#85 | |
I'll guess that will put you down to about 8 hours a day ....... an average days work for most folks. ...... that's for bad mouthing @Ultramaroon ...... who is too busy to mess wich you.![]() humfrz |
#86 | |
Drives: '13 FRS - STX
Had a boss who's favorite phrase was "I came in late this morning so I gotta leave early to make up for it!" He's probably only a few years younger than you. |
#87 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | humfrz (06-02-2017) |
#88 |
Drives: 15 Series.Blue
Okay, this might get long.
A space saver tire on one axle of a torsen differential will rotate at a higher RPM than the larger one on the other side of the differential. We all know this. A torsen allows the axles of the car to rotate at different speeds through the use of a set of worm gears for each axle. These worm gears are also meshed together with spur gears. So when one axle is spinning faster than the other, like in a corner or different sized tires, the worm gear of the faster axle causes the worm gear of the slow axle to spin and therefore spin the slow axle. Now the worm gears and the helical gear on the axles have a certain ratio. There is a limit to how much the faster axle can make the slower axle rotate due to this ratio. In our example there is a speed difference between the axles due to tire size. If the spare is of a slightly smaller size than normal, the torsen acts as if the car is constantly cornering. This is not good for the torsen because the worm gears are rotating constantly, because we have a speed difference in the axles. The worm gears have bearings that are not sized for constant use like the bearings for the axles are. They are small bearings. Rotation in bearings cause friction, which causes heat, regardless of lubrication there is still friction. A couple of corners is not enough to cause enough damage from heat since it is intermittent. However we are talking about constantly having one axle rotate faster than the other for a long time. So if they can be ran for a short time like this, why do manufacturers advise against it? Simple. People are idiots. The average person might not see issue with running the spare on the drive axle and put off replacing the tire while they continue to drive every day. So instead of saying it might be okay if a bunch of specific conditions are met, they tell the owner to not do it at all. Simple. |
| The Following 5 Users Say Thank You to Edibrac For This Useful Post: | humfrz (06-02-2017), navanodd (06-02-2017), Tcoat (06-02-2017), Ultramaroon (06-02-2017), WRBrzRX (06-02-2017) |
#89 | |
Not a troll
#90 |
Whoops, sorry. Forgot about that.
| The Following 4 Users Say Thank You to Edibrac For This Useful Post: |
#91 | |
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Cole (06-02-2017) |
#92 |
#93 | |
#94 |
Very true but it did kill an hour of my layover. So I got that going for me.
| The Following 5 Users Say Thank You to Edibrac For This Useful Post: | Cole (06-02-2017), nextcar (06-02-2017), Tcoat (06-02-2017), Ultramaroon (06-02-2017), WRBrzRX (06-02-2017) |
#95 |
Thank you. That's exactly what I've been trying to say.
I think.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (06-02-2017) |
#96 |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Please allow me to summarize this thread for the moderators and anyone else that does not have time to read it all:
| The Following 5 Users Say Thank You to nextcar For This Useful Post: | bcj (06-02-2017), Cole (06-02-2017), humfrz (06-03-2017), Tcoat (06-02-2017), Ultramaroon (06-02-2017) |
#97 | |
#98 | |
Edit: I would not say it stayed on topic the whole time unless @Cole works inside a Torsten and we actually witnessed him heating up due to resistance... |
| The Following 2 Users Say Thank You to nextcar For This Useful Post: | Cole (06-02-2017), Ultramaroon (06-02-2017) |
| loose rear-seat latches | hyperpunx | Issues | Warranty | Recalls / TSB | 34 | 02-22-2017 05:19 PM |
| what bushing should i get for better handling | nearvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-15-2014 04:26 PM |
| Outside Rear View Mirror Housing Loose | tonytduc | Issues | Warranty | Recalls / TSB | 3 | 10-01-2014 03:20 PM |
| Help! Trd rear bumper loose :( | FaNtaSy | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-25-2013 08:01 AM |
| Best handling car? | gt8613 | FR-S / BRZ vs.... | 154 | 10-07-2013 09:57 PM |
