Old 04-11-2017, 12:47 PM   #1
Bushhy
Drives: None
Loud Noise When AC Is On?
[ame="https://www.youtube.com/watch?v=2WK0FNVT9h0"]BRZ Idle AC noise? - YouTube[/ame]
So this noise started recently. I have been trying to figure it out. Clutch is stock and was replaced about 9k miles ago when my Transmission was replaced. The only way to stop this noise is to:
1. Turn off AC
2. Push in Clutch
Anyone have any ideas? I cannot figure this out for the life of me.
Bushhy is offline   Reply With Quote
Old 04-11-2017, 01:21 PM   #2
To me, it just sounds like the A/C compressor being engaged ....
Old 04-11-2017, 01:22 PM   #3
Bushhy
Drives: None
Now why would it get quiet when the clutch is pushed in? Thinking of raising my idle and see where it goes
Old 04-11-2017, 02:21 PM   #4
DirtySouth86
Drives: 2017 TOYOTA 86
Weird, I would say clutch release bearing, but not sure how the ac would have any effect on that, so I may be off base there.
Raising idle? Are you tuned? This car's idle is controlled by the electronic throttle body and the ECM. The only way to adjust idle speed would be with a tune. Why do you want to increase idle speed? what is your current idle rpm? Does the noise go away if you just barely rev the engine (100-200 rpm)?
There is a TSB for ECM reprogramming to help correct idle instability with ac on and extended crank time, but not sure if it would have any effect
on the noise.
Scion just released a TSB for the clutch release bearing as well. Not sure if Subaru, has the same TSB yet though.
DirtySouth86 is offline   Reply With Quote
Old 04-11-2017, 02:23 PM   #5
Let me guess ...... when you turn the A/C ON, the engine is under more of a load and makes that sound ...... when you push in on the clutch, the engine is relieved of turning the shaft in the transmission, thus speeds up just enough that the sound goes away .......
Calling @Ultramaroon for comment ....... although, NOT saying that humfrz is "out to lunch" .........
PS - Bushhy, I suggest you go down to your local indoor firing range and ask to test fire a .357 or .44 mag revolver (use no ear protection). Then you won't notice half the weird sounds that the FA20 engine makes ......
Old 04-11-2017, 05:00 PM   #6
I bet this is just the "neutral rollover" sound.
Because this is a little four-banger, at idle, especially if the engine is doing work like running the AC, it doesn't rotate perfectly smoothly. It could be eliminated by installing a heavier flywheel but who wants that?
With a constant-mesh transmission (all manual transmissions) all the gears are driven all the time. We only pick which pair of gears is engaged to the output shaft.
There's always a little backlash between the rotating components. Just take my word for the fact that it has to exist. Everything just rattles a little in neutral.
Sometimes we can narrow down to which pair of gears is making the most noise by introducing a little bit of drag. While it's making the noise, gently nudge the gearshift into each gate a tiny little bit. Don't hold it there. Just a quick gentle nudge and listen for a change in sound. Don't squeeze all the oil out from between the baulk rings in the syncros.
Bushhy, Let us know if that confirms anything.
Old 04-11-2017, 09:19 PM   #7
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 06-03-2017, 07:02 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine is doing the same thing. Just noticed it today, probably because I haven't used the a/c in awhile. Coming home from summer kickoff, we get off the freeway, first light, a/c cranking, stop, put in nuetral, sounds like a box of marbles. Push in the clutch or turn off a/c, goes away.
Sound is loud and awful.
Does anyone have a "for sure" answer? Ultra's makes sense, especially since I have a lighter flywheel.
Btw, a 2015 owned 2.5 years, never heard it before.
Old 06-03-2017, 09:40 PM   #9
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Amazing, on my 2016 I heard it the very first day I drove it off the lot.
(I don't care anymore unless someone figures out exactly what it is)
Joon525 is offline   Reply With Quote
Old 06-04-2017, 11:45 AM   #10
ZX88
ZX88's Avatar
Drives: 22 BRZ
Same issue here only when the A/c is on. For me its pretty intermittent. I notice it more on hotter days. I pretty much have the A/C on all the time.
ZX88 is offline   Reply With Quote
Old 06-04-2017, 04:15 PM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Today, not a sound. Yesterday was the first time I have ever heard it, but I was in "the valley of the devil". I don't think my car has ever been that hot.
I think I stated my last response wrong. My "for sure" list was more a wish for an expert to say it's ok.
Old 07-10-2018, 10:58 AM   #12
SaulSNES
SaulSNES's Avatar
Hate to bring this back from the dead, but I havent been able to find much (if any) information on what could be the cause of this and a possible solution. Im experiencing the same sound with the AC on, dissapears when I push the clutch in and only hear it when its idling. I thought it maybe had something to do with the lightweight crank pulley, flywheel and driveshaft I recently installed but im seeing that even stock twins are experiencing this noise.
And. Its. Driving. Me. Nuts.
Any leads would be greatly appreciated!
SaulSNES is offline   Reply With Quote
Old 07-10-2018, 01:58 PM   #13
It's perfectly ok. As I said before, it's just gearbox rattle. You made it more obvious with the lightweight flywheel.
Old 07-10-2018, 03:24 PM   #14
SaulSNES
SaulSNES's Avatar
I appreciate that man!
Loud noise from back of car hypebrz Issues | Warranty | Recalls / TSB 20 05-31-2016 08:27 AM
Loud engine noise? Rifle Engine, Exhaust, Transmission 9 08-16-2015 12:26 PM
Loud noise when letting off gas? HachiRo Issues | Warranty | Recalls / TSB 5 04-19-2015 03:36 AM
Loud Buzzing Noise - Car Not Running Apex_BRZ Issues | Warranty | Recalls / TSB 7 04-13-2014 05:00 PM
FR-S Loud Engine Noise White0utFrs Issues | Warranty | Recalls / TSB 15 09-20-2013 08:28 PM
