Max H.
Old 05-24-2017, 08:09 PM   #214
em99sport
Corvette convert
em99sport's Avatar
I'm thinking these with a 3mm spacer...
https://www.tirerack.com/wheels/Whee...4&autoModClar=
FYI, Traklites don't work well with extended wheel studs, so I would consider a different wheel if you're planning longer ARP studs. Their design makes the center portion of the wheel protrude a good bit and the lug holes are tight, causing clearance issues with lug nuts.
I can't comment on Koseis, but RPF1s have no issue. Also, both are lighter than the Traklites.
John W. | 191 DS
em99sport is offline   Reply With Quote
Old 05-24-2017, 09:24 PM   #215
blkwrxwag
Drives: DS FRS
No extended studs here. I ordered the Traklites based on looks, price and relative light weight. Hopefully I don't have any issues.
I've also ordered a Berk muffler delete and am buying some Guy Ankeny Bilsteins and a front bar from a friend.
All I need now is a car
-Max H.
Old 05-25-2017, 10:15 AM   #216
Open Loop
2013 FR-S Whiteout / SSC
All seven cars in DS at the recent NJ Pro Solo were twins. Any particular reason why? Just by chance?
Open Loop is offline   Reply With Quote
Old 05-25-2017, 11:45 AM   #217
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Attendance is just low for the other cars nationally as a whole. It'll change a little next year probably when people figure out which cars are top of the class (it's certainly not the FR-S/BRZ; at least for the pros).
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-31-2017, 10:04 AM   #218
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Well, I ended up downgrading from a light STX prep to a full DS prep for this season. Installed Konis, a Strano front bar, new rotors with Hawk HPS 5.0 pads, and picked up a set of Buddy Club P1 SF Challenge wheels. My alignment shop really put in some work to get me FL -1.9° / FR -1.8°, and before anyone says anything I do have the inserts on the Konis. haha Toe is set to 0 in the front and 1/16 in at the rear.
Car felt great at the Chicago Region event this past Sunday. Ran the Konis at 1/2 turn from full soft. Really tight course with a 180°+ turnaround followed by another 180° turnaround right at the start. It was a fairly confusing course visually, particularly at the initial turnarounds and the very end coming into the final gate, but ended up being a fun challenge.
I was the only FR-S/BRZ in class for the event. If I remember correctly all the other entries were WRXs with the exception of one E36 M3. After getting used to the new setup in the morning, and kind of remember how to autocross, I ended up having a decent afternoon and snagged 3rd in class. Although just barely, .010 gap to 4th place. 1st and 2nd were both very good drivers in WRXs and had me by 1.3 and over 3 seconds, respectively. But positions 3 through 7 were all within 1 second of each other.
I've got a lot to improve on with my driving still, like not overdriving my car so much, but it's looking like this should be a pretty fun season. Autocross the next two weekends too!
Here's the one picture of me from last Sunday's event, capturing massive amounts of body roll.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 05-31-2017, 10:30 AM   #219
AFRichZC6
AFRichZC6's Avatar
Those wheels look great on your car
AFRichZC6 is offline   Reply With Quote
Old 05-31-2017, 10:41 AM   #220
Shark_Bait88
Thanks! I agree.
Now keeping them clean...
Old 06-02-2017, 04:01 PM   #221
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Tire pressure
Hi,
Tire pressure question:
I bought some RE71R, and I'd like to know what HOT tire pressure are you running (those who run RE71R)?
My car is 100% stock for now. Size is 225/45/17 on RPF1.
Second question: The only thing I can play with to influence under/oversteer is tire pressure. On my RSX I would adjust the front pressure to have max grip without rolling on the side, and adjust the rear tire to remove some traction to have less understeer. I'm guessing the same apply for the BRZ; play with the rear pressure.
But on my RSX I found something strange. On my RS3 tires, I had to increase pressure to remove grip in the rear, but with the Dunlop Direzza ZII, that didn't work, instead I had to decrease pressure to remove grip in the rear.
How do the RE71 behave? Do I have to increase or decrease rear pressure to induce oversteer? Right now with the OEM tire I have good balance on corner entry, but understeer mid-corner, and sometimes also in exit.
Thanks
nico_rsx is offline   Reply With Quote
Old 06-02-2017, 04:11 PM   #222
blkwrxwag
Drives: DS FRS
Originally Posted by nico_rsx View Post
Hi,
Thanks
Hi Nico,
I would start out at around 32 hot in the front and 28 in the rear. If you want to loosen up the car, add rear tire pressure. I've been as high as 60psi in the rear on the RE71R to make a DS WRX turn
You will probably find yourself a bit loose though and for that, you really need a bigger front sway bar.
-Max H.
Old 06-02-2017, 06:34 PM   #223
Locust
Custom User Title
Locust's Avatar
Hi,
Thanks
Suggest starting at 32 front, 30 rear and playing with it until you find the sweet spot. With the RE71R in CS spec on my RS 1.0 I found 29 front / 27 rear to give even temperatures across the full surface of the tires but things change a little in DS spec.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 06-04-2017, 10:44 AM   #224
blkwrxwag
Drives: DS FRS
Quick question for those with experience of Konis.
I installed them yesterday and was surprised to find that my car did not lower itself by at least half an inch due to the lower gas pressure. In fact, the car is a bit higher in the rear.
Could this be because the stock shocks (with 34,000 miles on them) are already a low pressure shock, or am I a complete buffoon?
On my NC2 MX5, the Konis lowered the car significantly.
The good news is the car rides great with no clunks and squeaks. I double checked the installation about 10 times to make sure everything was seated correctly.
-Max H.
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 10:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 03:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 01:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
