Old 05-28-2017, 11:20 PM   #1
drz400dude
Works stage 2 install help
I'm trying to bolt the oil drain tube to the turbo and the exhaust flange is so close I can't get the bolt in the hole. Any suggestions?
drz400dude is offline   Reply With Quote
Old 05-28-2017, 11:44 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Does the bolt fit when the flange isnt there? If so then don't tighten the other bolt down before the difficult one is in place. Especially don't connect it at the top if you can.
Old 05-28-2017, 11:55 PM   #3
Dipstik-sportech
Dipstik-sportech's Avatar
Loosen the bolts on the turbo housing on both the intake and exhaust housings and rotate the center section to get the bolt in an easier location
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
drz400dude (05-29-2017)
Old 05-29-2017, 01:26 AM   #4
drz400dude
No. Even if the oil drain flange is removed it still doesn't fit.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 05-29-2017, 01:37 AM   #5
Irace86.2.0
So you are either using the wrong bolts for those holes or the dimensions are off by the manufacturer. Your options are to reconsider how to make it fit or contact the manufacturer.
You may need to post more pics for others to help see what is wrong. Or you can get a smaller bolt.
Old 05-29-2017, 01:40 AM   #6
Irace86.2.0
On second look, have you tried rotating the turbo housing?
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 05-29-2017, 01:49 AM   #7
Irace86.2.0
Old 05-29-2017, 11:46 AM   #8
drz400dude
Hmm. I'll give this a shot. Seems like they would have just provided shorter bolts. Or at least mentioned this in the directions.
Old 05-29-2017, 12:26 PM   #9
drz400dude
This worked perfectly! Aside from the E clip holding the waste gate rod shooting across the garage and taking 30 minutes to find. :eek:
The Following User Says Thank You to drz400dude For This Useful Post:
Tcoat (05-29-2017)
Old 05-29-2017, 09:23 PM   #10
Irace86.2.0
Im glad that worked 👍
WORKS CARB Stage 2 Installed! Review Mr_YUzU_FRS Forced Induction 94 05-26-2020 03:14 AM
WORKS/Ohlins Stage II R&T Coilover Suspension WORKS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 04-26-2018 09:12 PM
Experience with Works Stage 1 Turbo Kit aaguirre123 Forced Induction 33 09-18-2015 09:16 PM
My Experience with Works Stage 1 Turbo Kit aaguirre123 Member's Car Journals 9 06-09-2015 08:47 PM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 08:24 PM
