Old 07-03-2016, 09:01 PM   #99
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by bemgikim View Post
So.. we dont have any solution to this?
Depends;
Is it making a weird noise when you're slipping the clutch?
The solution is change how you shift to minimize clutch slipping.
Is the clutch mechanism (clutch pedal, hydraulic slave, clutch fork, throwout bearing) making noise because it's no longer lubricated properly?
Lubricate it.
ineedyourdiddly
Old 07-04-2016, 12:44 AM   #100
Infidel86
Drives: 2013 GBS BRZ
My '13 BRZ just got back from the dealer for the same problem. The problem ended up being the throw out bearing. The tech said that there wasn't enough lube on the clutch fork side which caused the bearing to rust. The clutch, pressure plate, throw out bearing, and clutch fork was replaced under warranty. The car had 21k miles ok it.
Infidel86 is offline   Reply With Quote
Old 05-29-2017, 03:29 AM   #101
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
Did it fix the problem? Ive noticed my issue has gotten worse lately.
itisthumper is offline   Reply With Quote
Old 05-29-2017, 05:02 AM   #102
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
sounds like clutch slipping. also my indicator immediately show after shift.
FR-Sky is offline   Reply With Quote
Old 05-29-2017, 10:58 PM   #103
Infidel86
I'm at about 33k miles now. The sound came back about a month or two after the repair, but it only happens rarely. I get it maybe once every other week. I can live with that.
Old 06-17-2017, 11:41 PM   #104
itisthumper
Drives: WRB BRZ MT
Damn Id like to bring it in but my warranty is out since I have a '13 with 40k miles
Old 06-18-2017, 10:31 PM   #105
Infidel86
If you have it done by them while you're out of warranty it'll cost you about 2k. There's a TSB for the TOB but you're out of the timeframe for that too.
Old 06-19-2017, 11:04 AM   #106
Keeping in mind that TSBs are simply a technical document showing how to correct known issues and is in no way a recall or even acknowledgement by Toyota that there actually is an issue. The dealers can still refuse warranty work based upon the fact it is a wear part. The good ones won't but they could.
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 01:12 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
