Old 11-03-2013, 04:30 AM   #99
diss7
Drives: AE86, 2x GT86, TE27
These brake kits are going to help me with my "more fun at a tonne" build.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
industrial (11-03-2013), SuperTom (05-19-2025)
Old 05-21-2014, 01:45 PM   #100
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Looking at these to fit on my BRZ but concerned about having to add spacers to clear my wheels
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-21-2014, 07:18 PM   #101
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I want these and the new TWS wheels. 16's, obviously.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 11-18-2014, 11:54 AM   #102
Anthony
Weight Nazi
Anthony's Avatar
I totally forgot about this thread, but just rediscovered it and read it all again.
Any updates, @swift996?
Old 11-20-2014, 10:04 AM   #103
swift996
swift996's Avatar
I sold my car a while back but to give you an update. I did upgrade to the WRX kit for the 2008 car. They were 14" rotors and were 32mm thick. They were awesome but required an 18" rim to work. You can get more info here:
http://www.ft86club.com/forums/showthread.php?t=63636
On the kit mentioned in this thread. It's a solid kit, very inexpensive and does it's job. It would be great for Autocross or street driving. Pushing the car to it's limits on the track will wear through the rotors quick due to the lack of heat capacity. I wouldn't recommend it for someone who tracks their car. For auto-x and street it's a great kit.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 2 Users Say Thank You to swift996 For This Useful Post:
Anthony (11-20-2014), Trettiosjuan (07-06-2015)
Old 03-17-2015, 11:29 PM   #104
TKShu22
Drives: 2013 WRB BRZ
Great thread
TKShu22 is offline   Reply With Quote
Old 05-31-2017, 07:24 PM   #105
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Bumping this thread for the major interest in lightening everything. Just ordered wheel tire setup at 35.3lbs in stock size. Will remove 6.2 lbs per corner. Car will be down to about 2500lbs with minor HP increase so I don't need a massive BBK Im sold on the front brakes mainly for the weight loss and minor ibrake mprovement. The reason Im bumping and will continue to bump is what did you guys use for the rear????? I just read this entire thread and no one will answer.
-Does the rear Wilwood 2003 wrx kit work? http://www.wilwood.com/BrakeKits/Bra...temno=140-7006
-How about this kit mentioned http://www.pandlmotorsports.com/product-p/pl-sub401.htm ? With possible bolting on a different wildwood outer rotor that is more normal.
- Or just keep the stock rear caliper and use lighter 2pc rotors? But be stuck with stock calipers that look out of place with the wildwood calipers up front and might have a rear bias issue and not lose as much weight.
SuperTom is offline   Reply With Quote
Old 05-31-2017, 09:27 PM   #106
ryoma
ryoma's Avatar
why not go for the RR Racing setup? They use Wilwood calipers as well, but have kits for both front and rear with "proper" (there is some debate about it, look up the information and decide for yourself) brake bias.
Old 05-31-2017, 10:59 PM   #107
SuperTom
SuperTom's Avatar
They look like they sell some great bang for the buck kits but I'm looking for a lightweight rear kit to go with the Lightweight wrx front kit this thread is talking about.
Old 06-01-2017, 07:02 AM   #108
SuperTom
SuperTom's Avatar
It looks like from reading this research using the stock rear brakes with this mini Wilwood BBK has the least amount of deviance from the stock bias. https://www.pointmeby.com/2016/09/24...z-frs-gt86-86/
Was just hoping for a lightweight caliper but I'm sure I can find a stock replace lightweight 2pc rotor.
Old 07-10-2018, 08:07 PM   #109
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Wilwood BBK for WRX - Fit to BRZ
Any luck finding a light rear rotor? I heard the OEM 2006 WRX rotor is the same dimensions and shaves a couple of pounds.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
SuperTom (07-10-2018)
Old 07-10-2018, 08:12 PM   #110
SuperTom
SuperTom's Avatar
NOthing! Its seems like anyone with valuable information is banned. WTF how do people get banned so easily on here.
Any part #s on those rotors that is great information.
Old 07-10-2018, 08:44 PM   #111
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, this should answer your question...
https://www.ft86club.com/forums/showthread.php?t=101695
The Following User Says Thank You to Spuds For This Useful Post:
x808drifter (07-10-2018)
Old 07-10-2018, 10:00 PM   #112
SuperTom
SuperTom's Avatar
well I'm screwed
Originally Posted by x808drifter View Post
2457) Asking why people get banned.
Wilwood Big Brake Kit Installed msile Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 03-03-2014 02:00 PM
FS: WISC. BNIB Wilwood Front BBK Scooby South Brakes, Suspension, Chassis 4 03-10-2013 03:22 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 08:14 PM
