Old 07-02-2012, 12:54 PM   #15
vividracing
vividracing's Avatar
Originally Posted by Sam Strano View Post
I think the thinking was the Subaru has stiffer front springs to promote more understeer at the limit which is more in keeping with what is typical of a Subaru car. Scion wanted the car more free, hence the softer front springs. But to counter that the Scion has front struts that are valved differently (stiffer). I suspect they are stiffer on compression a bit, not sure how much more, if any more, rebound they possess.
Has it been confirmed that they're different? If so, that's awesome. Most manufacturers would've engineered something that isn't optimal for either spring rate but works fairly well. Using 1 strut saves money.
vividracing is offline   Reply With Quote
Old 07-02-2012, 01:13 PM   #16
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Eibach has another set of springs they are going to test to confirm today. I'm sure either Tony will post in here or I'll get an email from him at some point.
Hey guys, Tony from Eibach here.
I just got confirmation on the second set of springs we tested. The first set was a Premium model with the rates posted above by the OP. The second set of BRZ springs was from a Limited model and we just tested them this morning and it has the exact same rates as posted and the Premium model.
These were both production models from local BRZ owners. We never bothered rate testing the pre-production models we used months ago because we knew the rates would most likely change on the production run.
Jackson is offline   Reply With Quote
The Following 5 Users Say Thank You to Jackson For This Useful Post:
autobrz (05-21-2013), brybot (08-30-2016), Mageep (07-13-2012), Scourge (08-15-2017), uptown (08-25-2012)
Old 07-02-2012, 01:22 PM   #17
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Hey Tony, did you guys run the tests on the FR-S springs as well?
Old 07-02-2012, 01:24 PM   #18
Wepeel
Drives: '13 BRZ Ltd
Thanks for the confirmation
Wepeel is offline   Reply With Quote
Old 07-02-2012, 02:12 PM   #19
Jackson
Jackson's Avatar
Yes, we did. The rates the OP posted are from our testing. An email broadcast was sent out just this morning to all of our distributors and dealers announcing the new BRZ/FR-S kit with our specs and OE specs.
Originally Posted by Motopythons View Post
Car: Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
Old 07-02-2012, 02:27 PM   #20
Wepeel
Drives: '13 BRZ Ltd
What are the Eibach spring specs (rate, drop)?
Old 07-02-2012, 02:45 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Prokit is 1" front and rear, part # 82105.140
Sportline is 1.4" front and rear, part # 4.10582
I don't have the rates for either.
They are also working on some other stuff as well, but I'll let Tony post that info once it's available.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-02-2012, 02:53 PM   #22
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I wonder where the discreprency between RCE's measured rates and Eibach's measured rates come from.
Old 07-02-2012, 02:57 PM   #23
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Most likely, pre-production suspension setup that was changed last minute before production began. I imagine it still had the JDM suspension setups while they were ironing out the USDM setups.
denkigrve is offline   Reply With Quote
Old 07-02-2012, 03:51 PM   #24
Racecomp Engineering
That's seems to be the case. Interesting either way. The shock dyno was done a production set of dampers which is the important part and we did more of our testing on the production car.
- drew
Old 07-02-2012, 03:53 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Possible pre-production vs production?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-02-2012, 04:04 PM   #26
That's what we're guessing. Shock dyno was done on production version though (thankfully).
- Andrew
Old 07-02-2012, 04:38 PM   #27
Dimman
Kuruma Otaku
Dimman's Avatar
- Andrew
Did you chuck your originals? Can you retest?
I'm curious about maybe different rates for different countries.
Did Eibach USA test their own or was this info passed down from Germany?
Because titanium.
Old 07-02-2012, 04:43 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tested local owners vehicles in Cali, including a set today.
The ones RCE tested with was a pre-prod car but I would guess they'd still have the OEM springs from Miles car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
actual release date. WHEN? Ad8707 CANADA 12 05-02-2012 01:11 AM
Actual Weight For FRS??? DanPO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-22-2012 05:07 PM
What are the Actual Curb Weights? DanPO BRZ First-Gen (2012+) — General Topics 9 12-22-2011 12:01 PM
