Old 05-29-2017, 12:19 AM   #827
UchihaFanBoy
UchihaFanBoy's Avatar
Drives: 16 BRZ,99 Forester,13 FRS(RIP)
Originally Posted by Detroiter View Post
It comes with the UEL headers that you will use. They are specific for the kit.
Ok cool I'll just sell the tomei then
UchihaFanBoy is offline   Reply With Quote
Old 05-29-2017, 01:11 PM   #828
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Was reading this thread about Perrin Engine mounts.
Anyone here still on stock engine mounts? Are upgraded engine mounts a must when going FI?
http://www.ft86club.com/forums/showthread.php?t=58984
Alltezza is offline   Reply With Quote
Old 05-29-2017, 07:54 PM   #829
Amputechture
Drives: 2014 BRZ
I just put on STI mounts last week. Honestly man I say with complete confidence that it's the absolute best "feeling" modification that I've done so far by a country mile. They don't cost much and really make the car feel solid. If you plan on doing plugs anytime soon it's a great time to do them while you have the motor up.
Amputechture is offline   Reply With Quote
Old 05-29-2017, 08:41 PM   #830
Alltezza
Alltezza's Avatar
Any plugs you recommend? OEM? I saw HKS makes some too
Old 05-29-2017, 09:50 PM   #831
Amputechture
Drives: 2014 BRZ
I am running HKS. They are just re-branded NGKs. I wasn't able to find the NGK part number so that I could just use those and save money, but never had any luck with that. Plenty of people making way more power than I are using stock plugs so I don't think there's anything wrong with sticking to factory. I just figured Iridium is so fucking expensive as it is, might as well spend ten more bucks and go a tad colder.
Old 05-31-2017, 09:14 PM   #832
HawaiianMike
Drives: 2015 Brz Limited
Twin Scroll vs UEL
I was Looking at purchasing a JDL Twin scroll turbo kit with a gtx2867r because I want a pretty broad power band.
Other things I would like (but may be a bit much who knows), recirculated wastegate and a high flow cat. These are because I would like to pass emissions here in NY.
I would like to know if there are two comparable dyno charts showing UEL vs twin scroll and if anyone has a cat and hows its affecting things....
Will be getting a flex fuel tune for it.
Thanks so much guys!
HawaiianMike is offline   Reply With Quote
Old 05-31-2017, 09:32 PM   #833
nickg
Drives: 2014 Whiteout FR-S Manual
Besides the Work kit (CARB exemption), there aren't any turbo kits that will pass an emissions inspection.
Sent from my XT1575 using Tapatalk
nickg is offline   Reply With Quote
Old 06-03-2017, 01:43 AM   #834
grichardt
grichardt's Avatar
http://www.ft86club.com/forums/showthread.php?t=119122
Finished my install diy hope it helps if anyone hasn't installed yet or want to see what all it will take to finish.
grichardt is offline   Reply With Quote
Old 06-03-2017, 12:20 PM   #835
AllSickLike
Drives: iso white BRZ
any numbers yet?
AllSickLike is offline   Reply With Quote
Old 06-03-2017, 04:05 PM   #836
grichardt
grichardt's Avatar
Still in my tuning process. Once that's complete I'll get some dyno pulls and post them
Old 06-05-2017, 10:34 AM   #837
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
I had seen this as well once I bought my Perrin mounts.
I wrapped them in exhaust wrap and heat shielding before install.
Wrap is underneath the shielding and a few stainless steel bands are loosely tightened around to make sure it doesn't work its way off the mounts.
Rybot is offline   Reply With Quote
Old 06-06-2017, 05:56 PM   #838
Alltezza
Alltezza's Avatar
I think I'm probably just gonna snag an STi mount or the Cusco mount for simplicity on my end. The Perrin mounts are also damn expensive compared to those 2.
Old 06-06-2017, 06:01 PM   #839
Alltezza
Alltezza's Avatar
Just got the clutch installed hoping to get this broken in before we get the kit installed
What catch cans are you guys running?
Old 06-08-2017, 02:11 PM   #840
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by drambo136 View Post
I had the same problem. Mine was the tune. The latency on the fuel injectors for DW was swapped right at the patch of injectors i bought apparently. The tuner bumped it up and that worked pretty well. The idle still osolates a bit but i expected it to be a little rough.
I hope i explained that the right way
Sent from my SAMSUNG-SM-G930A using Tapatalk
what is your vacuum reading at idle from your map sensor?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
