Old 06-02-2017, 12:16 PM   #1
artongdou
Drives: 2017 Series.Yellow
BRZ STi Alloy Wheel Size and Offset?
Does anyone know the spec of this wheel sold by Subaru? Along with weight would be even better.
http://parts.subaru.com/p/Subaru__/S...de_Accessories
artongdou is offline   Reply With Quote
Old 06-02-2017, 12:25 PM   #2
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
These are 17x7.5 or 7 and they have a +48 offset. I can't confirm weight, but I would expect somewhere in the 19-20lb category.
kuczynskika is offline   Reply With Quote
Old 06-02-2017, 12:33 PM   #3
artongdou
If it is 17x7.5 that would be perfect. But it seems like there is no weight advantage against stock wheel.
Old 06-02-2017, 12:35 PM   #4
kuczynskika
Yeah I can't remember if the usdm wheels are 7 or 7.5. I know for a fact that the JDM versions are 7.5. But yeah, no weight advantages at all. You want something light you have to go smaller like a 16" or 17" RPF1 or forged.
Old 06-02-2017, 12:43 PM   #5
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
USDM STI wheels on the Series Blue are 17x7. The JDM version are 17x7.5
TofuJoe is offline   Reply With Quote
Old 06-02-2017, 02:01 PM   #6
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Yep, 17x7 +48. I believe weights are somewhere around 18-19lbs, so slightly less than the regular stock wheels.
I have them on my Firestorm FR-S and really like the look.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 06-02-2017, 02:17 PM   #7
Mule
Drives: 2013 FRS
First off, lovely FRS. Secondly, stock suspension/ride height?
Mule is offline   Reply With Quote
Old 06-02-2017, 03:24 PM   #8
Shark_Bait88
Thank you! And yes, although the angle I took the picture at almost makes it seem like there's even more wheel gap than usual.
But in comparison to the amount of gap from body roll in this picture, it really doesn't look all that bad. haha
Old 06-02-2017, 04:12 PM   #9
Teseo
Drives: frs
Nasty body roll over there, you will add lowering springs or coilovers?
Old 06-02-2017, 05:07 PM   #10
Shark_Bait88
Nope. I have to stick with stock springs and OEM replacement shocks, because I run in a street class for autocross. Currently have Koni shocks on the car.
Old 06-02-2017, 09:27 PM   #11
artongdou
I find oz racing alleggerita hlt really lightweight. But it only got 17x8 +48 or 18x8 +48.
Old 06-09-2017, 06:56 PM   #12
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
I know the series yellow wheels are 17"x7.5" but are they the same rim as the jdm sti 17"x7.5" rim but with different center caps?
Also I see a lot of 16" and 17"x7" (series blue) guys getting nice fitment with 20mm/25mm spacers. Would the series yellow 17"x7.5" yield the same results with spacers or is the offset different and they require spacers of another size?
TachyonBomb is offline   Reply With Quote
Old 06-09-2017, 07:14 PM   #13
fourdegrees
Drives: None
Already available here: https://www.japanparts.com/parts/detail/41618.
Wheel measurements are 18x7.5, +48 offset. DSOmegaX has them on his car already. Not sure if he weighed them or not, but I'll review his build thread.
fourdegrees is offline   Reply With Quote
Old 06-09-2017, 07:17 PM   #14
fourdegrees
Drives: None
Originally Posted by DSOmegaX View Post
I've never weighed them actually, but the invoice stated that the box was approximately 10.8kg, so I would imagine the wheels are around 23lbs each.
From his build thread.
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Alloy space saver wheel churchx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-03-2016 09:43 AM
Desired Wheel Size, Width, Offset - OPINIONS CSG David Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-21-2014 12:02 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
